Posted: Fri May 18, 2007 3:43 pm Post subject: Redux crystals |
Seems I recall some posts regarding "cooking" redux to remove crystals
in Redux/Araldite but darned if I can find them w/ our search engine.
When I've mixed up a small batch recently and seem to have created some
small, flat flakes which concerns me...are these the crystals some have
posted about? The yellow paste seems fine coming out of the can...nice
and gooey w/ no solids. These flakes seem to form after I've added the
hardener and mixed it with the paste. Can anyone give me either a heads
up warning, reassurances, and/or a "fix"?
Fred
cockpit module
On Friday, May 18, 2007, at 03:11 PM, Graham Higgins wrote:
<ghiggins(at)nsw.chariot.net.au>
Does anyone have any info or experience in using the reverse thrust in
anger? My experience of being unable to stop on rollout,( aborted
takeoff) and hitting that cane drain, has been relived many times. It
is not a pleasant experience( broken back, broken aircraft). I have
often wondered if reverse thrust prop would have been more effective
than the single mono wheel brake on dew laden grass, lightly loaded
aircraft.
I would imagine the aerodynamics involved would be rather complex.
Graham Higgins in Oz, still rebuilding.
believed to be clean.
william(at)wrmills.plus.c Guest
Posted: Fri May 18, 2007 10:47 pm Post subject: Redux crystals |
Fred,
The crystals are hard, they form on the top of the resin like a crust and
convert any residue on the sides of the container, but they will disperse if
you lower the container into hot or near boiling water for a while. It
works well and apparently does not affect the quality of resin. However, I
have never experienced flakes forming after mixing. Perhaps it is something
to do with the hardener?
William
Posted: Sat May 19, 2007 5:11 am Post subject: Redux crystals |
Thanks to Bob(s) and William...the gentle heat works like a charm!
Fred
