ppeerenbo(at)charter.net Guest
Posted: Mon May 28, 2007 11:56 am Post subject: 912UL not Starting |
Need some help with a 912UL 300TT not starting after being off for a year.
Have fuel at the carbs cleaned and new diaphragms installed. I can put my hand over the carb inlets and turn it over and get lots of fuel. Getting very weak spark and has only fired once or twice in hours of testing. Eng turning over well (have jumped it ) I am looking if anyone knows what the voltage outputs from the CDI boxes to the ignition coils should be? I have 8 volts wile cranking at the red generator ignition circuit cables circuit to ground ( both the same ) I get about 12 to 13 volts to the coils is this correct or too low? I have the old style interference box but new style plugs. ( I replace them for something )
Paul Peerenboom
Kitfox IV 912UL 300TT
jwdfly
Posted: Mon May 28, 2007 3:19 pm Post subject: 912UL not Starting |
Check your valve clearance, Do not know much about 912's ,but do know about four strokes.
Roger Lee
Posted: Mon May 28, 2007 4:59 pm Post subject: Re: 912UL not Starting |
Hi Paul,
First thing is try it with a new battery. The 912 must turn the prop at least 225 rpm for it to turn turn over. It may sound ok to you, but may be under the 225 rpm. Did you pull the main and idle jets and physically clean them? If you need to test the prop rpm you can use a jumper cable and a car battery. This will give you the cranking power to test the prop rpm. Use of the choke lever only adds more fuel and is not a true choke. Do not add throttle when choking the engine. That being said I have had to just barely crack the throttle on a few to get them started. I said only crack the throttle. Let me know how the next starting attempt turns out.
You can go online under Rotax or Kodiak and go under tech info and print out the line main and the heavy maint manuals. they will tell you how to test electrical components and what their values are.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Roger Lee
Posted: Mon Jun 04, 2007 6:35 am Post subject: Re: 912UL not Starting |
Did you find your problem?
Tucson, Az.
Cell 520-349-7056 |
