gus.fraser(at)gs.com Guest
Posted: Tue Feb 14, 2006 12:51 pm Post subject: Yak-List:[feedback] 4340 Alloy steel sheet needed. [feedback |
Well folks I have had great help in my search. Scott, thanks for introducing me to the truly remarkable www.matweb.com , all and more that you need to know about all kinds of materials. The best bit is the search engine. I put in the specific properties that I needed for the 4340 and it gave me a recipe for 4140 that does the same thing, awesome.
Also I found the following http://www.russelmetals.com/pdf/english/service/pdf_catalogue/Section_14_-_Weights_and_Useful_Data.pdf which is a 26 page guide great to keep in the hanger.
Suggestions on the best way to heat to just over 1575 deg F welcome.
Gus
[quote] From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Fraser, Gus
Sent: Tuesday, February 14, 2006 1:18 PM
To: 'yak-list(at)matronics.com'
Subject: RE: 4340 Alloy steel sheet needed.
Dennis,
Thanks for that I called them yesterday and they only have larger sizes available. .1 and up. For reference this is the steel used for undercarriage units also.
Thanks again
Gus
[quote] From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Tuesday, February 14, 2006 12:57 PM
To: yak-list(at)matronics.com
Subject: Re: 4340 Alloy steel sheet needed.
See if these folks can help.
http://www.advancedglobalmaterials.com/4130-4340sheet.asp
Dennis
Alloy Steels
4340Mod
4620
4720
6150
8620
8740
9310
52100
H11
HY60 - 100
D6AC
HP 9 - 4 - 20
300M
HP 9 - 4 - 30
D6-AC
HY - TUF
Maxel 3 1/2
Maraging 250, 300, 350
Aircraft Quality & Vacuum Melted
*All materials available in the following:
Plate, Sheet, Rod, Bar, Tubing, Pipe, Wire, Forgings, Custom Shapes & Sizes
