bobbyhester(at)charter.ne Guest
Posted: Mon May 28, 2007 5:18 am Post subject: Nose gear lube |
My swiveling nose wheel has gotten jerky. Will just squirting a few
shots of grease in the zert fitting take care of this or do I need to
take it all apart clean, grease and reassemble? 65 hrs. on it.
Surfing the web with my laptop from Hopkinsville, KY
Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm
denis.walsh(at)comcast.ne Guest
Posted: Tue May 29, 2007 5:19 am Post subject: Nose gear lube |
I would recommend not squirting anything in the grease fitting. Long
a go there were reports of excess grease melting/oozing down on the
bell washer and giving you the shakes on landing. Haven't heard much
lately.
Have been slathering a little #5 grease on the wear points after
dissassembly and put it back together, once a year.
Has worked ok for my first 3,300 landings.
P S check the big washers for burrs. Jerky is not usual. Be sure
and adjust tension for prescribed break out force.
Denis Walsh
On May 28, 2007, at 07:17 262740005, Bobby Hester wrote:
to take it all apart clean, grease and reassemble? 65 hrs. on it.
MyFlyingRV7A.htm
Posted: Wed May 30, 2007 7:39 pm Post subject: Nose gear lube |
I took it apart cleaned it up and lubed it real good, no more herkie
jerkies, nice and smooth
Bobby Hester wrote:
