thilo.kind(at)gmx.net Guest
Posted: Thu Jun 07, 2007 1:30 pm Post subject: Rotax 912 Cooling issue / Zodiac CH 601 HDS |
Hi folks,
got an issue with the cooling system of my Rotax 912 UL: in the past, CHT
temps always were around 100 F and very stable. Water reached 215F during
climb out and dropped back to 140 F during cruise. Also, cooling fluid
always expanded into the overflow tank.
During the last annual I replaced some of the cooling hoses and also
replaced the cooling fluid (50% / 50 %). I'm not sure, what the percentage
was before the replacement.
Now, water runs around 215 F during climb out and 205 F during cruise. CHT's
are very erratic from 100F to 150 F with an increasing tendency during the
flight. Oil was normal as always around 195 F. Immediately after landing, I
checked the engine and everything appeared normal, except there was not more
than the minimum of cooling fluid in the overflow tank. I'm a bit of a loss
and would appreciate your input. My thought right now is, that the glycol
percentage is now higher than before, resulting in less heat transport and
thus higher cooling fluid temps. At the same time, the boiling point is
higher, thus less presuure in the system and now overflow in the overflow
tank. The erratic CHT temps could be caused by air still trapped in the
system.
Any comments are highly appreciated.
Thilo
daberti(at)sbcglobal.net Guest
Posted: Thu Jun 07, 2007 5:06 pm Post subject: Rotax 912 Cooling issue / Zodiac CH 601 HDS |
You have air in the system, more than likely in the underbelly radiator. I
put a valve in the aft end of the radiator (petcock type) and the air bleeds
out very easy now.
Dave 912uls HD
Roger Lee
Posted: Thu Jun 07, 2007 8:06 pm Post subject: Re: Rotax 912 Cooling issue / Zodiac CH 601 HDS |
HI Thilo,
Couple of things here. Let's look at the CHT max temps. They are 266F. You are running very cool and it would be better running a little hotter (above 200F). You may be right about the different coolant ratio, but with the temps you are running don't worry about it. The CHT temps can change 50F from mid-range throttle at around 4400-4750 rpm and will cool off when at 5000 rpm. Mid-range (4400-4750 rpm) in a 912uls runs hotter CHT's than at 5000rpm. It was set up that way. If there is a small amount of air in the system then it will work its way out and that's an "if there is air". Rotax would like to see the oil temps around 200F-220F so you are a little cool with the oil which is ok. Optimal running rpm is 4800-5200rpm. My expansion tank never gets overflow. You may need a new pressure cap or you didn't have enough anti-freeze in the water? Your running so cool you may want to consider running Evans NPG+ coolant.
Depending on my rpm and the OAT then my GHT will differ 20-50F.
Your old temps were too cool.
Give your engine a few hours and see if things settle down.
You should not have anything to worry about with your temps now.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
JetPilot
Posted: Thu Jun 21, 2007 9:41 pm Post subject: Re: Rotax 912 Cooling issue / Zodiac CH 601 HDS |
| thilo.kind(at)gmx.net wrote: | Hi folks,
temps always were around 100 F and very stable. ......
CHT's
flight.
Thilo |
CHT's running 100 degrees F ???? That does not make any sense at all. That is very close to the reading you would get with a completely cold engine. Something wrong in your readings, or in your reporting of temperatures. A CHT 100 degrees for a running engine is impossible.
Kolb MK-III Xtra, 912-S |
