richard(at)scarrhillalpac Guest
Posted: Sat Jul 14, 2007 9:45 am Post subject: Started Mod 73 |
All
Starting the mod 73, as my tail planes are still in the workshop and not filled or painted; In I went with the knife.
I have found that the TP6 bush measures at 50mm from the face of the inboard side of the outboard rib. This puts it 10mm inboard more than the, instructions on the Mod 73 paper work, in turn will make the span wise diameter 60mm instead of the described 50mm.
Before I continue, I ask is anyone finding the same measurements?
I have checked the first instillation of the TP6 from the manual and I fine it is as it should be.
Thank You
Richard Wheelwright.
Visit - www.EuropaOwners.org
ami(at)mcfadyean.freeserv Guest
Posted: Sat Jul 14, 2007 11:47 pm Post subject: Started Mod 73 |
Maybe you were supplied originally with two sets of TP5's, which are longer?
Duncan McF
carl(at)flyers.freeserve. Guest
Posted: Sun Jul 15, 2007 1:31 am Post subject: Started Mod 73 |
Mine certainly arent (cut at an angle).
Carl
G-LABS
