paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Sun Jun 17, 2007 5:25 pm Post subject: Fuel Tanks |
Hi all,
I recall watching Ivan Shaw's impromptu demonstration of a Landrover driving
over a Europa fuel tank.
I remember thinking at the time, wondering if it would fare as well if it
was full of liquid. I suspect that the hydraulic pressure would easily
rupture the tank, no matter what it was constructed of.
I would offer up a hypothesis that a full tank in a Europa that was
subjected to a high G load would rupture, but one that has had fuel burnt
off would have sufficient airspace in it that could be compressed and not
cause the tank to burst.
Just a theory.
Paul
asarangan(at)YAHOO.COM Guest
Posted: Sun Jun 17, 2007 7:02 pm Post subject: Fuel Tanks |
I am not sure about that theory. It is easier to crush an empty soda
can than a full one. Air is more compressible than liquid. When a full
tank is impacted, the liquid will transfer that energy to all surfaces
with little or no compression. A partial tank on the other hand will
compress until the air inside is squeezed to match the liquid. By then
the tank might have undergone enough bending stress to break it. Again,
just a theory.
--- Paul McAllister <paul.mcallister(at)qia.net> wrote:
Hi all,
driving
if it
easily
burnt
not
Just a theory.
Paul
Posted: Mon Jun 18, 2007 12:52 am Post subject: Fuel Tanks |
Paul, Being in the process of building a long range fuel tank at present, I
have had to look out the VLA regs for this, which will be applied by the PFA
before approval. Key requirements are: The tank needs to be able to
withstand a pressure of 24 kPa (about 3.48 lbs/sq. in) without rupture or
leakage. The tank must have an expansion space of minimum 2% of volume. The
tank must be restrained to resist inertial forces in forced landings, etc -
I have not got precise figures to hand but believe this to be to withstand
10g.
3.48 psi may not sound a lot but a tank with a side measuring 18 by
24 ins will need to withstand1503 lbs on that side to give an idea of the
strength required, and a 110 litre tank weighing about 200 lbs full should
have a restraining system of 2000 lbs strength. I wonder whether any system
sitting in the luggage bay can meet these requirements, as opposed to one
sitting in the passenger seat and using the passenger seat belt system as
restraint
Regards, David Joyce G-XSDJ
Posted: Mon Jun 18, 2007 11:11 am Post subject: Fuel Tanks |
I think you have a point. I just spoke to one of my students who does
failure analysis of aircraft parts. They have giant machines that pulls
and pushes a part until it breaks, and they take high speed photos
during the process for analysis. He seems to think that the tank being
full or not can go either way depending on the construction. In an
empty tank, the impact will tend to buckle the walls until the
structure collapses. In a full tank the fluid will equalize the forces
on all contacting surfaces, and will cause it to fail at the weakest
point, usually a weld joint. He seems to think that on welded
structures a full tank is probably worse, in agreement with Paul's
message.
Andrew,
I think Paul is right. There is a direct parallel in the mechanism he
refers
to in the Concorde accident in Paris - there debris hit the very full
tank
causing a segment of the wall to be blown out at the weakest point.
It might
not have happened had the tanks not been brimmed.
With the Europa tank, what the Land Rover unscientific demonstration
tells
us is that the tank can flex hugely without splitting. What any
materials
scientist will tell us is that the material will have a limit to the
tension
loads it can take: it is possible for a full tank taking an impact to
split
in tension; that tension arises because the contents will not allow
if to
flex.
Taking your can analogy: fill it with a dense foam (compressible) and
throw
it against a wall, hard. It will likely not split. Fill it with
liquid and
throw it similarly: it will likely split.
If the above stands scrutiny, it does tell us that brimming the tanks
"just
because there is space so I might as well use it" is not always the
wisest
policy if that fuel is not required.
Jeremy
