96victor(at)gmail.com Guest
Posted: Tue Feb 14, 2006 2:53 pm Post subject: Flap Washout |
Mine did the same thing. I couldn't figure out why it changed as it cured.
It was easy to weight it back to 1.4 degrees and do the upper surface.
Tom Friedland
On 2/14/06, Flying Farmer <funnyphone(at)btinternet.com> wrote:
Advice Needed
I just want to check something, before I get it wrong. Im setting
up the Flaps for the second skin lay-up, Top surface. When I did the first
surface, Bottom skin, I set the washout to 1.4o as described in the
manual, as I have a digital level it makes this operation easy. Now setting
up the Flaps for the top skin, Im checking the washout again, as before; I
find there is a large variation. My level is reading 2.2o, so my question
is, Should I still set this up for the washout as 1.4o? My own answer is
it should be set to 1.4o. But I would like some advice from those who have
been here before. Also any other tips.
Thank You.
flyinggpa(at)comcast.net Guest
Posted: Tue Feb 14, 2006 3:56 pm Post subject: Flap Washout |
As I recall, I too had that problem. I used lots of double sided tape to hold the bottom side tight in the foam blocks. I really think they will work even if you get them off a little. Try your hardest to get them right and keep building.
Have fun.
Cliff Shaw
1041 Euclid ave.
Edmonds, WA 98020
425 776 5555
http://www.europaowners.org/WileE
Dave Miller
Posted: Wed Feb 15, 2006 5:25 am Post subject: Flap Washout |
Just make sure when using the Smart level that you are not as dumb as me.
I couldn't figure out why the degrees of travel had changed on my
tailplane till I finally realised that I had hit the button and changed
the scale from degrees to percentage slope.
Dave A061
"Flying Farmer" <funnyphone(at)btinternet.com>
Sent by: owner-europa-list-server(at)matronics.com
02/14/2006 04:49 PM
Please respond to europa-list
To:
cc:
Subject: Flap Washout
Advice Needed
setting up the Flaps for the top skin, Im checking the washout again, as
before; I find there is a large variation. My level is reading 2.2o, so my
question is, Should I still set this up for the washout as 1.4o? My own
answer is it should be set to 1.4o. But I would like some advice from
those who have been here before. Also any other tips.
Thank You.
