		VE3LVO(at)rac.ca Guest
				 Posted: Tue Feb 14, 2006 12:48 pm    Post subject: Confessions of an amateur |
				Cheers,
             Having heaped upon you the moaning of a frustrated builder, I
 now beg you to follow some recalled events in the last two days. If you
 don't wish to share the info (because you're now well ahead of me and don't
 want the aggravation), leave this to those who be still be behind.
             Thinking the making of wings and tail were landmarks, I
 concluded early that the hanging of the engine was a one-morning job. Wrong.
             I modified the footwells to accomodate the Wilksch and so the
 firewall didn't fit properly and I've finally overcome that irregularity.
 The next challenge came from the book which said,  "don't put the
 intermediate frame on the 'plane and then try to hang the engine on it. Put
 the frame on the engine and then hang them both on the gear frame." That
 screwed me first because the lower firewall so carefully prepared by Graham
 Singleton actually covers both the gear- and intermediate frames so would
 have to be fitted with the engine already hung. No.
             Then came the info from helpful net buddies that one needs to
 produce slightly longer bolts in order to cinch up the Lord rubber mounts so
 that the AN5-41 bolts could be joined by a nut. I have circumvented that by
 fabricating 1-15/16" clamps to hold the Lords till I can thread a -41 into
 them.
             However, then came the challenge to 'cant' the engine 1-1/2deg
 to starboard per the book. Oh,oh. My carefully cinched up bolts left the
 engine out by slightly less than 3/4 degree. The shim washers - MS24665-516L
 are  a measured 0.030" each and would require 4 to right thew wrong - top
 and bottom.  In spite of the book admonition to include 4 washers everywhere
 (to accomodate the cotter pin positionning in the castellated nut) the fact
 is that with no washers in the starboard side, the cotter pin fits perfectly
 in the base of the nut slot - whereas the port pair with their 4 shim
 washers now render the -41 bolt too short for a cotter pin!
             Yes, in all instances the bolts are cinched up to hard metal
 stops, so no more bolt can be revealed. In addition, be prepared to wheeze
 and sweat to instal the bottom port bolt facing forward down amongst a
 forest of frame elements asf.
             So, thankfully I have emerged from the guts of the wheelwell and
 minus the longer bolts, have turned to fuel pump matters for comic relief
 while I contemplate where the nearest AN5-42 is. Nor can I say that you
 should go through this because it may have been a glitch in the production
 line - but I suggest if you're at this juncture, measure the length of the
 frame holes plus maybe a couple of shim washers and see if the requisite
 length of bolt provided satisfies the need. I should have done that.
             ....just another rant.........
 Ferg
		flyinggpa(at)comcast.net Guest
