Craymondw(at)aol.com Guest
Posted: Wed Jun 13, 2007 7:29 am Post subject: Glasair props |
Has anyone experimented with different props on Glasairs. When builders of Venture aircraft switched Hartzell with McCauley props they noticed a ten knot increase in speed.
See what's free at AOL.com.
| - The Matronics Glasair-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
robin02(at)mindspring.com Guest
Posted: Wed Jun 13, 2007 11:04 am Post subject: Glasair props |
I switched from -4 to -2 blades and increased my cruise on 10GPH from 203 to 210MPH on my TD. I also experimented with -8 blades to give me more ground clearance. This is the smallest diameter listed for these blades by Hartzell. I flew the set up for about 900 hours and it worked fine with unnoticeable speed change from the -4 blades. I went to the -2 blades when I changed my gear to the longer Glasair II struts.
By the way, if anyone has a ground clearance concern, I have a rebuilt hub with the -8 blades. The set up was done by Sunstate Propeller in Tampa. It is for experimental use only as Hartzell does not have an application for the -8 blades. I will sell the prop for $3500. Robin Young 286YM
From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com
Sent: Wednesday, June 13, 2007 11:29 AM
To: glasair-list(at)matronics.com
Subject: Re: Glasair props
