andygold(at)rkymtnhi.com Guest
Posted: Sun Jun 03, 2007 11:33 am Post subject: Garmin 196 help |
I just installed a Garmin 196 in place of my old Garmin 90. I liked the 90. It did everything I wanted it to do perfectly and simply for day VFR navigation. Just enter where you want to go and follow the arrow and it always took me right over the center of the destination airport. (I never used the map page) The only reason I gave it up was because the database was 5-6 years old and I couldn't get an update.
So, I bought a 196. With all the raving about it here and on other web sites, I looked forward to seeing how great it really was. (for what I use it for I couldn't imagine how it could be any better, but at least its updated with the new maps and AFDs)
Bottom line is the 196 has a really bad quirk that I don't like at all, enough that if I can't find a solution I'm going to pull it out and reinstall the relic 90. Following the arrow to a destination works great from a distance, but when I get within about 10-15 miles from the destination the arrow starts to skew over one way or the other. In other words the arrow says that the destination is 30 degrees over to the right, but I know the airport is straight ahead over the ridge. As I get closer, this displacement gets worse and worse. If I pass the airport the 196 does no correct. It keeps telling me to go straight or in the completely wrong direction. If I pass the airport with the 90, the arrow points to the tail, tells me to turn around and then guides you directly there, just like it should. This was an issue flying into Craig, CO a little while ago. I was unfamiliar with the area, so I trusted and followed the 196, right past town with the Garmin telling me to keep flying straight. I had to climb a couple thousand feet for a better view, circle around, and find the airport the old fashioned way.
My question is for others flying a 196. Does yours do the same thing, or does your heading indicator trustfully point to your destination from wherever you are and from whatever direction your nose is pointed? Or, do I have a bad unit? Or do I need to somehow program out this glitch, or do I not know what I'm doing and need some dummy's book on how to use a GPS?
Andy
stein(at)steinair.com Guest
Posted: Sun Jun 03, 2007 12:35 pm Post subject: Garmin 196 help |
Hi Andy,
I'm not really sure which "arrow" you're referring to? is it the HSI/DG page?
I've been using my old 196 for years and it's been super accurate the whole time (even driving my autopilot).
The other question is why don't you use the map page? If you put in a "Direct To" to where you're going you just follow the line....no "arrow" to worry about?!?!
Cheers,
Stein.
[quote] --
jrdial(at)hal-pc.org Guest
Posted: Sun Jun 03, 2007 12:51 pm Post subject: Garmin 196 help |
I have no problem with mine so you are either doing something wrong or there is a problem with that unit.
DO NOT ARCHIVE
Larry Bowen
Posted: Sun Jun 03, 2007 1:00 pm Post subject: Garmin 196 help |
You can "follow" the arrow and still be left/right of course. Are the top middle and bottom of the arrow all aligned? Or is the center section of the arrow off to the left (for example) -- showing you are right of the direct course?
Larry Bowen
Larry(at)BowenAero.com (Larry(at)BowenAero.com)
http://BowenAero.com
On 6/3/07, SteinAir, Inc. <stein(at)steinair.com (stein(at)steinair.com)> wrote:[quote] Hi Andy,
Cheers,
Stein.
[quote] --
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Andy,
I think you could make the 196 do as you described if you were to use the cursor to point to a destination on a small scale (zoomed out) map and hit the goto button. What would be happening is that the 196 would be taking you to some point that from a long distance looked like the destination, but as you got closer proved to be some distance away that wasn’t obvious at the small scale. The solution would be to either enter the airport identifier as the destination or to zoom in to it at a large scale to pick it from the screen.
Other than that, I don’t have any suggestions. I haven’t flown much with my 196 recently so I may be missing something.
Terry
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Andy Gold
Sent: Sunday, June 03, 2007 12:31 PM
To: rv-list(at)matronics.com
Subject: Garmin 196 help
Andy
| Quote: | | http://www.matronics.com/Navigator?RV-List | 01234
pilots2(at)yahoo.com Guest
Posted: Sun Jun 03, 2007 1:34 pm Post subject: Garmin 196 help |
The 196 has a Aviation , Land and Water mode. Go into the menu and check out the "Operating Mode" I suspect yours may not be in the "Aviation Mode".
Reuven Silberman
N7WT RV7A
"J. R. Dial" <jrdial(at)hal-pc.org> wrote:[quote] <![endif]--> Clean Clean DocumentEmail MicrosoftInternetExplorer4 <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} <![endif]--> <![endif]--> <![endif]-->
DO NOT ARCHIVE
ronlee(at)pcisys.net Guest
Posted: Sun Jun 03, 2007 2:00 pm Post subject: Garmin 196 help |
Leave it to me to ID the possible cause. I only know of this from others
and NOT personal experience. See if it makes a difference if you input
the destination identifier that you put "K" in front of airports. (Does not
apply if numbers are in airport ID)
Example: LAA is a VOR whereas KLAA is the nearby airport.
Ron Lee
d-burton(at)comcast.net Guest
Posted: Sun Jun 03, 2007 2:18 pm Post subject: Garmin 196 help |
[quote]Hi Andy, Are you using the HSI page? You do have to watch the “to/from” arrow. If you fly past your destination the TO arrow flips to FROM which is not too obvious at a glance. A quick look at the “distance to destination” and you’ll see there are only dashes since you are past your destination. I’m not sure what the other inaccuracy you are seeing is all about. Hope some of the other suggestions help! Dave[b]
Posted: Sun Jun 03, 2007 2:25 pm Post subject: Garmin 196 help |
It's showing that I'm left or right of what the direct course would have been, either because I detoured around terrain or because the RV is just so much fun to fly that we'll play around a bit on the way to where we're going.
But that shouldn't matter. At least it didn't with the Garmin 90. I know this may be heresy to some, but I don't really care where I am relative to what the straight line course would have been. I only care where my destination is relative to where I'm at now. I'd like to trust that when the GPS is locked into an official airport identifier that that's where its going to point to.
I can always beg forgiveness from the chief pilot (my wife) or the accountant (my wife) later for burning too much fuel or spending to much time flying.
Stein says just fly with the map page instead. That may well be what I have to do, but I'll miss the simplicity of just following the little arrow.
Andy
Posted: Sun Jun 03, 2007 2:38 pm Post subject: Garmin 196 help |
Hi Andy,
Just hit “goto” “enter” and the arrow will be well behaved again… for a while, if you behave.
Dave
Sent: Sunday, June 03, 2007 3:25 PM
Subject: Re: Garmin 196 help
Andy
mkellems(at)bellsouth.net Guest
Posted: Sun Jun 03, 2007 2:45 pm Post subject: Garmin 196 help |
Andy, That was the one thing I missed when going from the 90 to the 196 and then 296... The arrow does not function the same. I always liked doing an NDB approach with the 90. You'll get used to not having it and enjoy the 196 before long. Mike
randy(at)romeolima.com Guest
Posted: Sun Jun 03, 2007 2:46 pm Post subject: Garmin 196 help |
Do you have it set to "Track up"?
Randy Lervold
Posted: Sun Jun 03, 2007 4:29 pm Post subject: Garmin 196 help |
Actually my initial guess may not be correct. If you use the map function is helps
provide situational awareness and may clue you in to what is wrong. I doubt that
the GPS unit is bad.
Ron Lee
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Mon Jun 04, 2007 1:46 am Post subject: Garmin 196 help |
So then what is the arrow pointing to?
A township rather than the airport?
Doug
On Sun, 2007-06-03 at 17:44 -0500, Chopper wrote:
[quote] Andy, That was the one thing I missed when going from the 90 to the
LloydDR(at)wernerco.com Guest
Posted: Mon Jun 04, 2007 6:12 am Post subject: Garmin 196 help |
The way to do what you are wanting to do is after you are done with your side trips is to hit the direct to button, it will update your course and give you the current course to where you are going. If you enter a flight plan, it will always have the original plan in there and will give you directions to intercept that course, so it is working as programmed, you are just having to much fun of course for it!
Dan
N289DT RV10E
Sent: Sunday, June 03, 2007 6:25 PM
Andy
rocketbob(at)gmail.com Guest
Posted: Mon Jun 04, 2007 7:21 am Post subject: Garmin 196 help |
I have my 196 set up to show Turn as one of the displayed fields on the map page, which is much more useful than the arrow. It will tell you exactly how much left or right to turn to stay on course. For normal flying I prefer the 196 over the 396, a transflective monochrome display is much easier to read in the bright cockpit of an RV. Less glare also. I'd love to see a monochrome version of the 396.
Bob Japundza
RV-6 flying F1 under const.
