		jodel(at)nildram.co.uk Guest
				 Posted: Tue Feb 14, 2006 7:15 am    Post subject: Paint dilemma |
				Some advice from you all please.
 I have had my Europa painted by "a person that will remain nameless" who
 should know what they are doing.  They delivered it back to me in mid
 January.
 The fuselage was delivered to my house for some more fitting out to be
 completed but the wings were delivered direct to the airfield.
 They were unloaded from the trailer by myself and "a person that will remain
 nameless "and stored in the hangar on a cradle still in the polythene as
 delivered.
 On checking them last week with my inspector we found that the inside of the
 polythene was wet and over the lower third (they are sitting on the LE so
 1/3rd back from the LE on upper and lower surfaces) the paint is raised into
 thousands of tiny bubbles each around 0.1 to 0.2mm in size. We have removed
 the polythene and moved them to an enclosed area of the hangar where we can
 leave a fan heater running which raises the ambient temp by about 4 degrees
 c.
 Photos can be seen at:
 http://homepages.nildram.co.uk/~jodel/IMG_7340.JPG
 http://homepages.nildram.co.uk/~jodel/IMG_7343.JPG
 http://homepages.nildram.co.uk/~jodel/IMG_7344.JPG
 The third picture is probably the clearest example of what has occurred.
 When this was discovered I phoned the " person that will remain nameless"
 and described the problem.  He said that once the moisture had dried off the
 paint would return to normal.  Given that the wings have been sitting in
 this enclosed heated area for a week now with no change to the surface
 finish finish, what do you think the outcome will be?  Do you believe it
 will dry out and return? Have you seen this happen? The painter and I are 5
 hours drive apart so it is not an easy one to solve!
 thanks
 Simon
 G-BZTN kit 504
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		carl(at)flyers.freeserve. Guest
				 Posted: Tue Feb 14, 2006 11:43 am    Post subject: Paint dilemma |
				One crucial thing.
 You havent said what paint was used. If it was the Poly***** stuff then i'm
 not that surprised. I havent come accross anyone who is happy with the
 stuff.
 The only paint that should be used is two pack epoxy.
		tonyk(at)kaon.co.nz Guest
				 Posted: Tue Feb 14, 2006 12:13 pm    Post subject: Paint dilemma |
				 	  | Quote: | 	 		  > You havent said what paint was used. If it was the Poly***** stuff
 then i'm not that surprised. I havent come >>accross anyone who is happy
 with the stuff.
 Poly***** discontinued their paint some time ago. It was costing them
 too much to pay to have people's aircraft, mine included, repainted when
 the the paint failed.
 The Sikkens two pot that got put onto my aircraft thanks to them looks
 superb though!
 Tony
		mikenjulie.parkin(at)btop Guest
				 Posted: Tue Feb 14, 2006 12:17 pm    Post subject: Paint dilemma |
				Carl,
 Now you know one person that is happy with Topgloss!!
 It is a good solution if you want to paint your own aircraft instead of
 paying for it to be done.
 regards,
 MP
				 Posted: Tue Feb 14, 2006 12:18 pm    Post subject: Paint dilemma |
				Sorry, should have said!
 It is Akzo-Nobel Aerodur C21/100UVR (two pack polyurethane)
 Simon
		sidsel.svein(at)oslo.onli Guest
				 Posted: Tue Feb 14, 2006 12:49 pm    Post subject: Paint dilemma |
				Simon,
 Very sorry to read what happened.  I received my fuselage back from the
 painter (who I will be proud to name!) in December, and the wings and
 control surfaces two weeks ago.  I will pass on his advice, although not of
 much benefit to you but perhaps to others following in our steps, but first
 a word re. the paint:  Used Akzo Nobel's Aerodur (two-part), the same as
 sold by Europa 2004.  Very nice result, glossy and will be even better when
 polished (much later!!), according to the painter.
 My painter emphasised that the parts should not be wrapped or covered in
 anything or in contact with anything preventing evaporation of the wet stuff
 for as long as possible, to allow the paint to dry completely.  Otherwise
 tiny bubbles/blisters would result.  He advised strongly against
 transporting the wings back to my workshop with any support to the painted
 surfaces (dried for one week in his paint shop, after curing at around 30
 degr C for several hours following the spraying), so I used the arrangement
 made for rotating the wings during painting also for transportation
 (supported only at the spar end and at a fitting bolted to the wing tip
 light fixture point).  Now in my workshop, the wings are suspended from the
 ceiling at the same points.
 Asking him how soon I could apply vinyl self-sticking stripes etc. on the
 painted surfaces, he was most adamant:  Not before 3 months have passed,
 provided you store the parts at normal room temperature.
 A piece of encouragement to all those who are filling and sanding, or dread
 this stage:  I kept at it for more than 6 months.  Gave up towards the end
 on certain areas of the fuselage and had my painter do that (very
 professionally done by him), but I persevered on the wings and control
 surfaces.  Now when I see it all painted, I have almost forgotten the
 endless preparation work - it looks so beautiful with that shiny, white
 paint, no dust particles, no pinholes - very, very rewarding!  Don't give
 up!
 Svein
 A225 - XS Trigear - now in Norway - finding that upholstering also takes
 time, used 35 hours on just covering the central tunnel with
 leather - - - - -
