carl(at)flyers.freeserve. Guest
Posted: Tue Jun 19, 2007 11:14 pm Post subject: When to retract the flaps? |
Not sure what led you to believe we have a Trigear. G-LABS is one of the
original Classic monos - Kit 49.
In fact we have Ivan Shaws original Rotax 912 engine out of G-YURO. You
could call it son of YURO !!!
As regards the flaps question I totally agree that you need to get rid of as
much drag as possible as soon as possible. However a full retraction of the
flaps will cause the aircraft to sink (anything up to 100ft). I was warned
by a very experienced pilot that this was not a clever thing to do
especially at 200ft.
The other problem with retracting early (especially if you compromise and
only half retract) is that should the engine stop, you are likely to forget
you retracted and set yourself up for wheels up landing (or crash if
applicable).
I would say the safest height you should raise the gear is about 300ft and
in any event I would rather concentrate on flying the plane and seeing where
we are going. As G-LABS is somewhat underpowered I have to keep the nose
well down to build up speed (65kts) before commencing the climb.
I always assume there is a chance the engine could stop and on a nil wind
day it is not uncommon to cross the airfield boundary at 300ft. I would
NEVER consider turning back under such circumstances. As soon as the
aircraft is airborne and manouverable I point it at the nearest open space/
field (subject to where the gliders are launching and the location of the
winch).
Carl Pattinson
G-LABS
mikenjulie.parkin(at)btop Guest
Posted: Wed Jun 20, 2007 11:02 am Post subject: When to retract the flaps? |
| Quote: | As regards the flaps question I totally agree that you need to get rid of
as much drag as possible as soon as possible. However a full retraction of
the flaps will cause the aircraft to sink (anything up to 100ft). I was
warned by a very experienced pilot that this was not a clever thing to do
Carl,
With respect, if you are losing upto 100ft on flap retraction, you are not
using the best technique.
Holding the same attitude while retracting the flap will result in a
settling/sink. However, what one should do is as the flaps are slowly
retracted, the nose is raised to compensate for the reduction in lift caused
by the change in configuration.
In my limited experience with my 914 powered Monowheel, retracting the flap
never ceases to amaze me, the surge in performance as the wheel and flap
retract is brilliant.
regards,
Posted: Wed Jun 20, 2007 11:26 am Post subject: When to retract the flaps? |
Mike, I normally accelerate in something close to ground effect to a minimum
of 60kts and then progressively over about 2 secs pull up gear and flap.
Never noticed any tendency to sink, simply accelerates and starts to climb
nicely. If the engine goes I don't care too much whether I have got round to
putting the wheel down again. If you have runway to land on the damage is
negligible. If not you have much more serious things to worry about!
Regards, David Joyce
raimo.toivio(at)rwm.fi Guest
Posted: Wed Jun 20, 2007 12:54 pm Post subject: When to retract the flaps? |
| Quote: | Holding the same attitude while retracting the flap will result in a
I agree.
I have learnt also to do it (retracting)
almost immeadiately after take-off.
By doing it slowly /gently it is easy & safe.
No notable height loss at all.
Our Europa (Mono of course!) is a real performer
as a clean (clean only!!!) - so it must be clean asap after take-off.
| Quote: | In my limited experience with my 914 powered Monowheel, retracting the flap
In my VERY limited experience (912S), just confirm, REALLY.
One can ask: what to do if emergency landing gear retracted
(when doing "too early" in take-off)?
"So what" is my answer! It is easy and fast to lower and in the other
hand, Europa has a slippery boat-like-body to land w/o gear.
Happy landings.
Regards, Raimo
Posted: Wed Jun 20, 2007 1:07 pm Post subject: When to retract the flaps? |
Thanks for the tip - will give it a try.
Not sure though why you would need to bother with a 914 and I would guess a
VP prop. It goes up like a rocket anyway.
Carl
Posted: Wed Jun 20, 2007 1:25 pm Post subject: When to retract the flaps? |
Carl
Mike is right, I used virtually the same technique, As soon as positive
rate of climb is confirmed at around 2 to 300 ft unlock the
indercarriage and start slowly retractiong the flaps allowing the
airplane to maintain its trim. This resulted in a smooth transition from
65 kt climb with flap to 80kt climb without, and no height loss when
raising the flaps. There should be no trim change from flaps down at 60
kts to flaps up at 80kts, but there is an attitude chage of course.
You should find that flaps will settle anywhere in the range because
there is no load on the lever except the load of the undercarriage,
which is taken by the shock chords. If they don't then you need to
adjust the shock chords
Graham
caused by the change in configuration.
flap never ceases to amaze me, the surge in performance as the wheel and
flap retract is brilliant.
regards,
