Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sat Jun 23, 2007 10:41 pm Post subject: Prop control label again |
OK, let me try this again...
For THOSE OF YOU who have LABELS on YOUR prop controls, what does it say? I did NOT ask for a discussion regarding WHY, just the simple question. Zero info so far. Does this simply indicate no one is willing to stick their necks out here for fear of a political roast? (I know, dumb question- I've been here a loooong time) Believe me, I understand- if this is the case, please respond off-list- my direct e-mail is fiveonepw(at)aol.com (fiveonepw(at)aol.com) I AM including a label and simply curious what would be most appropriate!
C'mon, guys- this has nothing to do with primer...
Mark do not archive
See what's free at AOL.com.
_________________ From The PossumWorks... |
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Sun Jun 24, 2007 2:51 am Post subject: Prop control label again |
"PUSH - MAX RPM"
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Larry Bowen
Posted: Sun Jun 24, 2007 4:56 am Post subject: Prop control label again |
I have the deluxe throttle quadrant from Van's, that comes engraved/labled already. Why don't you just mimic that?
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1182689606-374-186&browse=controls&product=delux-quadrant
Larry Bowen
Larry(at)BowenAero.com (Larry(at)BowenAero.com)
http://BowenAero.com
On 6/24/07, Dale Ensing <densing(at)carolina.rr.com (densing(at)carolina.rr.com)> wrote:[quote] "PUSH - MAX RPM"
Dale Ensing
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
sbuc(at)hiwaay.net Guest
Posted: Sun Jun 24, 2007 5:56 am Post subject: Prop control label again |
Mark, attached is a photo of the labels in my plane. The image is small
but the throttle label is "Pull for Idle" and the mixture is "Pull for
Lean".
I've seen you fly and you're pretty good.....
Sam Buchanan
Fiveonepw(at)aol.com wrote:
| Quote: | OK, let me try this again...
respond off-list- my direct e-mail is _fiveonepw(at)aol.com_
(mailto:fiveonepw(at)aol.com) I AM including a label and simply curious what would be most appropriate!
23.36 KB |
504 Time(s) |
Beer30?
Posted: Sun Jun 24, 2007 6:44 am Post subject: Prop control label again |
High and Low seems to make the most sense to me. My son just built a laser router and I'm going to have him engrave my throttle quadrant (as well as the rest of the panel) with it. I could ask if he's looking for business to engrave other items. Let me know if anyone is interesting in laser engraving of similar items.
David
On 6/24/07, Fiveonepw(at)aol.com (Fiveonepw(at)aol.com) <Fiveonepw(at)aol.com (Fiveonepw(at)aol.com)> wrote: [quote] OK, let me try this again...
Mark do not archive
[quote][b] http://www.matronics.com/Navigator?RV-List http://forums.matronics.com [quote][b]
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Sun Jun 24, 2007 6:38 pm Post subject: Prop control label again |
You must have missed my response...
My RV used RPM PUSH INCREASE and my Navion uses PROPELLER PUSH INCR. Seems the other controls all use "Push" type labels too.
Greg Young - Houston (DWH)
RV-6 N6GY ..project Phoenix
Navion N5221K - just an XXL RV-6A
[quote] From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Fiveonepw(at)aol.com
Sent: Sunday, June 24, 2007 1:41 AM
To: rv-list(at)matronics.com
Subject: Prop control label again
Mark do not archive
Mark Phillips in TN
Posted: Sun Jun 24, 2007 9:10 pm Post subject: Prop control label again |
In a message dated 6/24/2007 7:58:28 AM Central Daylight Time, Larry(at)bowenaero.com writes:
| Quote: | | I have the deluxe throttle quadrant from Van's, that comes engraved/labled already. Why don't you just mimic that? |
Yeah, I checked that- trying to define one lable on bottom of panel "Prop - push(pull) ????
Thanks for the replies on&off list so far!
Mark do not archive
Mark Phillips in TN
mark(at)stratologic.net Guest
Posted: Mon Jun 25, 2007 4:51 am Post subject: Prop control label again |
I used the following..printed out on an inkjet printer on Avery clear
mailing labels #18660 (word has a template for this paper).
Looks as great as the day I did it in 2002. I used this paper for all my
labels. Easy to change later on when you mod something.
Propeller
Push >RPM
Mark
Posted: Mon Jun 25, 2007 6:04 am Post subject: Prop control label again |
In a message dated 6/24/2007 9:00:03 AM Central Daylight Time,
sbuc(at)hiwaay.net writes:
Musta been a rare day- ATC towers from OSH to LAL have mug shots of my tail#
on their walls 8-( Appreciate the reply, Sam
Seeyah!
Mark do not archive
Oops, failed to notice you were looking for prop labeling, not throttle
and mixture.
I take back what I said about your flyin'........
Sam Buchanan
