sportav8r(at)gmail.com Guest
Posted: Mon Jun 04, 2007 8:49 am Post subject: Rocky Mountain route: Noob question |
I'm part of the gaggle from the SouthEast RV group headed to Yellowstone this weekend. I have no mountain flying experience save what little you get living and flying in the Appalachians the past 15 years.
I plan to return home to Virginia via the Grand Canyon and Albuquerque, Dodge City, KS, St. Loiuis, MO and eastbound from there. My question pertains mostly to getting from Cody to Flagstaff.
This route looks promising, but I seek input from RVers who know this area:
KCOD;KRIW;KRKS;U34;KHVE;KPGA.
I'm not sure how easy the Green River is to fly down to get to U34, but if it's a decent pass, then the highest terrain I should see enroute looks to be 9500' in the vicinity of Rock Springs, WY.
Leaving the Grand Canyon area via KPGA;KFMN;KABQ;KDDC looks like an effortless way out to the east.
I have oxygen available, and a 160hp FP RV6A that I've never taken above 11500 MSL. Naturally, everything's weather dependent, but I'm hoping with 6 days allocated for getting home from KCOD that this leg will be as doable as getting to Cody is. If you're a local, or a veteran aviator in the _real_ mountains, please chime in, here or off-list. I want to play this smart and safe. I've done the AOPA online instructional course, seen the FAA movies on mountain flying, and "read the book," BTW.
-Stormy
david.nelson(at)pobox.com Guest
Posted: Mon Jun 04, 2007 9:38 am Post subject: Rocky Mountain route: Noob question |
Hi Stormy,
ASF has a "Mountain Flying" course.
http://flash.aopa.org/asf/mountainFlying/html/flash.cfm
Of course, this is no substitute for hands-on training by qualified
instructors.
/\/elson
Austin, TX
RV-7A - Fuselage
On Mon, 4 Jun 2007, Bill Boyd wrote:
| Quote: | I'm part of the gaggle from the SouthEast RV group headed to Yellowstone
-Stormy
~~ ** ~~ Research has shown that Mondays account for 1/7th of your time ~~ ** ~~
ronlee(at)pcisys.net Guest
Posted: Mon Jun 04, 2007 11:02 am Post subject: Rocky Mountain route: Noob question |
Preliminary look is that it is low for an RV. I would plan on flying high using
oxygen because in some areas the terrain is not conducive to an off-field landing.
Will assess it more later. PS, 11,500' is my typical LOW flying altitude.
From ABQ you should be fine. Just get over the mountains east of ABQ.
Ron Lee
n801bh(at)netzero.com Guest
Posted: Mon Jun 04, 2007 2:23 pm Post subject: Rocky Mountain route: Noob question |
Fly as much as you can in the early mornings, give yourself 1000+ over any ridgetops and enjoy the scenery. Weather for this weekend looks kinda iffy, that's if the front spinning in from the NW can knock down the present high pressure we have sitting over us for the past two weeks. My bet is it will get deflected and you guys will have a great time. Fly safely.
Ben
Jackson Hole Wy
Ben Haas
N801BH
www.haaspowerair.com
-Stormy
tronics.com
rtitsworth
Posted: Mon Jun 04, 2007 2:35 pm Post subject: Rocky Mountain route: Noob question |
Do you have a G396. G496, or other XM weather system? The wx can change dramatically throughout the day out west (including wind/turbulence), and bailout airports are sometimes further apart and/or on the other side of adjacent terrain. Perhaps not a requirement, but certainly a “nice to have”, especially when traversing long distances.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill Boyd
Sent: Monday, June 04, 2007 12:49 PM
To: rv-list(at)matronics.com
Subject: RV-List: Rocky Mountain route: Noob question
I'm part of the gaggle from the SouthEast RV group headed to Yellowstone this weekend…. [quote] [b]
Posted: Mon Jun 04, 2007 4:19 pm Post subject: Rocky Mountain route: Noob question |
By that I meant that the RV can get well above terrain easily.
One suggestion. From U34, consider heading to Monument Valley.
Around 110 degrees, 10 minutes west and 37 degrees, 3 minutes north.
Then head west just south of Navajo Mountain to Page.
Disregard, Do that on your flight from Page to FMN. Less out of your way
and most likely earlier in the day. Then circle around four corners
(Utah, NM, CO, AZ). You will see Shiprock NM almost straight ahead on
your way to FMN.
From there you can head to Santa Fe (KSAF) then pick up the expressway
eastbound south of Las Vegas NM (KLVS) then on east. If you are feeling
adventurous, direct from KSAF to KLVS would get you over some
mountains with lower terrain to your right. No need to go south to ABQ unless
you want to but you are close when near KSAF.
Miami Co Kansas (K81) had cheap fuel and good BBQ on field when I was
there a year ago if that is on your way.
Ron Lee
skydive80020(at)yahoo.com Guest
Posted: Mon Jun 04, 2007 5:28 pm Post subject: Rocky Mountain route: Noob question |
Last week I flew from Longmont (just north of Denver ) direct to Las Vegas in my 6A. 13'500 over the continental divide and the remainder of the route and area north can be handled at 11"500. Easy flight in an RV, I agree though mornings will help you avoid thunderstorms that we get off the mountains almost every afternoon.
Mark Phipps, N242RP, Gypsy Spirit
"n801bh(at)netzero.com" <n801bh(at)netzero.com> wrote:
[quote] Fly as much as you can in the early mornings, give yourself 1000+ over any ridgetops and enjoy the scenery. Weather for this weekend looks kinda iffy, that's if the front spinning in from the NW can knock down the present high pressure we have sitting over us for the past two weeks. My bet is it will get deflected and you guys will have a great time. Fly safely.
Ben
Jackson Hole Wy
Ben Haas
N801BH
Leaving the Grand Canyon area via KPGA;KFMN;KABQ;KDDC looks like an effortless [quote][b]
Posted: Mon Jun 04, 2007 5:57 pm Post subject: Rocky Mountain route: Noob question |
Another option to get a bit of a feel for the Rockies is once you
pass four corners, head east to Pagosa Springs (KPSO), previously 2V1.
Then go over Wolf Creek Pass just a bit left of a direct line from KPSO to
Del Norte (8V1).
Then a direct line from 8V1 to La Junta CO (KLHX) will take you over the
Great Sand Dunes National Monument. Fly over the passes there and east to
flat country.
Ron Lee
Posted: Tue Jun 05, 2007 6:00 am Post subject: Rocky Mountain route: Noob question |
Just so you know, the alternate routes I suggested
have you over mountains for short periods. I avoid
extended time over places with no landing options.
Ron Lee
lsbrv7a(at)yahoo.com Guest
Posted: Tue Jun 05, 2007 8:57 am Post subject: Rocky Mountain route: Noob question |
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
From Cody one can climb to 10,500 and cross over <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />Yellowstone, 90 nm. That is high enough that it will not be too much bother as you see Old Faithful and the other geysers. Turn south to Driggs, KDIJ, and dine on the patio watching aircraft arrive and depart with the Teatons in the background. Restaurants are also at Ogden.
EAA 407 is having a camp-in and breakfast at KWYS in August.
If you want to visit the Grand Canyon area you can continue on down the west side of the Rockies past Salt Lake City down to St. George and the Moab – Zion area. If you want to cross back to Rock Springs, it is relatively low turning east from Bear Lake, 1U7, to Evanston.
Bill Boyd <sportav8r(at)gmail.com> wrote: | Quote: | I'm part of the gaggle from the SouthEast RV group headed to Yellowstone this weekend. I have no mountain flying experience save what little you get living and flying in the Appalachians the past 15 years.
Sherman Butler
RV-7a Wings
Idaho Falls
Looking for earth-friendly autos?
Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center. [quote][b]
