sam(at)fr8dog.net Guest
Posted: Mon Jun 25, 2007 6:13 am Post subject: Static problems |
I'm having static problems, I think, not sure where to look though. Indicated airspeed seams to be accurate on the bottom end but 20 to 30 knots slow at cruise, verified with chase plane. The static was checked and certified IFR by an avionics shop, with no leaks. Looking for ideas......
Sam
james.k.hovis(at)gmail.co Guest
Posted: Mon Jun 25, 2007 6:43 am Post subject: Static problems |
Most likely the place where your static source is portted to the
outside is experiencing some turbulence that is raising the
free-stream pressure of the air. Airspeed is measured by taking the
dynamic (pitot) and static pressure difference and calculating the
airspeed with a mechanical computer. Changing your static port
location, seeing if there's a skin mismatch or even a burr near the
port may help. Calibrating the airspeed indication systems is one
reason why production aircraft fly with an extremely long pitot/static
boom during initial flight testing.
Kevin H.
On 6/25/07, Sam Marlow <sam(at)fr8dog.net> wrote:
| Quote: | I'm having static problems, I think, not sure where to look though.
ideas......
Sam
rene(at)felker.com Guest
Posted: Mon Jun 25, 2007 6:44 am Post subject: Static problems |
What type of static ports did you install. Are they flush with the skin/paint?
Rene' Felker
N423CF
40322
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sam Marlow
Sent: Monday, June 25, 2007 8:13 AM
Subject: Static problems
Sam | Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
Dave(at)AirCraftersLLC.co Guest
Posted: Mon Jun 25, 2007 8:32 am Post subject: Static problems |
Sam,
You might have a pitot leak.
You can check by putting a tiny bit of pressure on the pitot tube. Be careful, it doesn't take much to peg the instrument. If you can get a piece of surgical tubing over the pitot tube, then roll it up, you can set an airspeed on the indicator. Run it up to Vne. It shouldn't bleed down more than about 5 knots (mph) in 5 minutes. Any worse than that, you might want to look for a leak.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
Sent: Monday, June 25, 2007 7:13 AM
Sam
coop85(at)cableone.net Guest
Posted: Mon Jun 25, 2007 1:02 pm Post subject: Static problems |
As mentioned it could be a pitot leak. I had one right behind the panel and could actually change my airspeed by grabbing the connection that was leaking (it was very pronounced though, not just 20 knots at the high end).
Another thought depends on what indicator you have. If it’s an EFIS, there may be some calibration errors that you can adjust.
Marcus
40286
168 hours and can’t stand to park it long enough to paint it!
Sent: Monday, June 25, 2007 9:13 AM
GenGrumpy(at)aol.com Guest
Posted: Mon Jun 25, 2007 6:44 pm Post subject: Static problems |
Based on problems I had, if you have any 2 1/4 inch airspeed, VSI or
altimeters, I would consider them likely suspects!
I went through 3 airspeed indicators to get a good one plus one VSI. Both
had leaks internally in them that affected my pitot and static systems.
Grumpy
In a message dated 6/25/2007 4:04:58 PM Central Standard Time,
coop85(at)cableone.net writes:
Marcus
40286
____________________________________
Sam
************************************** See what's free at http://www.aol.com
Posted: Mon Jun 25, 2007 7:55 pm Post subject: Static problems |
I have the static port in the Van's recommended position, I wouldn't have a clue where to move it, or even how. I can't just start drilling holes randomly. What should I do?
James K Hovis wrote: [quote]--> RV10-List message posted by: "James K Hovis" <james.k.hovis(at)gmail.com> (james.k.hovis(at)gmail.com)
Kevin H.
ideas......
Sam
Posted: Mon Jun 25, 2007 7:56 pm Post subject: Static problems |
I installed the Cleveland Tool flush ports.
Rene Felker wrote: [quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Rene' Felker
N423CF
40322
801-721-6080
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Sam Marlow
Subject: RV10-List: Static problems
Sam [b]
Posted: Mon Jun 25, 2007 8:03 pm Post subject: Static problems |
I just had a static check by an avionics shop, no leaks, IFR certified. I'm baffled.
Dave Saylor wrote: [quote] Sam,
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
Sam
Posted: Mon Jun 25, 2007 8:05 pm Post subject: Static problems |
I have both EFIS and analog, and they agree with each other.
Marcus Cooper wrote: [quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Marcus
40286
Sam [b]
Posted: Mon Jun 25, 2007 8:10 pm Post subject: Static problems |
Good thought but I have full size backup instruments, and the EFIS agrees with the analog readings.
GenGrumpy(at)aol.com (GenGrumpy(at)aol.com) wrote: [quote] Based on problems I had, if you have any 2 1/4 inch airspeed, VSI or altimeters, I would consider them likely suspects!
I went through 3 airspeed indicators to get a good one plus one VSI. Both had leaks internally in them that affected my pitot and static systems.
Grumpy
In a message dated 6/25/2007 4:04:58 PM Central Standard Time, coop85(at)cableone.net (coop85(at)cableone.net) writes:
Marcus
40286
Sam |
See what's free at AOL.com.
AirMike
Posted: Mon Jun 25, 2007 9:20 pm Post subject: Static problems |
My I.A. friend suggested that it could be water accumulating.
He told me to put a sump in my system. Spruce sells a cheap sump.
I was directed to put a low point in the static lines for water to accumulate.
Had to run my lines up the port side, so after routing them high, they dropped down to the floor aft of the baggage bay.
Good luck - hope this helps
_________________ See you OSH '18
Q/B - sold. |
Tim Olson
Posted: Tue Jun 26, 2007 3:08 am Post subject: Static problems |
I'm going to combine 4 replies into one.
Sam Marlow wrote:
## I installed the Cleveland Tool flush ports.
Well, if they're the old flush flat Cleveland ports, then that's good
for at least about 1/3 of your 20kt error right there. If they're the
domed ones, they may have less error.
##I just had a static check by an avionics shop, no leaks, IFR
Did they check the PITOT system for leakdown too? The IFR static
test is far far more relaxed on the pitot side than the static side,
and they really only bother to test for leaks in many cases. The
suggestion given to use surgical tubing and check for leakdown is
a good one...even if they said it passed.
## I have both EFIS and analog, and they agree with each other.
Of course...even a leaky system could possibly have a pressure
inside it that's common along the whole system, so that doesn't
surprise me.
## Good thought but I have full size backup instruments, and the EFIS
Full size, or small, the leaks could be anywhere, if they exist.
From what I've read, it's very hard to get pitot errors from
mis-angled pitots without it being a really big angle error. If
your pitot is mounted in the standard way, and sits down low enough
from the wing, and there are no bugs and stuff in it, then it is
not likely the problem. That really brings you back to either
a pitot leak, static problem, or port type/position problem. There's
not going to be a silver bullet, so it's just time to roll up
the sleeves and start digging. I replaced my static ports even
after the plane was painted. If yours are the flat ones I'd
start there and then fly the 4-way GPS and see where you're at.
It's not going to come free, so it'll just take some time,
and eventually you should be able to get within a couple KTS.
k5wiv(at)amsat.org Guest
Posted: Tue Jun 26, 2007 3:21 am Post subject: Static problems |
How are your altimeter and vertical speed indicators? If they are correct then it's unlikely that you have a static issue since they also use the static port for their sensing. Only the airspeed uses the pitot, however, so I'd start looking there. Possibly a kink in the pitot line, or a pinch, or something restricting it.
Jack & Cecilia Sargeant
1127 Patricia St.
Wichita, KS 67208-2642
316/683-5268 [quote] --
Posted: Tue Jun 26, 2007 4:42 am Post subject: Static problems |
Thanks.
Do not archive.
AirMike wrote:
OSH '08 or Bust
http://forums.matronics.com/viewtopic.php?p=120657#120657
Posted: Tue Jun 26, 2007 4:45 am Post subject: Static problems |
Thanks Tim, this is a tough one, I guess it'll just take some digging.
Sam
Tim Olson wrote: [quote]--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com> (Tim(at)MyRV10.com)
##I just had a static check by an avionics shop, no leaks, IFR certified. I'm baffled.
surprise me.
## Good thought but I have full size backup instruments, and the EFIS agrees with the analog readings.
Posted: Tue Jun 26, 2007 4:47 am Post subject: Static problems |
I've ran the lines to check for kinks etc, nothing I can see. It's a
tough one for sure.
Jack Sargeant wrote:
[quote] How are your altimeter and vertical speed indicators? If they are
1127 Patricia St.
316/683-5268
sgesele(at)yahoo.com Guest
Posted: Tue Jun 26, 2007 9:31 am Post subject: Static problems |
| Quote: | Time: 07:13:44 AM PST US
to look though.
static was checked
leaks. Looking for
ideas......
Sam
There are three potential sources for your error:
pitot, static, or instrument.
Pitot:
Is your pitot installed exactly per Van's
instructions? If not, what changes have been made? A
pitot leak can be checked, and the instruments checked
for error, by using the method contained in the
following link:
http://www.iflyez.com/manometer.shtml
Many heated pitot tubes have a drain port. Ensure
that it is covered when performing the test. You may
want to try a test flight with the drain port covered.
All the drain port does is allow an exit path for
water. Don't fly in the rain with the drain covered.
Static:
Just because the system was checked for leaks during
an IFR cert, does not rule out static errors. You
mentioned flush ports. These have been the cause of
numerous static errors on the RV fleet. Static errors
may be a function of airspeed. You can use GPS
altitude to determine if you have a static error that
is a function of airspeed. In VFR, severe clear,
conditions, start with the aircraft at rest on the
ground. Adjust the altimeter setting until the
altimeter matches the GPS altitude. Go fly. Start at
a safe altitude and Vs+10 kts. Record both the GPS
altitude and indicated altitude at various airspeeds
as the aircraft accelerates to cruise. Repeat as the
aircraft is slowed from cruise to Vs+10 kts (power at
idle). Perform this test while maintaining a specific
indicated altitude. Obtain the local altimeter
setting and land. If the above test shows the
indicated altitude to be less than the GPS altitude,
then your static port is reading a higher than ambient
pressure. This will cause an airspeed error.
Instrument:
The pitot test above will check both the pitot system
for leaks, and the accuracy of the instruments.
Now that's room service! Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit.
http://farechase.yahoo.com/promo-generic-14795097
Posted: Tue Jun 26, 2007 11:01 am Post subject: Static problems |
Sam,
When we get static checks, they only test the pitot system if we ask. Even then it's an "information only" type check, no certification. There's no requirement for a pitot check in 91.411/413, so having the static system IFR certified could still leave you with a pitot problem.
If you are looking for a pitot leak, remember that it won't show up as a low airspeed indication with the test I suggested. Airspeed will go to whatever you put in, then bleed off. If the leak is pretty big, you might not see any indication at all, but since you are getting something close at lower speeds, I doubt you have a huge leak.
The fact that two instruments agree pretty well rules out instrument error but not a leak common to both.
What happens when you open the alternate static port?
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
Sent: Monday, June 25, 2007 9:02 PM
Subject: Re: Static problems
[quote] [b]
Posted: Tue Jun 26, 2007 3:38 pm Post subject: Static problems |
Thanks Scott, I'll try that ASAP, will let the world know the results!
Scott Gesele wrote: [quote] | Quote: | --> RV10-List message posted by: Scott Gesele <sgesele(at)yahoo.com> (sgesele(at)yahoo.com)
From: Sam Marlow <sam(at)fr8dog.net> (sam(at)fr8dog.net)
to look though.
static was checked
leaks. Looking for
ideas......
Sam
Pitot:
following link:
Static:
Instrument:
| [b]
