Posted: Sun Jul 15, 2007 2:24 pm Post subject: Mod 73 |
Just to add to what David Corbett has said about the practicalities: I
brought my tail planes back to my workshop and used a piece of plumbing
waste pipe, and a vacuum cleaner extension pipe which both needed building
up to a tight fit using PVC tape on one side and duct tape covered with
smooth parcel tape on the other side, both covered liberally with grease,
but without cling film or any extra release agent. The mod part 1 took about
90 mins and seemed straightforward with the hole dimensions OK and both TP6s
solidly bonded. The pipes came out with the sort of twisting force you can
readily apply by hand.
For those who don't want to wait for self adhesive labels, I
experimented with putting a single layer of bid over the required placard,
simply photocopied onto ordinary paper. It has set solidly in legible state
without any blurring of the lettering Regards, David Joyce, G-XSDJ
ksiggery(at)mac.com Guest
Posted: Mon Jul 16, 2007 9:34 am Post subject: Mod 73 |
As we are not the builders of G-ROOV and lacking sufficient expertise
(we feel) to make a good job of Mod 73 is there anyone out there
willing to do the work for us? We are Biggin based but could tow/fly
to accomodate.
Thanks Kevin Siggery
ami(at)mcfadyean.freeserv Guest
Posted: Mon Jul 16, 2007 12:01 pm Post subject: Mod 73 |
<<photocopied onto ordinary paper. It has set solidly in legible state
| Quote: | without any blurring of the lettering >>
I suspect that the Inspector's signature (when applied) will get 'bleached'
by the wet epoxy, unless signed with a laundry pen!
Duncan McF.
jron.jones(at)tiscali.co. Guest
Posted: Wed Jul 18, 2007 12:43 pm Post subject: Mod 73 |
Greetings All,
I have just completed mod 73 on my own aircraft (G-RJWX) and all went well - thankfully!
As I did the job at home and the aircraft was left at the airfield (Sleap) I needed a substitute for the torque tube. So I borrowed the tailplane posts off someone's trailer (mine have been galvanised and are now too thick!).
They needed a couple of coats of paint and flatting to get a really good, smooth finish but they were ideal.
Hope that helps.
Ron Jones.
