nwcmc(at)tiscali.co.uk Guest
Posted: Thu Jun 21, 2007 1:48 am Post subject: EUROPA PIP-PIN RECESS |
| Quote: | This is like treating the symptom and not the illness. The play comes
from
the TP10 fixing on the torque tube. If the pip pin fixes well, the play
is
tranferred on the glue of the TP6 in the foam! If there is any flutter
then
you can imagine how long it will take before the TP6 comes untie.<
I agree that the problem starts with the fixing of the TP10's. However
the design of the pip pin recess is still important. A small amount of
relative movement between the tailplanes (caused by the less than
perfect fixing of the TP10's) is not in itself dangerous. Neither is
disbonding of the TP6's by itself. What is dangerous is if the
tailplanes move outwards allowing them to disconnect from the TP10 pins.
If the TP6 becomes disbonded (by for instance twisting loads) it is
possible in some cases for the tailplane to move outwards sufficiently
for the tailplane to become disconnected from the TP10 pins. The size
and shape of the recess is important in this respect. A recess sidewall
which is close to the pip pin head on the inboard side can prevent
outward movement of the tailplane whilst the pip pin is in place even if
the TP6 is disbonded.
Although flutter has been mentioned (and can be a very dangerous
condition), a possible cause of this inflight loss of control is a
tailplane moving outwards enough to become detached from its TP10 pins.
Regardless of the TP10 fixing it is important that this is not allowed
to happen.
I know that the PFA is looking at a modification to the pip pin recess
so we will just have to wait to see what they come up with.
Nigel Charles
jan.de.jong(at)xs4all.nl Guest
Posted: Thu Jun 21, 2007 2:21 am Post subject: Europa pip-pin recess |
Hallo Jos,
I did the same thing. Locked both TP6 and TP5 in 3 layers of bid tube
before bonding tube into place with flox and bid laps. TP6 and TP5
deeply scored beforehand using dremel cutting disk. I am confident that
TP6 will not go anywhere.
Dutch CAA requires all mandatory mods executed for CofA. Finnish CAA no
different I presume.
So I hope that PFA will bless at some point.
Jan de Jong
#461, making slow progress.
Posted: Thu Jun 21, 2007 4:50 am Post subject: EUROPA PIP-PIN RECESS |
Hello Fred
"Ron...a picture's worth 1000 words...thanks, and I need a few more words:
I take it the shoulder of the screws is what penetrates the TT and
bushes, and both the CF tube and the embedded and threaded "base" you
turned help to keep the outer bush bonded in place."
The shoulder of the screw acts like a pin, instead of 2 balls to hold pin
in place I used threads (need a wrench for prying hands to remove). The
inner and outer bushings are glassed to plywood ribs. The CF tube is
glassed to each bushing and fillet that is holding bushing to rib. The
lower insert does not really help with bushing bond, it is glassed to CF
tube and rib fillet (perhaps helps a mini tad but not much). The top
receptical does not help bushing bond, it is bonded to recess and a bit of
CF tube on the bottom, and a flox ring on top bonds it to outer 2 UNI.
Sorry, not much in the way of more pictures, will try to describe:
1) First it is absolute imperative TP9 and two TP12s are well stuck to TT
TP4. You can search Archives "Ron Parigoris Torque Tube" for a description
how I made the fit right. Slop between TP4 TT and TP12 stabilator drive
arm, if enough will allow the pip pin, or in my case the shoulder screw to
begin to allow torque to be applied the the outer bushing. If built to
plans, the bond on the outer bushing is not tremendous robust, and if you
apply torque to it, it could easily debond where if no torque was applied,
it could have lived a happy life. Read the PFA procedure careful
describing wiggle of pip pins, they are trying to determine if torque is
being applied to outer bushing. Again if there was no motion between TP4
and TP12, the pip pins could not drive, only motion can allow the
undesirable drive. It is possible that there is motion but within
allowable limits. If this is the case it is possible you could debond the
outer bushing as described if the fit in the TT and outer bushing and pip
pin is tight. As described the only reason for the Pip Pin is to keep the
stabilator on the TT, and the TP12 drive arms engaged to the TP13 driven
bushings that are bonded into the root plywood rib. Just a side note my TP
13 bushings were bonded in place with rapid epoxy and only 50 % coverage
and also in the wrong position where the angle of attack was not the same
on both stabilators. Oval holes, well scuffed washer under the step on the
bushing and redux/Flox repaired. OK I hope not confusing too much, but the
pip pin only needs to contact to prevent any outboard movement. The fit to
the outer bushing can be fairly close and round, but the TT if radially
elongated (I did mine ~.020" each way) still will hold the Stabilator
inboard, but if motion developed between TP4TT and TP12 stabilator drive
arm, the TT elongated pip pin hole could not drive the pip pin (if less
than max. recommended motion) before the pin hit the side of the oval.
2) My "Mutilation" was done after my accelerated tailplanes were built.
The Redux used on metal first pass bonds a bit better than Aeropoxy. A bit
of flexibility that can allow things to load just a tad more even before
joint lets go. Idea is to make sure inner and outer bushings are well
stuck to plywood insert ribs. The club mod is a good one (although I still
like redux first pass on metal.) Connecting the bushings helps prevent
twisting forces from debonding. When only the inner bushing is taking the
full load when sliding on the stabilator to TT, there is a lot of force
due to leverage that can be applied to that lone bushing. The CF Rowing
skull oar has a very slight taper. The second the TT enters the CF it is
held from allowing this undesirable torque upon assembly, and it guides
the tip into the outer bushing.
3) OK so my inner and outer bushings are stuck to stabilator and each
other pretty good. If they stay stuck then the outer bushing is a fine
means to pin the stabilator to the TT. 006 pip pin recess dilemma is
trying to make sure that if the outer bushing debonded that the stabilator
was not allowed to move outboard and have TP12 drive arm pins, disengage
from the stabilator driven TP13 bushings by ensuring that the pip pin
recess is strong enough to take outboard forces. I am not certain about
the minimum base requirements if plans not followed exact, but I suspect
it is to help hold the outer bushing a bit better. I was able to contact
with my glass reinforcement/filled a little more than 1/2 the
circumferance of the bushing from the bottom, and my CF tube had half of
it sneak around by twisting it so it was reduxed to the top of the
bushing! On a new build following the Club Mod is pretty easy, on
completed stabilators it took a bit more creativity.
Even though my outer bushing is stuck pretty well, I made sure my bottom
threaded insert is stuck well to the outer plywood rib. My top receptacle
is stuck on the bottom pretty well on the BID of the pip pin recess, then
I filled with foam and left a space for a flox fillet to the top 2 UNI
plies that completed the top and left it flat except for a perhaps 3/8"
hole.
4) One more time, my shoulder screw goes through top receptacle, top of
outer bushing, through top of TT that is elongated .020" each side,
through the bottom of the TT that is elongated .020" each side, through
the bottom of the outer bushing, through CF tube and glass, and into
threaded bottom insert.
First means to hold stabilator on TT is shoulder screw to outer bushing
top and bottom and TT top and bottom.
If Outer bushing debonded second means is shoulder screw to upper
receptacle to both sides of TT and on bottom CF tube, glass and insert.
Hope this is clearer than mud?
Ron Parigoris
josok-e(at)ukolo.fi Guest
Posted: Thu Jun 21, 2007 1:31 pm Post subject: EUROPA PIP-PIN RECESS |
Ron,
I first want to acknowledge you for taking the time and effort to
respond to my queries with such a thoughtful and nuanced explanation of
what you've done and why. Your willingness to do so creates the real
value I find in the forum discussions of so many critical life safety
issues.
Thanks so much,
Overall, you seem to have taken the bull by the horns in addressing the
apparent fragility of the bonds between the TP6 sleeve/bush, the
plywood insert, and foam...recognizing that your fix would be suspect
in the UK.
On Thursday, June 21, 2007, at 05:49 AM, <rparigor(at)suffolk.lib.ny.us>
wrote:
| Quote: | Just a side note my TP13 bushings were bonded in place with rapid
same
Being alerted to your condition, I've mounted my stabilators
(factory-built in my accelerated XS kit) to the torque tube assembly
and have found that the trailing edges, as measured at the trim tab
hinge line, vary by .375 inches; this translates to an angle of 1.19
degrees; thus the AOA of my stabilators have a differential of that
amount which is troubling to say the least, not only from a visual
standpoint, but more importantly from an aerodynamic standpoint as a
potential contributor to flutter. I attribute this differential to the
misplacement of the TP13 bushes in the plywood inserts at the root of
the stabilator.
| Quote: | Oval holes, well scuffed washer under the step on the
By "oval holes", I assume you're referring to the holes in the TT for
the pip pins. Since the TP13 bushes set the AOA of the stabilators, I
don't see how elongating the pip pin holes in the TT can "repair" this
problem. I find NO information in the build manual as to an acceptable
tolerance in the AOA between the two stabilators. The only fix I can
imagine would be to remove the TP13 bushes from one stabilator, fill
the void with flox, redrill for and replace the TP13 bushes so that the
two stabilators are in alignment with identical AOAs.
So all you guys w/ the "accelerated" XS kits: In your build (or now
that you're flying), have you found the same condition as I've
described above? If so, has it been remedied (how?), or has it been
ignored?...and is really no problem whatsoever?
(I'm always doing checks on my anal-retentiveness quotient.)
Input appreciated,
Fred
A194
believed to be clean.
Posted: Thu Jun 21, 2007 3:38 pm Post subject: Europa pip-pin recess |
Hi Jos,
I am confident that the club mod will keep TP6 in place if it is never
required to do other than its intended job - keeping the stabilator from
sliding off TP4. The bid tube will in any case be a backup retainer
between inspections.
But an official blessing will be needed.
Jan de Jong
g-iani(at)ntlworld.com Guest
Posted: Thu Jun 21, 2007 11:23 pm Post subject: Europa pip-pin recess |
Jan
I do not understand your reference to "an official blessing will be
needed. The Club mod is a fully approved PFA standard mod.
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
Posted: Fri Jun 22, 2007 12:14 am Post subject: Europa pip-pin recess |
Ian,
We do have the approved modification, so we do not have the standard,
probably too weak situtation.
I opted for this mod, because the original "looked" improvable.
How does this approved modification change the need for a a "standard" pip
hole and what other influences may there be?
If in the UK,would we be grounded too?
http://www.europaowners.org/kit600
karelvranken(at)hotmail.c Guest
Posted: Fri Jun 22, 2007 1:56 pm Post subject: EUROPA PIP-PIN RECESS |
Nigel,
I can follow your explanation except when you write: "What is dangerous is
if the taiplanes move outwards allowing them to disconnect the TP10 pins."
TP10's are nylon tubes. You mean perhaps the pins on the TP12?
The pip pin recesses on F-PKRL were made conform the build manual, even
stronger.
The problem I would talk about is the play between TP12 and TP4.
TP4 and TP12 are delivered with holes. When you have to fix them together
with the nylon TP10 tubes then you have to drill very carefully to allow the
clevis pins to be installed. Afterwards I found that the play occured on
starboard side by moving the TP12 by the pins. The mass balance keeps the
TP4 easily in place. So port side no play. When I did the same test on Dirk
Oyen's OO-145, it gave the same result. Factory tolerance? Bigger holes and
clevis pins wasn't a solution (Rowland Carson). Others do have the same
problem hence the discussions: clamps or taper pins. Finally no definite
solution nor mandatory modification. The play measured at trailing edge may
not be more then 1/2". I will have no play at all. So if we are waiting for
a modification to keep a fluttering tailplane on board then I say: You treat
Karel Vranken, F-PKRL waiting for next mod and if my problem is not
concerned then Bob Harrison may have an order from me.
Posted: Fri Jun 22, 2007 2:45 pm Post subject: EUROPA PIP-PIN RECESS |
Karel
You are right about treating symptoms. I too am still very puzzled about
the cause of William's accident. There are certainly a lot of Europas
around with 1/2" of looseness in the tailplanes. This arises from that
rather unwise requirement to drill the TP 10s through the torque tube
and the TP4s. imho that is where most of this particular problem starts.
The other problem is the security of the TP6 bush which is required to
keep the tailplane in place. It can come loose from more than one cause.
Slop in the TP12 allowing hammering while taxying on rough ground.
Damage caused during derigging or on the trailer.
I suspect this unhappy situation is, like most accidents, the result of
more than one factor combining to produse an accident.
I do find it incredible that it was possible to pull the wings off at 90
kts.( But then I haven't done the sums.)
Graham
karelvranken wrote:
<karelvranken(at)hotmail.com>
Nigel,
is if the taiplanes move outwards allowing them to disconnect the TP10
pins." TP10's are nylon tubes. You mean perhaps the pins on the TP12?
Others do have the same problem hence the discussions: clamps
or taper pins. Finally no definite solution nor mandatory modification.
The play measured at trailing edge may not be more then 1/2".
Karel Vranken,
Posted: Sat Jun 23, 2007 9:06 am Post subject: EUROPA PIP-PIN RECESS |
Thanks Graham,
I hope that other big guns start to shoot so that it is heard in the PFA
bureau.
Karel Vranken.
Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Sat Jun 23, 2007 6:40 pm Post subject: Europa pip-pin recess |
Hello,
I don't quite understand the process of elongating the pip-pin
holes. Mine are tighter'n a drum all round and so they touch everywhere
(presumably), whereas if I were to elongated any, then won't the long side
only be touched tangentially by the pin. Won't this then permit the long
side to be slowly indented, and won't the condition accelerate as the event
(and inner surface) wear on?
What am I missing here?
Happy Landings
Ferg
Wiring, wiring, wiring
jonsmitheuropa(at)tiscali Guest
Posted: Sat Jun 23, 2007 11:36 pm Post subject: Europa pip-pin recess |
Hi!
The factory news letter number 21, "tech talk" page 14 describes why the pip
pin holes in the torque tube should be elongated. The paragraph is entitled
"torque tubes".
Regards, Jon
Posted: Sun Jun 24, 2007 8:09 am Post subject: Europa pip-pin recess |
Sorry, my concern is premature. My reasoning: assuming an official fix
for better TP6 retention and assuming this fix incompatible with club
mod then club mod must remain blessed without fix.
Jan de Jong
G-IANI wrote:
Jan
