Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Fri May 25, 2007 7:51 am Post subject: 601XL Empty weights |
What kind of empty weights are you 601XL builders seeing? Please indicate what engine you installed and any equipment out of the ordinary.
Thanks!
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
tonyplane(at)bellsouth.ne Guest
Posted: Fri May 25, 2007 2:10 pm Post subject: 601XL Empty weights |
Tim,
My empty XL weighed out at 799 Lbs with the CG at 290 mm.
It is probably a LOT heavier than a stock XL as I have 600x6 tires/wheels/brakes all around (nose fork from a 801), dual aux tanks & gauges, dual sticks, dual brakes, ldg/taxi/position lights/strobes plus EFIS, AS & Alt steam gauge backups, xpndr/alt encdr, com. stereo intercom, ELT, etc. The engine is a Jab 3300 with a wood Sensenich Prop.
The Zenith 700 lb figure is probably a zero option, min required equipment, day VFR airplane.
Tony Graziano
N493TG; 243 hrs of flying fun in the XL
601XL Empty weights From: Tim Juhl (juhl(at)avci.net ([email]juhl(at)avci.net?subject=Re:%20601XL%20Empty%20weights&replyto=1180108292.m2f.114727(at)forums.matronics.com[/email])) Date: [b]Fri May 25 - 8:53 AM[/b] [quote] | Quote: | What kind of empty weights are you 601XL builders seeing? Please indicate what
Thanks!
| [b]
Posted: Fri May 25, 2007 2:30 pm Post subject: 601XL Empty weights |
I have seen between 750 and 800 lbs.
Kevin Bonds
Joined: 09 Jan 2006 Posts: 171 Location: Nashville, Tn
pmaxpmax(at)HOTMAIL.COM Guest
Posted: Fri May 25, 2007 4:53 pm Post subject: 601XL Empty weights |
My XL weighed in at 777 pounds. Lights, center stick, steam gauges, no interior, no com, no transponder. Since then I've added a com and transponder. I have to say, it still climbs better than anything else at my home airport.
When I was considering the Corvair I was worried it would be heavier than other engine choices. In reality, the Corvair is about the same weight when you add all the other do-dads you need to really fly and enjoy your plane.
Phil Maxson
601XL/Corvair
Northwest New Jersey
| Quote: | From: tonyplane(at)bellsouth.net
Subject: Re: 601XL Empty weights
Date: Fri, 25 May 2007 17:09:24 -0500
Tim,
Tony Graziano
601XL Empty weights From: Tim Juhl (juhl(at)avci.net ([email]juhl(at)avci.net?subject=Re: 601XL Empty weights&replyto=1180108292.m2f.114727(at)forums.matronics.com[/email])) Date: [b]Fri May 25 - 8:53 AM[/b] | Quote: | | Quote: | What kind of empty weights are you 601XL builders seeing? Please indicate what
Thanks!
arget=_blank>http://www.matronics.com/Navigator?Zenith-List
p://forums.matronics.com
| Create the ultimate e-mail address book. Import your contacts to Windows Live Hotmail. Try it! [quote][b]
rpf(at)wi.rr.com Guest
Posted: Fri May 25, 2007 7:44 pm Post subject: 601XL Empty weights |
Hi Tim,
Mine came in at 710lbs (unpainted). Standard kit with the only options of
position/nav/strobe lights. Day VFR instruments and Jabiru 3300 with wood
Sensenich Prop.
Randy
bryanmmartin
Posted: Sat May 26, 2007 4:37 am Post subject: 601XL Empty weights |
Mine came in at 830lbs. Full six-pack with conventional gyros, Garmin
GNS-430, King KT-76A, confor-foam seats and sound/heat insulation
throughout the cabin.
Thanks!
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
xl(at)prosody.org Guest
Posted: Sat May 26, 2007 6:21 pm Post subject: 601XL Empty weights |
633Z is 715 pounds empty, setup for night VFR,
plus a Westech CHT monitor (6 sensors to 1 gauge)
The only frill that I have is a Pioneer AM-FM radio.
Joe E
N633Z (at) BFI
CH601XL 446 hours
Jabiru 3300, Sensenich wood prop
http://www.cleanh2o.com/633z/
On Fri, 25 May 2007, Tim Juhl wrote:
ordinary. Thanks! Tim
DO NOT ARCHIVE
David X
Joined: 10 Jan 2006 Posts: 154 Location: Princeton, NJ, USA
Posted: Tue Jun 05, 2007 7:39 pm Post subject: Re: 601XL Empty weights |
734 - Rotax 912ULS. Basic VFR night, extended tanks, all the paint.
_________________ Zodiac 601 XL - CZAW Built - Rotax 912S
DO NOT ARCHIVE |
