rlborger(at)mac.com Guest
				 Posted: Sat Feb 11, 2006 6:35 am    Post subject: Propeller Discussion |
				Fellow Europaphiles:
 My 2-bits, for what it's worth.
 I like the WhirlWind propellers.  Decent price for the 2-blade
 version.  The 4-blade would look so sexy on the Europa, like a mini-
 Spitfire.  (If you want to put out the extra $5K or so)
 As you can see below in the signature block, I've bought an
 Airmaster.  Reason:  Airmaster is electrically controlled.  WhirlWind
 is hydraulic controlled.  The hydraulic controller has to be mounted
 where my 2nd alternator is mounted.  Choice:  2nd alternator or
 hydraulic controller.  With my all-electric panel and IFR setup, I
 had to go with the 2nd alternator.  If I went simple daytime, VFR
 (which will probably be 95% of my flying anyway) and vacuum gages, I
 might have been able to get away with the Europa electrical system
 and could have gone WhirlWind hydraulic C/S prop.
 Like I said, just my 2-bits for what it's worth.  Please don't anyone
 follow my lead, just because I've tried it.  I still don't know how
 it will work as I'm still months and months and months away from flying.
 Good building and great flying,
 Bob Borger
 Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
 http://www.europaowners.org/N914XL
 (85%) tail kit done, wings closed, cockpit module installed, pitch
 system in, landing gear frame in, rudder system in with Singleton
 Mod, outrigger mod in, Fuselage Top on, lift/drag/flap pins in, wing
 incidence set, tie bar in, flap drive in, Mod 70 done, baggage bay
 in. Completing the firewall-aft fuel system and fitting the
 instrument panel.  Working in - 24 Instrument Panel, 25 Electrical,
 28 Flaps, 29 Main Gear, 30 Fuel System, 32 Tail, 34 Door Latches & 35
 Doors, 37 Finishing.  Airmaster arrived 29 Sep 05.  Seat arrived from
 Oregon Aero.  Preparing ROTAX 914 for installation.  Singleton
 firewall mod has arrived.
 3705 Lynchburg Dr.
 Corinth, TX  76208
 Home:  940-497-2123
 Cel:  817-992-1117
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
