Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Fri Jun 22, 2007 6:42 pm Post subject: Prop control label |
For those out there with blue knobs-
What is an appropriate label on the panel (Not on the knob itself) for the prop control- two come to mind "PROP- pull coarse" and "RPM- pull low".
What're y'all using?
Thanks!
Mark
See what's free at AOL.com.
_________________ From The PossumWorks... |
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Fri Jun 22, 2007 7:38 pm Post subject: Prop control label |
My RV used RPM PUSH INCREASE and my Navion uses PROPELLER PUSH INCR. Seems the other controls all use "Push" type labels too.
Greg Young - Houston (DWH)
RV-6 N6GY ..project Phoenix
Navion N5221K - just an XXL RV-6A
Thanks!
Mark
Bruce(at)glasair.org Guest
Posted: Sat Jun 23, 2007 9:14 am Post subject: Prop control label |
Just why would anyone want to label the TPM controls. FAR's suggets color and shape constraints, not labeling. I fought a battle with my AB-DAR on this issue. He could site no FAR that required labeling, just that 'we've always done it'. I have no labels on mine. If you don't know how to use the controls, you shouldn't be flying the airplane.
Bruce
www.glasair.org
klwerner(at)comcast.net Guest
Posted: Sat Jun 23, 2007 1:30 pm Post subject: Prop control label |
Color and shape constraints are for identification purposes by touch, but not the operational aspect itself. Labeling tells you what you can do with any given control once it is identified in regards to its purpose.
Example: I observed an Experimenter friend of mine that got a bit exited before his first engine start of a Rotary conversion, and when it fired it went immediately to full throttle, because he was a bit excited/stressed at that instant. Labeling the throttle "may" have prevented that, but I don't know if he had a written checklist for this first engine start, ...the mental checklist failed obviously!
And yes, the pilot should know how to properly use the controls of the craft (s)he commands, but then add some adverse facts to it, and Mr. Murphy, the Lawyer may kick in...
cjensen(at)dts9000.com Guest
Posted: Sat Jun 23, 2007 3:31 pm Post subject: Prop control label |
Konrad,
If someone unfamilair with an aircraft starts it without first doing a fairly thorough familiarization, the throttle should be labeled "By the time you take the time to read this, you will be S.O.L."
Labels are for a person familiarizing himself with a craft, not for identifying critical flight controls while burning gas.
Chuck Jensen
-----Original Message-----
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Konrad L. Werner
Sent: Saturday, June 23, 2007 5:29 PM
To: rv-list(at)matronics.com
Subject: Re: Prop control label
PittsS1(at)aol.com Guest
Posted: Sat Jun 23, 2007 3:38 pm Post subject: Prop control label |
naw ... they are to satisfy the FAA / insurance companies. and make us safer...
mike
Posted: Sat Jun 23, 2007 4:00 pm Post subject: Prop control label |
Hi Chuck,
I fully agree with you, but my friend made a mistake due to stress (while still on the ground & before even burning gas). He was very familiar with the airplane as he built the whole engine conversation and knew very well were the throttle position should have been for starting. Please re-read my post once more, because I did NEVER said that labeling is very helpful for inflight emergencies, which do come up on occasion...
Cheers,
Konrad
Mark Phillips in TN
Posted: Sat Jun 23, 2007 10:22 pm Post subject: Prop control label |
In a message dated 6/23/2007 12:17:17 PM Central Daylight Time, Bruce(at)glasair.org writes:
| Quote: | | If you don't know how to use the controls, you shouldn't be flying the airplane. |
Thanks for answering my question, Bruce...
Mark do not archive
