roberthatton
Joined: 06 Nov 2006 Posts: 2 Location: Bicester, United Kingdom
Posted: Mon Jun 18, 2007 11:19 am Post subject: Undercarriage Not Retracting |
Has anyone experienced undue stiffness when retracting the mono-wheel undercarriage, or its absolute refusal to retract? I have experienced this and I am trying to figure out how to cure the issue. Any ideas?
Robert Hatton
A128 N741JH
carl(at)flyers.freeserve. Guest
Posted: Mon Jun 18, 2007 12:19 pm Post subject: Undercarriage Not Retracting |
I assume the distance between the rubber block upper and lower reaction plates is correct - ie: 133mm. If it is too small, the undercarriage will not retract fully or lock in place.
The most likely suspect is that the swinging arm bearings have been over tightened. If they are too tight you will need to insert shims between the bearing shells to loosen them up.
You dont say if the retraction mechanism ever worked or if the aircraft is flying.
bill.sue(at)orcon.net.nz Guest
Posted: Mon Jun 18, 2007 1:26 pm Post subject: Undercarriage Not Retracting |
Yes I had this early on.
After checking all of the mechanism I finally tracked it down to the
lever binding in the slot as it tried to move forward. The lever was not
tight in the slot but I think may have been twisting slightly as I tried
to retract. The cure was to polish the lever and each side of the slot,
squirt in some silicone lubricant and it solved it completely.
Sue & Bill
ZK CHV
XS Mono
914/Airmaster
580hrs
Robert Hatton wrote:
Robert Hatton
A128 N741JH
__________ NOD32 2337 (20070618) Information __________
karelvranken(at)hotmail.c Guest
Posted: Mon Jun 18, 2007 2:43 pm Post subject: Undercarriage Not Retracting |
Robert,
If your undercarriage worked already well before, than it is perhaps a lubricating problem of the undercarriage hinges. They are not greased once and forever. They can only function with regular appliance of some kind of creap oil.
My personnal experience,
Karel Vranken, # 447 Monowheel F-PKRL.
pjeffers(at)talktalk.net Guest
Posted: Mon Jun 18, 2007 10:56 pm Post subject: Undercarriage Not Retracting |
Try lubrication of the main retraction shaft where it rotates in the undercarriage frame.
Pete jeffers
