JetPilot
Posted: Thu Jul 12, 2007 8:23 pm Post subject: Kolb Rigging - Flaps and Ailerons |
I have a MK-III Extra with seperate ailerons and flaps. I been doing some adjusting of my flaps and ailerons to try to find the best way to rig them. It seems to me that the bottom of each being flat with the wing in flight would be best combination of speed and low speed capability, but that is just a guess. Maybe having them droop just a bit would help my slow speed handling without hurting my cruise speed to much...
What have you guys found ?? Anyone done any testing having the flaps and ailerons rigged slightly up or down, and what is your favorite way to rig your Kolb ?
MK III Xtra 912-S
231.21 KB |
379 Time(s) |
Kolb MK-III Xtra, 912-S |
