carl(at)flyers.freeserve. Guest
Posted: Sat Jul 14, 2007 6:06 am Post subject: Europa Tailplane - Mod 73 |
Im not sure your mod would have prevented Williams accident.
I believe his kit would have been purchased in 1994 and was finished in
1995.
sidsel.svein(at)oslo.onli Guest
Posted: Sat Jul 14, 2007 6:56 am Post subject: Europa Tailplane - Mod 73 |
While there may be doubt whether the shallow lip on the inside of TP6 will be adequate as a tailplane retention, it is worth reading EA2004's reasoning behind Mod 73 carefully: Retention of the tailplane by TP6 (and the pip pin securing TP6 to the torque tube) AND a secondary retention by the pip pin and its surrounding composite structure alone, should the primary retention not hold. The mod is therefore as much a strengthening of the structure around the pip pin and a proper transfer of forces acting on the pip pin into the tailplane skin, as it is a mod for better bonding of TP6 to the tailplane.
This is the reason why the instructions make a point of not removing any bid/epoxy around the hole on the underside, in the event the pip pin ball should not open on the underside of the new layup, but instead buy a longer pip pin. Removing bid/epoxy here would defeat that secondary retention function of the mod.
As I understand it, this view is also reflected in FSB-006 Issue 3 section 5: Mod 73 need to be done if the upper pip pin recess does not satisfy the stated requirements. I think, however, that PFA ought to have required ovalization of the torque tube holes even if Mod 73 may be omitted if the requirements of Section 5 are complied with -ovalization should be done in any event, I think.
Svein
LN-SKJ
willie.harrison(at)tinyon Guest
Posted: Sat Jul 14, 2007 7:02 am Post subject: Europa Tailplane - Mod 73 |
I have heard that there are still doubts in the AAIB investigation
about whether the initial failure was the wing pin (with
consequential failure of the tail) or the other way around. Hence we
are being required to cover both hypotheses by mods and checks front
and back.
If it was indeed the wing pin which failed first - very big "if" -
then the implication is that the tail could/would have then failed
because it was subject to loads it had never been designed for
(perhaps a sudden pitch or roll or yaw?) , and not because there was
anything wrong with it - it would have been a consequential event,
not a causal one. You might also feel that if the wing pin had failed
then the aircraft may have been doomed whether or not the tail broke
up. If this is true then perhaps neither mod 73 nor Nigel's mod
would have saved the day.
A supporting thought to this hypothesis is that the build quality
around the wing pin on the crash aircraft is known to have been poor.
Also, the aircraft is known to have been returning from a Permit
inspection when the wings would have been removed and replaced.
Perhaps in refitting the wing, some damage was done to the already
compromised wing pin?
Just a thought.
Willie Harrison
On 14 Jul 2007, at 15:05, Carl Pattinson wrote:
<carl(at)flyers.freeserve.co.uk>
finished in 1995.
gcrowder2
Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
Posted: Sat Jul 14, 2007 7:40 am Post subject: Europa Tailplane - Mod 73 |
I wonder about the integrity of the elevator mass balance in the accident aircraft. If the
mass balance had become disengaged for any reason, then the slightest disturbance in pitch
could cause the elevator to become uncontrollable. This would be consistent with the report
of wild pitch excursions initially prior to the tail departing.
Glenn
[quote] From: willie.harrison(at)tinyonline.co.uk
Subject: Re: Europa Tailplane - Mod 73
Date: Sat, 14 Jul 2007 16:01:35 +0100
--> Europa-List message posted by: William Harrison <willie.harrison(at)tinyonline.co.uk>
and back.
Just a thought.
Willie Harrison
> --> Europa-List message posted by: "Carl Pattinson"
> finished in 1995.
kheindl(at)msn.com Guest
Posted: Sat Jul 14, 2007 8:45 am Post subject: Europa Tailplane - Mod 73 |
aircraft. If the
I am not so sure about the above. A failing mass balance would have the same
effect as pushing the stick forward. The pilot would instinctively pull back
the stick and regain level flight. Maximum trim would then reduce that load
a little, but there should be no real problem in maintaining ccordinated
flight with the stick held back.
Karl
Glenn> From:
willie.harrison(at)tinyonline.co.uk> Subject: Re: Europa
Tailplane - Mod 73> Date: Sat, 14 Jul 2007 16:01:35 +0100> To:
europa-list(at)matronics.com> >
Harrison <willie.harrison(at)tinyonline.co.uk>> > I have heard that there are
still doubts in the AAIB investigation > about whether the initial failure
was the wing pin (with > consequential failure of the tail) or the other
way around. Hence we > are being required to cover both hypotheses by mods
and checks front > and back.> > If it was indeed the wing pin which failed
first - very big "if" - > then the implication is that the tail could/would
have then failed > because it was subject to loads it had never been
designed for > (perhaps a sudden pitch or roll or yaw?) , and not because
there was > anything wrong with it - it would have been a consequential
event, > not a causal one. You might also feel that if the wing pin had
failed > then the aircraft may have been doomed whether or not the tail
broke > up. If this is true then perhaps neither mod 73 nor Nigel's mod >
would have saved the day.> > A supporting thought to this hypothesis is
that the build quality > around the wing pin on the crash aircraft is known
to have been poor. > Also, the aircraft is known to have been returning
from a Permit > inspection when the wings would have been removed and
replaced. > Perhaps in refitting the wing, some damage was done to the
already > compromised wing pin?> > Just a thought.> > Willie Harrison> > >
> On 14 Jul 2007, at 15:05, Carl Pattinson wrote:> > > --> Europa-List
message posted by: "Carl Pattinson" > > <carl(at)flyers.freeserve.co.uk>> >> >
Im not sure your mod would have prevented Williams accident.> >> > I
believe his kit would have been purchased in 1994 and was > > finished in
1995.> >> >> > ---
Posted: Sat Jul 14, 2007 8:52 am Post subject: Europa Tailplane - Mod 73 |
Can anyone explain to me how the tailplane can possibly move outward by even
a millimeter when the pip pin head is resting firmly against a solid wall on
the inboard side, whether this is epoxy, glass, wood or anything else ?
Where are these huge forces that would pull this pin sideways through the
surrounding foam body ? Is a loose TP6 really such a big problem, apart from
making it difficult if not impossible to rig the tailplane ?
Karl
| Quote: | From: "Sidsel & Svein Johnsen" <sidsel.svein(at)oslo.online.no>
Reply-To: europa-list(at)matronics.com
To: <europa-list(at)matronics.com>
Date: Sat, 14 Jul 2007 16:54:16 +0200
14 Hantone HillWhile there may be doubt whether the shallow lip on the
any event, I think.
Svein
LN-SKJ
Tell Hotmail about an email that changed your life!
http://www.emailbritain.co.uk/
riddon(at)sent.com Guest
Posted: Sat Jul 14, 2007 9:14 am Post subject: Europa Tailplane - Mod 73 |
Nigel,
Can you tell me where I can find details of mod 10672 as I can’t locate it on the Europa Aircraft web site?
Richard Iddon G-RIXS
13/07/2007 15:41
13/07/2007 15:41
josok-e(at)ukolo.fi Guest
Posted: Sat Jul 14, 2007 9:58 am Post subject: Europa Tailplane - Mod 73 |
Hi Richsrd,
http://www.europaclub.org.uk/mods/improved_tp5_and_tp6_sleeve_retention.shtml
Europa club pages,
Jos Okhuijsen
Visit - www.EuropaOwners.org
nicolaprice(at)tiscali.co Guest
Posted: Sat Jul 14, 2007 10:00 am Post subject: Europa Tailplane - Mod 73 |
Its on the Europa club website builders pages I think.
Thanks for the what ' to look for' Nigel.
John Price.
gcrowder2
Posted: Sat Jul 14, 2007 12:39 pm Post subject: Europa Tailplane - Mod 73 |
Yeah, I got that but without mass balancing, the elevator could tend to slam up or down
to the stops, possibly ripping the stick out of the pilots hands. One or two oscillations of
this sort and the tail would come off for sure.
Glenn
[quote] From: kheindl(at)msn.com
Subject: RE: Europa Tailplane - Mod 73
Date: Sat, 14 Jul 2007 17:43:49 +0100
--> Europa-List message posted by: "Karl Heindl" <kheindl(at)msn.com>
>aircraft. If the
Karl
> Glenn> From:
>europa-list(at)matronics.com> > --> Europa-List message posted by: William
>1995.> >> >> > ---
Posted: Sat Jul 14, 2007 1:58 pm Post subject: Europa Tailplane - Mod 73 |
What I still don't understand is that the wings came off and from the
information to date there was not enough speed to pull the wings off.
Incomplete information it would appear. Wings should not fail at any
speed less than about 125 knots? That's what max rough air speed means.
Graham
glenn crowder wrote:
| Quote: | Yeah, I got that but without mass balancing, the elevator could tend
to slam up or down
Glenn
gcrowder2
Posted: Sat Jul 14, 2007 3:59 pm Post subject: Europa Tailplane - Mod 73 |
Once the tailplane(s) departed, the wing by itself has a negative pitching moment. Once the
main wing heads down with nothing to stop it, would normally tend to pitch all the way under, which would certainly break the wing attachments.
Glenn
| Quote: | Date: Sat, 14 Jul 2007 23:01:30 +0100
--> Europa-List message posted by: Graham Singleton <grahamsingleton(at)btinternet.com>
Graham
> to slam up or down
PC Magazine’s 2007 editors’ choice for best web mail—award-winning Windows Live&ocid=TXT_TAGHM_migration_HMWL_mini_pcmag_0707' target='_new'>Check it out! [quote][b]
mikenjulie.parkin(at)btin Guest
Posted: Sat Jul 14, 2007 4:45 pm Post subject: Europa Tailplane - Mod 73 |
Glenn,
I am not so sure about that statement. As one accellerates, more nose down trim is required - standard in any aeroplane. That implies that if the tailplane was taken out of the equation, the aircraft would pitch up - not down. Aerodynamicists, am I missing something here??
regards,
gcrowder2
Posted: Sat Jul 14, 2007 7:05 pm Post subject: Europa Tailplane - Mod 73 |
Yes, but trimming nose down is done to lower the angle of attack of the wing, and
thus lower the induced drag, allowing a higher airspeed. It is still pushing down, just not
as much as at lower speeds.
All non symmetrical airfoils that do not have reflex in the trailing edge have a negative CM (pitching moment). This is why the tail is necessary in the first place. The tailplane provides a downforce that balances the negative pitching moment of the wing. In a flying wing design, there is a necessity for more washout at the tips and/or reflex in the trailing edge of the wing to counteract the negative CM of the wing (effectively adding downforce at the tail).
Without the tail, the wing will rotate nose down and then tuck under.
Glenn
Date: Sun, 15 Jul 2007 01:43:10 +0100
.ExternalClass P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass {font-size:10pt;font-family:Tahoma;}
[quote] Glenn,
regards,
DuaneFamly(at)aol.com Guest
Posted: Sat Jul 14, 2007 9:59 pm Post subject: Europa Tailplane - Mod 73 |
To All,
Was I imagining what I read about the accident? Wasn't flutter mentioned as part of the failure equation? If high frequency flutter occurred in flight, might that have caused, maybe, the debonding of the TP6 sleeve. Then the same high frequency flutter of the tailplane might have allowed the tailplane to "walk" on the torque tube. It could only go in one direction, outboard, and would not have to go very far before TP13 drive pins disengaged. Once disengaged, what would the tailplane behave like? Would the flutter drive the tailplane up and down so quickly without the mass balance weight as to cause the tailplane to fail? Or could the aerodynamics from the loose tailplane force the tail up, with the pilot countering this force with the other tailplane? Would it equalize to a controllable point while in flight? A question for the investigators, "Was the pip pin still in it's hole in the torque tube?"
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300
Sensenich R64Z N
Ground Adjustable Prop
Get a sneak peak of the all-new AOL.com.
Posted: Sun Jul 15, 2007 1:01 am Post subject: Europa Tailplane - Mod 73 |
I accept what you say about CM about the aerodynamic centre for an aerofoil. But are you saying that irrespective of the CofG of the aircraft, an aircraft will always pitch down.
regards,
nigel_graham(at)btconnect Guest
Posted: Sun Jul 15, 2007 1:44 am Post subject: Europa Tailplane - Mod 73 |
Posted: Sun Jul 15, 2007 5:51 am Post subject: Europa Tailplane - Mod 73 |
Nigel,
I understand all that and your mod should have been made standard a long
time ago. But what about older Europas ? We hear reports about disbonded
TP6s but we don't hear how they were repaired. I really would like to know.
A suitable retrofit mod should also have been made available as soon as this
problem was known.
I still say that there is no way the tailplane can move if the pip pin head
is firmly against solid material on the inboard side. You say there is
always a gap, but that gap is filled with floxed epoxy, and the head is
inside a close fitting plastic pipe in my case. I think another builder
recently told us about a similar mod he made. The remaining space around the
pipe is also filled with epoxy. Of course all these solutions are based on
theory and only a lab test could verify the claims.
When my TP5s disbonded from trailering I was kicking myself for not having
installed a one-piece pipe, but in those early days I was very careful to
follow the build instructions precisely. I stll think that a retrofit of a
one-piece sleeve would be more than strong enough to prevent any future
disbonding, and would be a relatively easy solution where the TP6s have
already disbonded.
As far as the accident goes, we still don't have any real conclusive
evidence about the sequence of events. Only a number of theories. Only a
wind tunnel test would verify the flutter theory, but who is going to pay
for that ? Eyewitness reports can be very misleading.
If the wing trailing edge pin came off first, is it possible that the pilot
was getting set up for landing and deploying flaps and undercarriage ?
I also like the other suggested solutions where a lock is put behind the
TP12
Karl
Karl,
I have attached below, an excerpt of a long mail I sent to the PFA that
describes a sequence of events that could lead to the tailplain moving
outboard. Out of interest, there is always a gap between the pip-pin and
the
face of the rib.
This was sent before the current Mod 73 was issued, but you will see why
the
temporary remedial action has been to reinforce the pip-pin hole.
Nigel
Excerpt
...... The only thing preventing each tailplane moving sideways is a single
pip-pin that passes through the TP6 bush and into the TP4 torque tube. (See
Fig.5 Chap 4)
The design relies on a good bond to hold TP6 in place, however only the
protruding outer 12mm (just 8mm on TP5) is required to bond to the
tailplane
rib that will subsequently be laid-up onto it. Epoxy adhesive does not bond
well to stainless steel - so the potential for this bondline to fail is
great.
This tiny bondline is the only "design" load path to prevent the tailplane
moving laterally. If the bond failed, the loose TP6 bush would tend to push
its way inboard into the soft blue foam, allowing the tailplane to move
outboard. The TP5 bush would offer no resistance since it would simply
slide
along the TP4 torque tube.
In some early Europas, this TP6 bush has de-bonded and it is only the
laminations into the "PipPin" access hole that prevent any lateral movement
of the tail-plane. This lamination was never intended to be structural. If
the aircraft is high-time and habitually operated off rough strips, it is
logical to predict that the continual fretting would cause the glass around
the pip-pin hole to chafe, opening up the hole to a point where the whole
tailplane could slide far enough laterally to allow the tail-pane drive
pins
(TP12) to disengage from their drive bushes (TP13) - The tailplane would
then oscillate violently with catastrophic results.
Modification 10672) calls for both the Stainless TP5 and TP6 bushes to be
laminated into an epoxy/Bi-Directional Glass tube before inserting this
into
the tailplane TP2 cores and laminating the ribs. This bonds both bushes
over
their entire surface area, significantly increasing the bond area and more
importantly, physically tying TP5 with TP6 and both the inner and outer
ribs
together. With this structure, the entire bond surface area and both ribs
would have to fail before the tailplane could move sideways.
The loadpath is through the mod 10672 and not through the outer skin and
pip-pin hole - a significantly better engineering solution.
Watch all 9 Live Earth concerts live on MSN. http://liveearth.uk.msn.com
Posted: Sun Jul 15, 2007 6:43 am Post subject: Europa Tailplane - Mod 73 |
The only "solid" material on the inboard side is 2 plies of bid comprising
the pip pin recess (and a bit of foam!!!) . That is why the PFA have been so
specific as to what is considered acceptable or not.
The tailplane rib is on the outboard side of the pip pin recess and would
provide no suport to a disbonded TP6.
You say that the pip pin head is located against "solid material" but what
is that solid material anchored to? If it isnt anchored to the tailplane
surface or to the outboard tailplane rib then it isnt anchored to anything !
I suspect the current mod 73 will prove to be no more than a temporary
solution and a more robust mod will follow in due course.
There would seem to be several retrofit solutions to this problem and
ultimately it is up to the PFA to decide which will be best in the long
term.
Whilst I agree this problem should have been addressed a long time ago, the
fact is that many Europas have flown many hours without incident. This
would suggest the problem is not as dire as we all think it is. I suspect
that 99% of Europas are flying around with secure tailplanes but in the
absence of definitive proof one has to assume the worst.
We are also assuming that a disbonded TP5 contributed towards Williams
accident. So far however there is no definitive evidence to support such an
assumption (in the public domain at least).
Carl (with a C !)
G-LABS
gcrowder2
Posted: Sun Jul 15, 2007 7:33 am Post subject: Europa Tailplane - Mod 73 |
Hi Mike - yes the aircraft will always pitch down with a non symmetrical airfoil. This is why
aerobatic aircraft are designed with symmetrical airfoils - zero pitching moment.
Aerobatic pilots don't like their aircraft pitching without their command!
Also, in the accident aircraft, losing the tailplane suddenly removed 20 lbs of weight off the
tail, pitching the nose down further.
If you've ever flown a C-172 while lowering the flaps you will probably remember the
pitch down. Actually, it balloons up first while speed is being lost, then pitches down.
The wing is now very non-symmetrical, requiring up trim on the elevator to
balance the increased negative CM. The Europa does this too but not as noticeable,
probably because of the powerful tail.
Glenn
| Quote: | From: mikenjulie.parkin(at)btinternet.com
Date: Sun, 15 Jul 2007 10:01:17 +0100
.ExternalClass P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass {font-size:10pt;font-family:Tahoma;} I accept what you say about CM about the aerodynamic centre for an aerofoil. But are you saying that irrespective of the CofG of the aircraft, an aircraft will always pitch down.
regards,
| See what you’re getting into…before you go there. Check it out! [quote][b]
