fklein(at)orcasonline.com Guest
Posted: Sun Jul 01, 2007 9:43 am Post subject: Fuel venting |
I understand that some builders have vented the tank and the sight
gauge to the top of the fuel filler pipe, taking care that the precise
location will not allow fuel being added to inadvertantly flow into the
vents. What I don't understand is...using the supplied fuel filler cap
(which is specifically called out as "non-venting", again in the ACS
catalogue)...how such an arrangement in fact can act to vent the fuel
system.
Can anyone enlighten me?
Fred
Ivor Phillips
Posted: Sun Jul 01, 2007 10:55 am Post subject: Fuel venting |
Hi Fred
I used a vent valve TRV86 in the top of the filler with a AN fitting
taken down to just forward of the flap tube,
http://www.thinkauto.com/
information on web site
sent photo's direct!
regards
Ivor
johnwigney(at)alltel.net Guest
Posted: Mon Jul 02, 2007 6:09 am Post subject: Fuel venting |
Hi Fred,
I vented the tank to the neck since I was unhappy with the standard vent
arrangement. The main problem I found was that the vent tube from the
tank was too small and caused the fill pipe to back up and burp at low
fill rates from a hose. The vent pipe also vented fuel onto the top of
the fuselage. The changes I made have worked out well and consist of the
following steps :-
* Modified the vent fitting at the tank so that I could use a larger
vent tube size (clear plastic tubing with fabric reinforcement,
3/8" dia I think. I can check if you wish).
* Installed a tee fitting at the top neck of the filler. This was
bonded into place with Redux.
* The center leg of the tee is connected into the filler neck which
was drilled to suit. One other leg is connected to the tank vent
tubing and the third leg is sized for the original small tubing
and goes directly to the vent on the fuselage top.
* Another feature which helps during filling is that I have a 2"
section in the middle of the fuel down pipe which is left
unpainted. This makes it easy to check filling progress. I can now
fill at basically the full flow rate and I do not get any fuel
vented onto the fuselage top.
I do not use a sight gauge arrangement. I have two capacitance fuel
gauges plus my Grand Rapids EIS flowmeter and totaliser.
Cheers, John
N262WF, mono XS, 912S
Mooresville, North Carolina
ORIGINAL MESSAGE
Subject: Fuel venting
system.
Fred
topglock(at)cox.net Guest
Posted: Mon Jul 02, 2007 7:16 am Post subject: Fuel venting |
Fred,
My aircraft is vented, per the manuel, with one deviation. I added a
"T" at the top of the filler tube, that allows fuel to spill out into
the filler neck, before reaching the top of the aircraft. Keeps gas
from spilling out on my paint.
Jeff - Baby Blue
300+ hours and in for 2nd annual...
Fred Klein wrote:
the vents. What I don't understand is...using the supplied fuel filler
cap (which is specifically called out as "non-venting", again in the
ACS catalogue)...how such an arrangement in fact can act to vent the
fuel system.
Fred
s.vestuti(at)virgin.net Guest
Posted: Mon Jul 02, 2007 1:13 pm Post subject: Fuel venting |
Hi John , i notice that you are still using the vent in the fuselage top, so, are you getting any fuel stains or spills over the fuselage from the vent when you are full of fuel to the Filler Cap and in The Climb? I am in the process of "drawing up" a similar arrangement to you except using two "ninties" and venting to the fuselage bottom - it would be eaisier for me to use my existing "roof" vent as in your arrangement , but, i need to know if your getting fuel spills when "full to the filler cap" with your arrangement,
steve vestuti #573 G-CEBV
approx 25Hrs of absolutly fantasic flying .
Visit - www.EuropaOwners.org
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Mon Jul 02, 2007 1:46 pm Post subject: Fuel venting |
Fred,
I have done pretty well the same as John has. Take a look at
http://europa363.versadev.com/ under July 2002 and you will see a bunch of
photographs.
I didn't use the sight gauge as the general theme on the forum was that it
was pretty well useless. I used a system designed by Tony K that measures
the weight of fuel in the tank with a pressure transducer, analogue to
digital converter and a microprocessor to display the tank contents on a 10
segment LED display. It works nicely. Its most a back up to my fuel
totalizer in my GRT EIS
Paul
