naumuk(at)alltel.net Guest
Posted: Mon Jun 04, 2007 4:14 pm Post subject: Corvair mount bolt length |
Corvair people-
When I found out that you needed longer than kit-supplied firewall mount bolts for a Corvair installation, I took the advice of a fellow lister and got some 3-1/2" bolts and was going to retrofit them to the kit mounts.
Then, Craig Payne sent me a set that he wasn't using that have 2-3/4" bolts.
My question is, can I get by with 2-3/4" bolts, or am I back to square 1?
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Mon Jun 04, 2007 4:42 pm Post subject: Corvair mount bolt length |
Do you have your motor mount? My WW mount had 1.5 inch or 38 mm tubes on it just like Zenith shows on their Lycoming O-235 dynafocal mount (sheet 6-YE-2 in the plans). Have you searched the Corvair list archives? There was a lot of traffic on this.
http://www.maddyhome.com/corvairsrch/index.jsp
-- Craig
Posted: Mon Jun 04, 2007 5:20 pm Post subject: Corvair mount bolt length |
Craig-
No, I don't have the mount. How do I access the Corvair archives?
Here's a question for all. What is the recommended radius for the crank journal sides? Just miked my journals and I have to go .010 under, so I know I'm going to have to have the radii put in. Have to give the machinists a number to hit.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Mon Jun 04, 2007 5:30 pm Post subject: Corvair mount bolt length |
Just click on the link in my message. Here it is again:
Also Nick sent me this back in Feb '06:
"In the latest edition, we no longer weld the bolt to the engine mount fitting. For the lower engine mount fittings, installing the bolt after the fitting is installed to the fuselage allows for better alignment.
For a 38mm long bushing, allow approximately 3mm to go through the fitting, the doubler and firewall = 41mm A better bolt to use is an AN6-22A (grip length = 1-11/16")"
-- Craig
[quote] [b]
Posted: Mon Jun 04, 2007 6:03 pm Post subject: Corvair mount bolt length |
Gotcha. Thanks.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
