darinh
Posted: Mon May 21, 2007 11:40 am Post subject: Straight Breakers vs. Breaker Switch? |
I am figureing out my panel and was wondering what everyone has done when it comes to breakers and breaker switches? I am thinking about using straight breakers on the avionics with them being tied to the avionics master and then using breaker switches on things like landing lights, navs, strobes, heater, etc. What have you guys done?
Darin Hawkes
Series 7 (in progress)
dosmythe(at)cox.net Guest
Posted: Mon May 21, 2007 12:02 pm Post subject: Straight Breakers vs. Breaker Switch? |
It was once stated many years ago here that if a breaker/fuse trips you most
likely have a serious problem and it will not reset anyway. In the interest
of cost, I installed the more robust automotive blade type fuses. To date,
I've never had one blow (about 8 years).
Don Smythe
andynfultz(at)bellsouth.n Guest
Posted: Mon May 21, 2007 12:10 pm Post subject: Straight Breakers vs. Breaker Switch? |
I'm doing as Don did. He failed to mention that it is a bunch less
expensive this way also.
Andy Fultz
john(at)leptron.com Guest
Posted: Mon May 21, 2007 12:22 pm Post subject: Straight Breakers vs. Breaker Switch? |
Darin,
That is about as complicated a question as the gross weight thing....
There is a thought ,(not agreed by all) that the breakers are a distraction
and should be installed not in an accessible place in flight.
NASA and many others have studied this ... so my suggestion is to install 2
automotive breaker boxes under the dash. One is the main system, lights,
master, avionics, ect. The other is the actual avionics breaker box. This
box is controlled by the avionics sw and a 30 amp or so relay to liven up
the avionics. One master breaker button to protect the whole thing. That
breaker is thrown when the over voltage protector is livened up. A simple
system works great and easy to deal with if something goes awry. This is the
way I wired my system and you can look it over to see if you like the idea.
Gee, I also have lipo battery packs for backup.
John Oakley
Posted: Mon May 21, 2007 12:23 pm Post subject: Straight Breakers vs. Breaker Switch? |
Don,
I am glad to see you still on the list; I have a lot of respect for you and
your experience.
John Oakley
lcfitt(at)sbcglobal.net Guest
Posted: Mon May 21, 2007 2:19 pm Post subject: Straight Breakers vs. Breaker Switch? |
Darin,
I put in the Potter and Brumfield Push Pull circuit breakers. I liked the
simplicity of checking systems during annuals, but really not much of a
benefit over what Don suggests. I have never pulled one in flight, but did
have one accidentally pull once as I was removing something from the
passenger seat. I think it was my camera with the strap that hooked the
knob and pulled it. It was the power to my video camera set-up and caused a
moments consternation as I tried to determine - on the ground - why my
camera suddenly stopped working. This project has been a work in progress
for about five years and occasionally it will hiccup with lots of time spend
debugging it.
Lowell
dan(at)azshowersolutions. Guest
Posted: Mon May 21, 2007 3:38 pm Post subject: Straight Breakers vs. Breaker Switch? |
Darin,
Sometimes it's good to see others that are scratching their heads building as I am. I too had many questions as to the best way to wirre the panel so I went to one of Bob Nuckols seminars. This is his web address http://www.aeroelectric.com/
Look over his web site and think strongly about purchasing his book as it has many wiring schematics that are simply done. If you are hooking up a Rotax 912s it has that covered. You have already received good advice from those on this list...Bob is an advocate of not using breakers for good reasons. The book Aeroelectric Connection covers these philosophies well.
Happy Wiring,
Dan Billingsley
Mesa / KF-IV 912s / N314DW / Building
Float Flyr
Posted: Mon May 21, 2007 3:48 pm Post subject: Straight Breakers vs. Breaker Switch? |
I've been reading the mail on this one. And It is obvious that the type of circuit protection is a personal convenience. For example I fly floats in remote locations. Circuit breakers are a nice convenience, should I ever experience a short circuit the popped breaker will make it much easier to locate. Automotive blade type fuses would provide an equal level of protection without the ability to easily unload circuits selectively in flight. My plane has a whopping great five circuits drawing a total of about 10 Amps peak current. Carrying a reasonable supply of spares is also a good idea. Circuit protection is sort of like an insurance policy.... I'm betting I'll need it and the electronic component manufacturers are betting I won't.
The important thing to me is not so much what protection you use but where you install it. My advice on that item is to install your protection as close to your busses as possible. Several certified aircraft actually install the breakers directly on the busses. That gives the most protection for everything down stream of the buss. Therefore it is also important to install some protection for the busses them selves too. A good healthy fusible link right on the positive terminal of the battery ( not the starter circuit ) will protect all the busses that line feeds. You will also want to install some current protection between your alternator and your battery or main buss.
The last item is neatness. You will have to look at the set up of your electrical system for many hours of enjoyable flight so you should make the installation so it looks neat. Remember if you use the blade fuses to give enough room to easily extract and replace fuses. Auto resetting relays(breakers) like used on automotive headlights should be reserved for that application and with the exception of the Dukes of Hazzard be kept out of the air..
[img]cid:946294623(at)21052007-2DFD[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
Description: |
Filesize: |
19.77 KB |
Viewed: |
442 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Mon May 21, 2007 4:24 pm Post subject: Straight Breakers vs. Breaker Switch? |
Dan,
Good advise on using Bob Nuckolls book and information. You may not remember,
he was once was on this list. Good info and supplies, I have his over voltage protection and many of his tools.
John Oakley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Dan Billingsley
Sent: Monday, May 21, 2007 5:38 PM
Subject: Re: Straight Breakers vs. Breaker Switch?
Darin,
Happy Wiring,
Dan Billingsley
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Tue May 22, 2007 9:20 am Post subject: Re: Straight Breakers vs. Breaker Switch? |
+1 on the Bob Nuckols website and guidance, especially these days in airplanes with electronic ignition or fuel control. Unlike the days where the mags would keep the fan turning, circuit design has become truly important even for VFR airplanes. For example, the Diamond diesel twin was just AD'd after a couple of flight instructors took off with near-dead batteries and found that retracting the gear reduced the buss voltage enough to kill the controls for BOTH engines.
Circuit protection, be it CB or fuse, is not a personal convenience. The protection is sized to protect the wire used, NOT for whatever is at the end of the wire. I've seen shorted wires light paper scraps and lint on fire. Non-aviation wire insulations can actually catch fire or melt off, posing their own hazard. The other thing that is often ignored is that the CB or fuse provides a last-ditch chance to kill a circuit manually. If the contacts in the switch for your electric trim just failed in the closed position, you would probably want to be able to pull the breaker ASAP.
A&P, Aero Eng
Series 5 Vixen in-work
Gaithersburg, MD
_________________ Remember that internet advice may only be worth what you pay. |
n85ae
Posted: Tue May 22, 2007 10:14 am Post subject: Re: Straight Breakers vs. Breaker Switch? |
Use little fuses, and big wires, and chances are you'll never have a fire,
plus they rarely ever break for no reason.
Use switch breakers if you like changing parts all the time. These things
are garbage at best. At least the ones I have seen.
Use regular breakers if you like replacing parts on occasion. I changed
a bunch of these when I was in the Navy, a BUNCH. They break a lot.
Jeff Hays
darinh
Posted: Tue May 22, 2007 12:15 pm Post subject: Re: Straight Breakers vs. Breaker Switch? |
Great info guys! I have ordered the Aeroelectric book from Bob so hopefully that will set alot of this straight in my head.
Darin Hawkes
crazyivan
Posted: Tue May 22, 2007 2:49 pm Post subject: Re: Straight Breakers vs. Breaker Switch? |
Solid advice on this thread. The only thing I disagree with is John's (no offense intended) recommendation about putting automotive breakers under the dash.
Automotive fuse boxes are made from plastic (or some sort of non-aviation polycarbonate) and automoticve grade wire. If this catches fire then you'll have some toxic fumes quickly accumulating.
As for mounting it under the dash, if you lose some equipment or suspect an electrical problem, being able to see which breaker tripped greatly aides in troubleshooting your in-flight malfunction/emergency.
Again, no offense John. This is just my opinion and it's worth the proverbial 2 cents.
_________________ Dave
Piper PA-22/20 |
Posted: Tue May 22, 2007 3:12 pm Post subject: Straight Breakers vs. Breaker Switch? |
I agree that being able to get to the fuse box "might" be helpful in flight.
See the attached pic of my panel. On the far right you see a rectangular
area in the face of the instrument panel. There is a small knob at the top
that opens the door. Behind the door are the automotive blade fuse holders.
There are also extra fuses in that area. You can open this door in flight
and get access to the fuses. There is also an emergency bypass switch
behind the door that will bypass the master solenoid if that solenoid should
fail in flight. You can regain connection from the battery to the main buss
if the solenoid fail.
Don Smythe
Description: |
Filesize: |
148.99 KB |
Viewed: |
452 Time(s) |
n85ae
bajtme(at)verizon.net Guest
Posted: Wed May 23, 2007 12:58 pm Post subject: Straight Breakers vs. Breaker Switch? |
Don Smythe <dosmythe(at)cox.net> wrote: [quote]I agree that being able to get to the fuse box "might" be helpful in flight.
Don Smythe
smokey_bear_40220(at)yaho Guest
Posted: Wed May 23, 2007 5:11 pm Post subject: Straight Breakers vs. Breaker Switch? |
I spent a lot of time on my panel arrangement. My
main buss runs along the bottom of the panel and
directly to each fuse or C/B, then up to the item to
be controlled or protected. If a gauge fails, you can
look immediately, in time and place, below for the
fuse.
I ran a verticle buss down to the counsel. There you
will find things like my trim C/B, trim gauge and trim
switch. No need to look for the C/B or fuse if you
get runaway trim. You can immediately grab and pull
the C/B. Also I wired it so counter-trimming should
trip the C/B as an immediate action item.
Some items are not realted to gauges. For example, I
put a C/B switch to the right of my throttle for the
landing light. On and off with your thumb while still
on the throttle. It is a flat faced rocker switch,
not one of those pin head C/B's that mess you up in an
accident when your face hits it.
Not electrical, but the throttle is below the MP
gauge. The prop control is below the Tach. The
mixture control is below the EGT and Fuel/Air ration
gauges. I was planning for old age, I guess.
There is a main buss C/B and 2 seperate battery
circuits with masters. Either can power the main buss
and both can be turned off in flight to isolate a
fire, leaving 2 essential busses for ignition and fuel
pumps thru seperate C/B's.
I think the only under panel fuse I have is for the
alternator field circuit.
I actually enjoyed planning it out and playing with
cardboard and stickons until I got it good enough.
Still, I have fuses, C/B's, and C/B switches to make
it functional. While I planned for ease of flow, easy
operations and emergencies, I may have introduced
weaker parts to make it happen. It was a compromise,
but one that I felt would protect itself and me pretty
well, so I guess I like it.
Panel pic available on request. (It is too many KB's
to attach here.)
Kurt S.
S-5/NSI turbo
Florida and panama
http://mobile.yahoo.com/go?refer=1GNXIC
Float Flyr
Posted: Thu May 24, 2007 7:02 pm Post subject: Straight Breakers vs. Breaker Switch? |
I can heartily agree with Bob Nuckols reasons for liking fuses over breakers...but removing blade fuses and even locating blown circuits while trying to fly a plane can be interesting. Breakers give the control/visual cues I prefer.
As for your comments on wire size, burning, Etc. Right on! The wire sizes should be chosen for de-rated current draw. This means that there should be no splices into wires to power any one of numerous frivolous devices. If you really need it add an extra protected circuit. Make sure that all your wiring is protected... most certified aircraft will actually have one side of the buss attached directly to it's buss so the whole circuit is protected.
Having worked with both coloured wires and certified white wiring I now feel much more comfortable with the white wiring. The wires themselves are manufactured to more exacting tolerances. The insulations are less likely to burn and are much more rugged. There are many shielded cables available in different sizes. Finally the wire charts in AC 43 will work with certified wire... I don't think I can say the same thing about automotive style wire in its myriad of Sesame Street colour.
[img]cid:855291502(at)25052007-0421[/img]
Canada
Aerocet 1100s
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
394 Time(s) |
Kitfox III-A
vft(at)aol.com Guest
Posted: Thu May 24, 2007 8:52 pm Post subject: Straight Breakers vs. Breaker Switch? |
You don't need to restrict yourself to the color white if you want to use the higher quality Tefzel wire. It is available in just about any color including multi color. As to fuses vs breakers, I have wired quite a few airplanes and have done it both ways depending on what the owner wanted. The auto type blade fuse blocks work very well and result in a clean, light, and simple system. Never mine being able to reach them during flight. If you have designed your electrical system correctly there should never be a need to replace them while flying. For both of my own projects I chose to use a combo of switched and pull type breakers cause that's what I wanted. The important things to keep in mind are to use quality components, think through the most likely failure modes, and don't forget you will need to service something years from now. The first and last items are what frustrate folks most often. Usually in the form of a poor quality component at the end of a wire that's too short and unreachable.
Danny Melnik
F1 #25
Melbourne (FL) Rocket Factory
Ex owner of N24ZM series 5 Safari
Description: |
Filesize: |
19.77 KB |
Viewed: |
421 Time(s) |
Lynn Matteson
Posted: Fri May 25, 2007 2:31 am Post subject: Straight Breakers vs. Breaker Switch? |
Not to rub in your obvious pain of being the "Ex owner of N24ZM
series 5 Safari " , but I'm heading out west on Monday (hopefully)
to among other things, visit the latest owner of N24ZM...I'll give it
a pat on the cowl for you....she's a beauty! : )
Lynn Matteson
flying w/293+ hrs
On May 25, 2007, at 12:51 AM, vft(at)aol.com wrote:
Quote: | You don't need to restrict yourself to the color white if you want
Danny Melnik
F1 #25
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
