romott(at)adelphia.net Guest
Posted: Thu May 24, 2007 6:00 am Post subject: Flighttech Intercom & Microair 760 |
I have been helping a friend who owns a Zenith 601 with Flighttech ITC-402P and Microair 760 which would not function properly. The intercom would work fine, radio transmissions could be received, but the transmit function was weak or non existent.
After bunches of trouble shooting, rewiring, returning both units to have them analyzed for problems (twice!!!), we finally got them working. Rick Lord at Erie Avionics http://www.erieaviation.com/ figured out what the problem was. He wired the radio and intercom together and noted that the Flighttech was not pulling the PTT line down to ground as required by the Microair. Rick added a couple of diodes and fixed the problem.
If you are having similar problems, contact Rick Lord at Erie Avionics or http://www.flighttech.com/contact_us.htm
THANKS to Rick Lord for his patience and finally figuring this out!!!!!
Ronnie Brown
klehman(at)albedo.net Guest
Posted: Thu May 24, 2007 5:10 pm Post subject: Flighttech Intercom & Microair 760 |
Ron
I mentioned awhile ago that Flightech knows of this issue with their
older intercoms due to a track error on the circuit board. The diode is
there but wired incorrectly and they should be able to tell you how to
install one jumper wire or repair it for you. Their schematic is
correct but the board has an error. I believe I had to lift one end of
the problem diode and jumper it to the correct place but it was quite
some time ago that I did it.
Actually my board also had a second error that prevented the warning
audio from my EIS from feeding through but they are also aware of that.
I really like the intercom and flightech was easy to work with.
I think that every electronic unit that I purchased had an issue or two
to work through regardless of the manufacturer.
Ken
Ron Brown wrote:
| Quote: | I have been helping a friend who owns a Zenith 601 with Flighttech
Ronnie Brown
