pinkston(at)carolina.rr.c Guest
Posted: Tue Jul 10, 2007 4:01 pm Post subject: carbon rudder |
rudder is to far done to back up now ,,,maybe carbon down the road but not now,,…..,how much is to much weight to have to add past the 4.5 lbs in the book to bal it? Or does it matter ???? rp
| - The Matronics Glasair-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
Craymondw(at)aol.com Guest
Posted: Tue Jul 10, 2007 7:56 pm Post subject: carbon rudder |
When you take into consideration all the planes not flying with counter weighted rudders. I don't have mine weighted with five pounds and I have had my plane in speeds up to 260 mph in high speed passes.
See what's free at AOL.com.
lists(at)stevet.net Guest
Posted: Wed Jul 11, 2007 6:35 am Post subject: carbon rudder |
It all depends on how much risk you want to assume in your test flying phase. Glasair Aviation has flight tested and proven their design. The 4.5 lbs. of counterweight is known to work. However, the construction is up to you. Just know that any changes you make to these balance considerations are on your head to demonstrate flight-worthiness. The previous poster has said that he reduced the balance weight and has had good success. You may or may not. Do you want the added risk of flutter to all the other issues you will face on test flying your airplane? Your call.
Best Regards,
Steve
____________________________________________________________________
Posted: Wed Jul 11, 2007 7:11 am Post subject: carbon rudder |
Because they didn't not want to do so, I know that some builders were not able to cram in the 4.5 pounds of weight suggested. I was one of them.
