air.peter(at)googlemail.c Guest
Posted: Sun Jul 08, 2007 2:09 pm Post subject: Mag and Lightspeed ignition grounding |
Hello all,
I am wiring my panel and actually the ignition switch, contacting the mag and the Lightspeed to the latter.
My question is the following: As to my best knowledge the shield from the Mag wire should not be contacted with ground at the switch, the shield from the Lightspeed cable will be contacted to ground at the switch. Is this working (long term), as the Mag will be shortened with the ground from the Lightspeed ?
Or may I contact the ground from the mag together with the ground from the Lightspeed (ground loop !) ?
Thanks for your help
Peter Lancair 360 (85%)
