effectus(at)rogers.com Guest
Posted: Fri May 18, 2007 4:40 pm Post subject: Battery Charger |
Hi Everyone,
A little while ago someone posted something about a good battery charger that was available through Walmart under a different name. I am getting to the point where I want to start charging my batteries and I can't find the reference to the charger.
Dave Hertner
#40164
Working on wing guts!
Description: |
 Download |
Filename: |
David_R._Hertner.vcf |
Filesize: |
753 Bytes |
Downloaded: |
333 Time(s) |
LarryRosen
Posted: Fri May 18, 2007 5:48 pm Post subject: Battery Charger |
From Tim:
I purchased a Schumacher SC-2500A
<http://store.schumachermart.com/25ampchsc.html> charger (actually I
bought the WM-2500A...Wal-Mart's model number for that charger..
read it here <http://www.myrv10.com/N104CD/upgrades/20070401/index.html>
I have the battery tender jr, as do others and it works fine, but it
does not have the volt read out that the Schumacher has.
Larry
Dave Hertner
#40164
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Tim Olson
Posted: Fri May 18, 2007 6:37 pm Post subject: Battery Charger |
David,
It may have been me...not sure.
Here's a link
Dave Hertner
#40164
Jim & Julie Wade
Posted: Sat May 19, 2007 2:55 am Post subject: Re: Battery Charger |
I have used the battery minder on the last 3 planes I have had. It works great. I ran the plugin into the baggage area and plug it up when it is parked. You can even boost from the plug of you have to.
http://www.vdcelectronics.com/
Jim & Julie
40383
N369JW 95 Hours
Tim Olson
Posted: Sat May 19, 2007 5:40 am Post subject: Battery Charger |
I had looked long and hard and was jut about to buy Battery
Tender/Battery minder type products for my plane. I don't
disagree with their use. But, what drove me to the Schumacher
was that once I dug in on a Saturday a.m. and read everything I
could find about charging Odyssey batteries, it sounded like their
preferred charge curve and voltage was not really compatible with
many of the common chargers. Odyssey had a list of only a handful
of recommended chargers, and the Schumacher that I used was
identical to one that appears to be a Schumacher but branded
as an Odyssey charger that they currently sell...for much more
money. I do know that there are a few chargers that are
specific to charging odyssey batteries properly, so my goal
was just to get one of those. I can't remember the voltage
off hand, but I believe you want a top end of about 14.6V
when charging, and many either over or undershoot that by
a ways. So I was just trying to go to the best possible for
the battery I chose. If I were using just any old battery, I
may not think about it so hard I guess, but if you're spending
the money on an odyssey, I figure you may as well try to
treat it the best possible...that was just my theory.
Jim & Julie Wade wrote:
Quote: |
<jwade(at)msdeltawireless.com>
Jim & Julie 40383 N369JW 95 Hours
