topglock(at)cox.net Guest
Posted: Sun Jul 15, 2007 10:27 am Post subject: Europa Tailplane - Mod 73 |
All,
I've read, with great interest, all the suggestions and discussion. I'm
no engineer, but I have a pretty good idea of what I would do, should I
find any evidence of disbonding of the tailplane bushings. And, I
believe it could be done with very little cosmetic damage to the
tailplane. I like the solid tube idea and would build off of that.
Basically, a tube, of the appropriate length, with two 1/4", round,
metal rods welded fore and aft, on centerline. The rods wouldn't have
to run the full length of the tube, but it certainly wouldn't hurt. The
purpose of the rods would be to further stabilize the tube and prevent
it from twisting.
Should the original bushings become disbonded, it should be a fairly
simple task to remove the old bushing (even if it required opening the
wingtip), remove the inner bushing and modify the foam and ribs, to
accomodate the new shape of the tube. Inserting the new tube would be
as simple as applying a thin coat of Redux to the tube and inner walls
of the foam, plugging the outboard end of the new tube and pushing the
assembly in. The new tube would then be drilled to accept the standard
pip pins. Adding covers to the pip pin access holes would further
remove the possibility of a pin becoming dislodged.
Seems to me that the new assembly would be extremely strong and should
remove any further chance of the tailplanes pulling away from the drive
pins.
So, am I way off base, of does this idea hold water?
Jeff - Baby Blue
300 hours and finishing up her 2nd annual...
Karl Heindl wrote:
Nigel,
I understand all that and your mod should have been made standard a
long time ago. But what about older Europas ? We hear reports about
disbonded TP6s but we don't hear how they were repaired. I really
would like to know. A suitable retrofit mod should also have been made
available as soon as this problem was known.
I still say that there is no way the tailplane can move if the pip pin
head is firmly against solid material on the inboard side. You say
there is always a gap, but that gap is filled with floxed epoxy, and
the head is inside a close fitting plastic pipe in my case. I think
another builder recently told us about a similar mod he made. The
remaining space around the pipe is also filled with epoxy. Of course
all these solutions are based on theory and only a lab test could
verify the claims.
When my TP5s disbonded from trailering I was kicking myself for not
having installed a one-piece pipe, but in those early days I was very
careful to follow the build instructions precisely. I stll think that
a retrofit of a one-piece sleeve would be more than strong enough to
prevent any future disbonding, and would be a relatively easy solution
where the TP6s have already disbonded.
As far as the accident goes, we still don't have any real conclusive
evidence about the sequence of events. Only a number of theories. Only
a wind tunnel test would verify the flutter theory, but who is going
to pay for that ? Eyewitness reports can be very misleading.
If the wing trailing edge pin came off first, is it possible that the
pilot was getting set up for landing and deploying flaps and
undercarriage ?
I also like the other suggested solutions where a lock is put behind
the TP12
Karl
> Karl,
> I have attached below, an excerpt of a long mail I sent to the PFA that
> describes a sequence of events that could lead to the tailplain moving
> outboard. Out of interest, there is always a gap between the pip-pin
> and the
> face of the rib.
> This was sent before the current Mod 73 was issued, but you will see
> why the
> temporary remedial action has been to reinforce the pip-pin hole.
> Nigel
> Excerpt
> ...... The only thing preventing each tailplane moving sideways is a
> single
> pip-pin that passes through the TP6 bush and into the TP4 torque
> tube. (See
> Fig.5 Chap 4)
> The design relies on a good bond to hold TP6 in place, however only the
> protruding outer 12mm (just 8mm on TP5) is required to bond to the
> tailplane
> rib that will subsequently be laid-up onto it. Epoxy adhesive does
> not bond
> well to stainless steel - so the potential for this bondline to fail is
> great.
> This tiny bondline is the only "design" load path to prevent the
> tailplane
> moving laterally. If the bond failed, the loose TP6 bush would tend
> to push
> its way inboard into the soft blue foam, allowing the tailplane to move
> outboard. The TP5 bush would offer no resistance since it would
> simply slide
> along the TP4 torque tube.
> In some early Europas, this TP6 bush has de-bonded and it is only the
> laminations into the "PipPin" access hole that prevent any lateral
> movement
> of the tail-plane. This lamination was never intended to be
> structural. If
> the aircraft is high-time and habitually operated off rough strips,
> it is
> logical to predict that the continual fretting would cause the glass
> around
> the pip-pin hole to chafe, opening up the hole to a point where the
> whole
> tailplane could slide far enough laterally to allow the tail-pane
> drive pins
> (TP12) to disengage from their drive bushes (TP13) - The tailplane would
> then oscillate violently with catastrophic results.
> Modification 10672) calls for both the Stainless TP5 and TP6 bushes
> to be
> laminated into an epoxy/Bi-Directional Glass tube before inserting
> this into
> the tailplane TP2 cores and laminating the ribs. This bonds both
> bushes over
> their entire surface area, significantly increasing the bond area and
> more
> importantly, physically tying TP5 with TP6 and both the inner and
> outer ribs
> together. With this structure, the entire bond surface area and both
> ribs
> would have to fail before the tailplane could move sideways.
> The loadpath is through the mod 10672 and not through the outer skin and
> pip-pin hole - a significantly better engineering solution.
Watch all 9 Live Earth concerts live on MSN. http://liveearth.uk.msn.com
pete(at)lawless.info Guest
Posted: Sun Jul 15, 2007 11:10 am Post subject: Europa Tailplane - Mod 73 |
So how do you drill the new pip pin holes though the outside new tube to
line up with the existing holes in TP4?
mikenjulie.parkin(at)btin Guest
Posted: Sun Jul 15, 2007 12:25 pm Post subject: Europa Tailplane - Mod 73 |
Glen and Ron P.
I am a pilot and not an aerodynamicist. However, having just blown off the dust from my old aerodynamics textbook, what you are saying is not strictly correct. It may be that you are correct with relevance to the europa, but it really does depend on where the C of G is!!
If one considers the main wing, if the Aerodynamic Centre (AC) is aft of the CofG the wing would be in a stable configuration. That is without any opposing forces the aircraft would pitch down. On the other hand, if the AC was forward of the CofG without any opposing forces the aircraft would pitch up.
As the stabiliser is well aft of the aircraft CofG it is always stabilising. But it is possible to have a de-stabilising wing with a stabilising tailplane. Overall the aircraft would be stable as long as sum of wing and tailplane Cm/Cl curves have a negative slope.
The point is that if the wing AC is forward of the CofG with no other forces affecting it the aircraft will pitch up, not down.
Most aeroplanes I have flown 'balloon' on flap selection, particularly with the first notch of flap. However the nose down effect of selecting flap is caused by a rearward movement of the Centre of Pressure which creates an increased moment about the C of G which requires the adjustment of the tailplane trim - all be it with a slightly increased nose down attitude. Much the same I suppose as saying the pitch down is caused by an increase in negative Cm.
Having said all that looking at the diagram in the aircraft handbook in the weight and balance chapter as a rough guestimate it would appear that the C of G of our europas (58-62.5in AOD) would always be forward of the Aerodynamic Centre which is approximately 25% chord in subsonic flow.
regards,
Mike.
kheindl(at)msn.com Guest
Posted: Sun Jul 15, 2007 12:48 pm Post subject: Europa Tailplane - Mod 73 |
Jeff,
I think that the TP5 and TP6 can be removed with heat without cutting any
holes. Also, it would be easier to pre-drill the pip-pin holes, as you can
then do a trial fit before bonding. To get the position exactly right I
would attach a template (using double-sided tape) with a 1/4 inch hole over
the top of the recess, first lining up all 3 holes with a 1/4 inch shaft or
bolt, before removing the TP6. Just one of my crazy ideas.
Karl
| Quote: | From: Rman <topglock(at)cox.net>
Reply-To: europa-list(at)matronics.com
Subject: Re: Europa Tailplane - Mod 73
Date: Sun, 15 Jul 2007 13:25:12 -0500
All,
I've read, with great interest, all the suggestions and discussion. I'm no
engineer, but I have a pretty good idea of what I would do, should I find
any evidence of disbonding of the tailplane bushings. And, I believe it
could be done with very little cosmetic damage to the tailplane. I like
the solid tube idea and would build off of that. Basically, a tube, of the
appropriate length, with two 1/4", round, metal rods welded fore and aft,
on centerline. The rods wouldn't have to run the full length of the tube,
but it certainly wouldn't hurt. The purpose of the rods would be to
further stabilize the tube and prevent it from twisting.
Should the original bushings become disbonded, it should be a fairly simple
task to remove the old bushing (even if it required opening the wingtip),
remove the inner bushing and modify the foam and ribs, to accomodate the
new shape of the tube. Inserting the new tube would be as simple as
applying a thin coat of Redux to the tube and inner walls of the foam,
plugging the outboard end of the new tube and pushing the assembly in. The
new tube would then be drilled to accept the standard pip pins. Adding
covers to the pip pin access holes would further remove the possibility of
pins.
Jeff - Baby Blue
Karl Heindl wrote:
>Nigel,
>I understand all that and your mod should have been made standard a long
>time ago. But what about older Europas ? We hear reports about disbonded
>TP6s but we don't hear how they were repaired. I really would like to
>know. A suitable retrofit mod should also have been made available as soon
>head is firmly against solid material on the inboard side. You say there
>is always a gap, but that gap is filled with floxed epoxy, and the head is
>inside a close fitting plastic pipe in my case. I think another builder
>recently told us about a similar mod he made. The remaining space around
>the pipe is also filled with epoxy. Of course all these solutions are
>based on theory and only a lab test could verify the claims.
>When my TP5s disbonded from trailering I was kicking myself for not having
>installed a one-piece pipe, but in those early days I was very careful to
>follow the build instructions precisely. I stll think that a retrofit of a
>one-piece sleeve would be more than strong enough to prevent any future
>disbonding, and would be a relatively easy solution where the TP6s have
>already disbonded.
>evidence about the sequence of events. Only a number of theories. Only a
>wind tunnel test would verify the flutter theory, but who is going to pay
>pilot was getting set up for landing and deploying flaps and undercarriage
>I also like the other suggested solutions where a lock is put behind the
>TP12
>Karl
>>Karl,
>>outboard. Out of interest, there is always a gap between the pip-pin and
>>the
>>face of the rib.
>>This was sent before the current Mod 73 was issued, but you will see why
>>the
>>Nigel
>>Excerpt
>>single
>>pip-pin that passes through the TP6 bush and into the TP4 torque tube.
>>(See
>>Fig.5 Chap 4)
>>tailplane
>>rib that will subsequently be laid-up onto it. Epoxy adhesive does not
>>bond
>>great.
>>tailplane
>>moving laterally. If the bond failed, the loose TP6 bush would tend to
>>push
>>outboard. The TP5 bush would offer no resistance since it would simply
>>slide
>>movement
>>of the tail-plane. This lamination was never intended to be structural.
>>If
>>the aircraft is high-time and habitually operated off rough strips, it is
>>around
>>the pip-pin hole to chafe, opening up the hole to a point where the whole
>>tailplane could slide far enough laterally to allow the tail-pane drive
>>pins
>>Modification 10672) calls for both the Stainless TP5 and TP6 bushes to be
>>laminated into an epoxy/Bi-Directional Glass tube before inserting this
>>into
>>the tailplane TP2 cores and laminating the ribs. This bonds both bushes
>>over
>>more
>>importantly, physically tying TP5 with TP6 and both the inner and outer
>>ribs
>>together. With this structure, the entire bond surface area and both ribs
>_________________________________________________________________
Posted: Sun Jul 15, 2007 1:30 pm Post subject: Europa Tailplane - Mod 73 |
Karl,
The particulars on aligning and drilling the pip pin holes should not be
a big problem. It may be as simple as marking cross hairs on the
surface of the tailplane or, building a template using a plastic tube
and end plate, simulating the drive plate, should allow you to get a
precise enough measurement to drill the holes. If you've built in a
drain hole, as provided for in the instructions, the lower hole should
be a breeze. At any rate, I see it as a doable mod and one that should
provide a much stronger tailplane.
Jeff
Karl Heindl wrote:
Jeff,
any holes. Also, it would be easier to pre-drill the pip-pin holes,
as you can then do a trial fit before bonding. To get the position
exactly right I would attach a template (using double-sided tape) with
a 1/4 inch hole over the top of the recess, first lining up all 3
holes with a 1/4 inch shaft or bolt, before removing the TP6. Just one
of my crazy ideas.
Karl
> All,
> I'm no engineer, but I have a pretty good idea of what I would do,
> should I find any evidence of disbonding of the tailplane bushings.
> And, I believe it could be done with very little cosmetic damage to
> the tailplane. I like the solid tube idea and would build off of
> that. Basically, a tube, of the appropriate length, with two 1/4",
> round, metal rods welded fore and aft, on centerline. The rods
> wouldn't have to run the full length of the tube, but it certainly
> wouldn't hurt. The purpose of the rods would be to further stabilize
> the wingtip), remove the inner bushing and modify the foam and ribs,
> to accomodate the new shape of the tube. Inserting the new tube
> would be as simple as applying a thin coat of Redux to the tube and
> inner walls of the foam, plugging the outboard end of the new tube
> and pushing the assembly in. The new tube would then be drilled to
> accept the standard pip pins. Adding covers to the pip pin access
> holes would further remove the possibility of a pin becoming dislodged.
> should remove any further chance of the tailplanes pulling away from
> the drive pins.
> Jeff - Baby Blue
> Karl Heindl wrote:
>> Nigel,
>> made available as soon as this problem was known.
>> pin head is firmly against solid material on the inboard side. You
>> say there is always a gap, but that gap is filled with floxed epoxy,
>> and the head is inside a close fitting plastic pipe in my case. I
>> think another builder recently told us about a similar mod he made.
>> The remaining space around the pipe is also filled with epoxy. Of
>> course all these solutions are based on theory and only a lab test
>> very careful to follow the build instructions precisely. I stll
>> think that a retrofit of a one-piece sleeve would be more than
>> strong enough to prevent any future disbonding, and would be a
>> relatively easy solution where the TP6s have already disbonded.
>> Only a wind tunnel test would verify the flutter theory, but who is
>> going to pay for that ? Eyewitness reports can be very misleading.
>> the pilot was getting set up for landing and deploying flaps and
>> undercarriage ?
>> the TP12
>> Karl
>>> Karl,
>>> that
>>> pip-pin and the
>>> face of the rib.
>>> see why the
>>> Nigel
>>> Excerpt
>>> a single
>>> tube. (See
>>> Fig.5 Chap 4)
>>> the
>>> tailplane
>>> not bond
>>> fail is
>>> great.
>>> tailplane
>>> to push
>>> move
>>> simply slide
>>> movement
>>> structural. If
>>> it is
>>> glass around
>>> whole
>>> drive pins
>>> would
>>> to be
>>> this into
>>> bushes over
>>> and more
>>> outer ribs
>>> both ribs
>>> skin and
gcrowder2
Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
Posted: Sun Jul 15, 2007 1:57 pm Post subject: Europa Tailplane - Mod 73 |
Yes, thats all correct. The downforce of the tail just perfectly balances the CG being in front of the Aerodynamic Center. That creates a stable pitch attitude. Actually the negative CM of the wing is one of the factors that determine the Aerodynamic Center. Once the tail is gone, the aerodynamic center of the entire aircraft will move back to the wings center of pressure, which is behind the CG causing the aircraft to pitch nose down. At the same time, the CG has moved forward since 20 lbs on the tail is now missing. Bad JuJu. The tail was creating a positive CM, which is no longer there. If the tail is normally creating downforce, then losing that downforce will cause the plane to pitch down. Just think what happens when you push the stick forward. You are lessening the downforce on the tail, which causes the aircraft to pitch down.
Glenn
Date: Sun, 15 Jul 2007 21:24:08 +0100
.ExternalClass P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass {font-size:10pt;font-family:Tahoma;}
[quote] Glen and Ron P.
regards,
Mike.
Posted: Sun Jul 15, 2007 3:10 pm Post subject: Europa Tailplane - Mod 73 |
Hi Jeff,
I think we are basically in agreement. But pre-drilling the holes in my view
is absolutely essential.
If you make a tiny mistake in drilling after the installation you will have
to start all over again, and you won't have a 100% accurate reference for
the holes and angle.
Karl
| Quote: | From: Jeff B <topglock(at)cox.net>
Date: Sun, 15 Jul 2007 16:25:18 -0500
Karl,
The particulars on aligning and drilling the pip pin holes should not be a
big problem. It may be as simple as marking cross hairs on the surface of
the tailplane or, building a template using a plastic tube and end plate,
simulating the drive plate, should allow you to get a precise enough
measurement to drill the holes. If you've built in a drain hole, as
provided for in the instructions, the lower hole should be a breeze. At
any rate, I see it as a doable mod and one that should provide a much
stronger tailplane.
Jeff
Karl Heindl wrote:
>Jeff,
>can then do a trial fit before bonding. To get the position exactly right
>I would attach a template (using double-sided tape) with a 1/4 inch hole
>over the top of the recess, first lining up all 3 holes with a 1/4 inch
>shaft or bolt, before removing the TP6. Just one of my crazy ideas.
>Karl
>>All,
>>Basically, a tube, of the appropriate length, with two 1/4", round, metal
>>rods welded fore and aft, on centerline. The rods wouldn't have to run
>>the full length of the tube, but it certainly wouldn't hurt. The purpose
>>of the rods would be to further stabilize the tube and prevent it from
>>twisting.
>>accomodate the new shape of the tube. Inserting the new tube would be as
>>simple as applying a thin coat of Redux to the tube and inner walls of
>>pip pins. Adding covers to the pip pin access holes would further remove
>>pins.
>>Jeff - Baby Blue
>>Karl Heindl wrote:
>>>Nigel,
>>>is inside a close fitting plastic pipe in my case. I think another
>>>builder recently told us about a similar mod he made. The remaining
>>>space around the pipe is also filled with epoxy. Of course all these
>>>solutions are based on theory and only a lab test could verify the
>>>claims.
>>>careful to follow the build instructions precisely. I stll think that a
>>>undercarriage ?
>>>TP12
>>>Karl
>>>>Karl,
>>>>and the
>>>>face of the rib.
>>>>why the
>>>>Nigel
>>>>Excerpt
>>>>single
>>>>(See
>>>>Fig.5 Chap 4)
>>>>tailplane
>>>>bond
>>>>great.
>>>>tailplane
>>>>push
>>>>slide
>>>>movement
>>>>If
>>>>is
>>>>around
>>>>whole
>>>>pins
>>>>would
>>>>be
>>>>into
>>>>over
>>>>more
>>>>ribs
>>>>ribs
>>>>and
The next generation of Hotmail is here! http://www.newhotmail.co.uk/
Posted: Sun Jul 15, 2007 4:09 pm Post subject: Europa Tailplane - Mod 73 |
Karl
you might get the TP5 out with heat but the TP6 is not so easy. Even
after it is loose from the end rib you then have to get it inserted into
the root rib and then get it out of that.
The heat to loosen it from the end rib will almost certainly melt the
foam to an unknown extent, not worth the risk.
Graham
Karl Heindl wrote:
Jeff,
any holes. Also, it would be easier to pre-drill the pip-pin holes, as
you can then do a trial fit before bonding. To get the position exactly
right I would attach a template (using double-sided tape) with a 1/4
inch hole over the top of the recess, first lining up all 3 holes with a
1/4 inch shaft or bolt, before removing the TP6. Just one of my crazy
ideas.
Karl
Posted: Sun Jul 15, 2007 4:14 pm Post subject: Europa Tailplane - Mod 73 |
Glenn
lowering the flaps gently at a trimmed 80 kts should result in a trimmed
60 kts without needing to adjust the trim.
I remember Ivan was delighted to discover this early in the testing and
bought Don Dykins a pint or two to celebrate!
Don was gracious and put it down to luck.
Graham.
glenn crowder wrote:
| Quote: | Hi Mike - yes the aircraft will always pitch down with a non symmetrical
airfoil. This is why
aerobatic aircraft are designed with symmetrical airfoils - zero
pitching moment.
Aerobatic pilots don't like their aircraft pitching without their command!
Also, in the accident aircraft, losing the tailplane suddenly removed
20 lbs of weight off the
tail, pitching the nose down further.
If you've ever flown a C-172 while lowering the flaps you will
probably remember the
pitch down. Actually, it balloons up first while speed is being lost,
then pitches down.
The wing is now very non-symmetrical, requiring up trim on the elevator to
balance the increased negative CM. The Europa does this too but not as
noticeable,
probably because of the powerful tail.
Glenn
Date: Sun, 15 Jul 2007 10:01:17 +0100
I accept what you say about CM about the aerodynamic centre for an
aerofoil. But are you saying that irrespective of the CofG of the
aircraft, an aircraft will always pitch down.
regards,
Mike
arget=_blank>http://www.matronics.com/Navigator?Europa-List
p://forums.matronics.com
See what you’re getting into…before you go there. Check it out!
<http://newlivehotmail.com>
Graham Singleton
Tel: +441629820187
Mob: +447739582005
Posted: Sun Jul 15, 2007 4:36 pm Post subject: Europa Tailplane - Mod 73 |
Graham,
I could be wrong, but I don't agree. I think I can control the heat
precisely to a localized area and not damage any foam.
Karl
| Quote: | From: Graham Singleton <grahamsingleton(at)btinternet.com>
Date: Mon, 16 Jul 2007 01:11:29 +0100
Karl
you might get the TP5 out with heat but the TP6 is not so easy. Even after
it is loose from the end rib you then have to get it inserted into the root
The heat to loosen it from the end rib will almost certainly melt the foam
Graham
Karl Heindl wrote:
>Jeff,
>Karl
Posted: Mon Jul 16, 2007 12:01 am Post subject: Europa Tailplane - Mod 73 |
Karl
IMHO You are dicing with trouble!
You will find that One of the main problems will be that the foam will
expand considerably where the heat is (the rest of the unheated foam
acts as a thermal insulator ) so you will get differential expansion on
a grand scale meaning considerable buckling. Been there done that!
The only chance of applying any heat anywhere will be by gradual heat
sink over many hours and over the whole item and then similarly cooling
over many hours as post curing was required on the original build.
Bob Harrison G-PTAG
Posted: Mon Jul 16, 2007 3:59 am Post subject: Europa Tailplane - Mod 73 |
Hi Bob,
Thanks for the warning. But, a) I have no intention of doing anything to my
tailplanes for quite a while, while all the dust settles. I am quite happy
with my tailplane retention the way it is right now.
b) I would have no problem heating the TP6 gradually with precise
temperature control, and in any case I would do a trial run on a separate
prepared piece of foam.
Now Fred Klein wants to implement another good mod, but I think the PFA has
already stated that pre-skinned tailplanes are not affected.
Karl
[quote]From: "R.C.Harrison" <ptag.dev(at)tiscali.co.uk>
Subject: RE: Europa Tailplane - Mod 73
Date: Mon, 16 Jul 2007 08:59:23 +0100
Karl
Bob Harrison G-PTAG
Posted: Mon Jul 16, 2007 8:17 am Post subject: Europa Tailplane - Mod 73 |
Hard to believe that, Karl. You will still have difficulty with the TP6,
getting it entered into the TP5 hole
Graham
Karl Heindl wrote:
Graham,
Karl
willie.harrison(at)tinyon Guest
Posted: Mon Jul 16, 2007 8:37 am Post subject: Europa Tailplane - Mod 73 |
Roger at the Factory confirmed that Jeremy is correct.
On 16 Jul 2007, at 13:31, Jeremy Davey wrote:
<europaflyer_3(at)msn.com>
Karl,
Sorry to differ, but I believe that's not so. Pre-skinned
tailplanes ARE
affected - the only ones that are possibly not affected are the pre-
moulded
ones, and to the best of my knowledge there are only two sets of
those: on
Peter Kember's new bird, and on the old factory demonstrator G-GBXS.
Has anyone come up with a reason for overlapping the lower skin
instead of
using a flox corner yet?
nigel_graham(at)btclick.c Guest
Karl
I think that when the cause is eventually discovered - it will be found to
be a combination of two or more conditions that individually, would not
cause a problem.
One Pip-Pin was found to be bent through 90 degrees, implying that one
tailplane did rotate and that TP4 remained in place. I would guess that the
TP6 remained firmly anchored to the torque tube by the pin and the rest of
the structure broke loose and rotated around it.
A few years back I witnessed a formula one fatal at Reno, right in front of
our grandstand. The aircraft suffered a tailplane flutter which resulted in
four or five violent pitch up/down cycles before the tail broke free and the
aircraft pitched into the ground. The whole incident probably took no more
than 2.5 seconds from start to sad end. The torsional load on the main wing
spars must have been phenomenal and it would be easy to understand how a
main plane could fail following a tailplane flutter.
With regard to suitable repairs. I have thought long and hard about this
(and so are the guys at the PFA) and the truth is that there is no quick
fix. Regardless of whatever method is devised to locate the tail laterally,
the fact remains that a disbonded TP5 and TP6 will prevent the tailplane
locating accurately on TP4 - and this must be addressed.
The Mod 73 Pip-pin reinforcement is a good short term fix (the sticking
plaster).
To retro-fit the tailplane mod would require that the entire tailplane be
dismantled and rebuilt .....possible, but by no means easy.
In my opinion it would be easier to build new tailplanes (and if I was in
this predicament, this would be my chosen course of action).
I quite enjoyed building mine and it didn't take that long.
How about someone (Europa 2004?) producing new tail kits (Tailplanes only)
and offer these to existing Europa owners at cost plus. I reckon they could
be produced for around £400-£500 GPB ($800-$1000 USD) plus shipping. It's an
idea to keep the discussion rolling......
Nigel
Posted: Mon Jul 16, 2007 9:46 am Post subject: Europa Tailplane - Mod 73 |
Is there anything special about the TP5 hole ? The TP5 would be removed
first, obviously.
Karl
Date: Mon, 16 Jul 2007 17:18:01 +0100
Graham
Karl Heindl wrote:
>Graham,
>Karl
Posted: Mon Jul 16, 2007 10:02 am Post subject: Europa Tailplane - Mod 73 |
Glenn
the Europa airfoil as designed has a bit of reflex in the trailing edge
but you need to check the computer printout to see it.
Graham
| Quote: | All non symmetrical airfoils that do not have reflex in the trailing
edge have a negative CM (pitching moment).
Glenn
Posted: Mon Jul 16, 2007 3:29 pm Post subject: Europa Tailplane - Mod 73 |
No but its a tight fit on the bush, TP5 o6 TP6. How do you persuade it
to start down the hole from the inside?
Graham
Karl Heindl wrote:
first, obviously.
Karl
Posted: Mon Jul 16, 2007 4:26 pm Post subject: Europa Tailplane - Mod 73 |
Graham,
Not sure what you mean by the bush.
Disregarding the heat application for the time being, I would have a 1.5"
alu tube inside the TP6.
Then I would drill a small hole near the pip pin hole through the TP6 and
into the tube for a small self-tapping screw or rivet, if there is space for
a rivet tool in the recess. Assuming, the TP6 is now loose, I take hold of
the tube end at the root and slowly pull the thing out with a turning
motion.
The screw head (unless it is countersunk) will cut a fine spiralshaped
groove into the foam, but that is hardly a problem, because I would line the
hole with floxed redux anyway before inserting the new part. Does that make
sense so far ?
Actually, the screw would already be in before I start the heat application,
because the TP6 needs to be turned once the adhesive starts to soften, and
would have to keep turning while the adhesive cools down again before
extraction.
Karl
Date: Tue, 17 Jul 2007 00:32:32 +0100
No but its a tight fit on the bush, TP5 o6 TP6. How do you persuade it to
Graham
>first, obviously.
>Karl
Tell MSN about your most memorable emails! http://www.emailbritain.co.uk/
Posted: Mon Jul 16, 2007 9:30 pm Post subject: Europa Tailplane - Mod 73 |
Nigel,
Unpopular as it may be, I think you are right. Mod 73 strikes me as a very
unsatisfactory fix for a poor design. What I would like to see is a new set
of tailplanes with a redesigned torque shaft and retention system. A 'belt
and braces' system that will make all this uncertainty go away. We all love
our little aeroplanes, but it must be made more rugged down the back. At
the moment the whole situation concerns me greatly and my confidence in the
integrity of the aircraft has taken a severe knock with the loss of G-HOFC
and our friends. Accidents caused by pilot error I can live with, but
structural failure I cannot. I want to be able to relax when I fly my
Europa.
Europa 2004 can put on the list now for a new set of tailplanes if the
re-design can restore my confidence in my aircraft.
regards,
Mike
| Quote: | How about someone (Europa 2004?) producing new tail kits (Tailplanes only)
could
an
Nigel
