carl(at)flyers.freeserve. Guest
Posted: Mon May 21, 2007 11:46 pm Post subject: Oil Pressure Sender |
With aapologies if this message gets posted twice - see below
Well its finally happened, my oil pressure sender is giving up the ghost. It
registers 85psi most of the time when the pressure should be nearer 50.
So I thought time to replace and checked out Skydrives current price list
£140 ****ing quid. When I recovered from the shock, I then did an internet
search and guess what.
Sonex (USA) - genuine VDO replacemet $35
ETB instruments - VDO but different connections (two instead of one) - £28
Anyone had the same experience?
I would habe been happy to pay £50 for the "genuine article" but a markup of
500% - Skydrive (UK) you have got to be taking the piss !
Also whats the best way of remotely mounting the sensor so it isnt affected
by vibration - I know this subject has been extensively covered before.
Carl Pattinson
G-LABS
pete(at)lawless.info Guest
Posted: Tue May 22, 2007 12:30 am Post subject: Oil Pressure Sender |
Carl
Demon Tweaks (race and rally cars bits) sell the VDO gauge for £44, I can't
spot the sender in the catalogue but they must have it to go with the gauge.
Worth a call 01978 664466 or www.demon-tweeks.co.uk . I have bought all
sorts of odd bits from them and they are very slick with delivery.
Pete
pjeffers(at)talktalk.net Guest
Posted: Tue May 22, 2007 12:32 am Post subject: Oil Pressure Sender |
I had exactly the same experience with a VDO oil Px sender. £130 odd + Vat +
delivery from Skydrive and $35 in the States incl delivery to UK. Oh and it
arrived in less than a week!!!
Pete Jeffers
Posted: Tue May 22, 2007 12:53 am Post subject: Oil Pressure Sender |
I will certainly put Demon Tweaks on my list.
The people I was referring to ETB are mainly bike and race car but they seem
to have all the Guages and sensors we use in the Europa and all at very
reasonable prices.
http://www.etbinstruments.com/Sensors_ancillaries.htm
The oil sender they stock is the two pin variety which I understand is the
one reccommended for use with the flydat. Presumably all that is required is
to earth one of the terminals - shouldnt be too difficult to figure with an
ohmmeter.
Alternately they may be able to supply the normal one with one connection.
They list a single connection sensor but only up to 5bar pressure. The Rotax
one needs 10bar.
I will try and give them a ring.
Posted: Tue May 22, 2007 1:15 am Post subject: Oil Pressure Sender |
Correcton to the last message.
Just spoken to ETB and the sender body is earth. The two terminals are for
the pressure guage and the other a warning light - presumably shorts to
earth when there is no oil pressure.
Posted: Tue May 22, 2007 1:17 am Post subject: Oil Pressure Sender |
Hi Carl
Demon listed both low and high range VDO gauges in the catalogue and I
noticed after I sent the first mail they said they held a lot of VDO bits
not listed and to call with your requirements.
Let me know what you manage to get - if the cost is sensible I may well get
one in as a spare.
Pete
peter.rees01(at)tiscali.c Guest
Posted: Tue May 22, 2007 1:42 am Post subject: Oil Pressure Sender |
Paul Sistern has them on his website for £30 - £50 depending on which
one you want: www.partsforaircraft.co.uk/
You could get on from Spruce but by the time you've paid postage etc,
you may as well buy it from Paul and get it a lot quicker.
Peter
___________________________________________________________
Tiscali Broadband only £9.99 a month for your first 3 months! http://www.tiscali.co.uk/products/broadband/
