james.k.hovis(at)gmail.co Guest
Posted: Fri May 18, 2007 4:54 am Post subject: Establishing gross weight |
A quick (hopefully) education on material properties. Metals when
placed under load will stretch or compress a certain amount
proportional to the load applied. When the load is removed, the metal
will go back to its original shape. This is called elastic
deformation. Increasing loads will stretch or compress the metal
elastically in a linear fashion up to a certain stress level called
the "Yield Point". The stress at this point is "Yield Stress". Loads
applied beyond the yield point will deform the metal plastically,
meaning when such a load is removed, the metal DOES NOT return to its
original shape. This will continue up to a point where the metal will
actually break, the "Ultimate Stress". Look at FAR 23.305, limit loads
(3.8G for Normal cat.)must not permanently deform the structure and
the structure must withstand the ultimate loads (5.7G) for three
seconds without failure (breaking). Therefore, yield stress is often
used at limit load to size the structure. Any loading exceeding the
limit load will deform the structure rendering unuseable, but
hopefully not breaking. However, I don't know what philosophy Van's
used. I assume a very conservative approach.
Kevin H.
On 5/17/07, JSMcGrew(at)aol.com <JSMcGrew(at)aol.com> wrote:
Dan,
I'm only responding because I think builders should think long and hard
before making the decision to increase Van's recommended limits. I don't
want to
see any statistics in our group. The RV-10 was designed to handle 3.8G's
with
a ~1.5 safety margin (~5.7G ultimate). Anything you do beyond the design
conditions cuts into said safety margin.
By your argument the C-5 Galaxy with a maximum gross weight of 840,000 lbs
x
3.8G's can handle 3,192,000# of load. So when at low fuel weight (374,000#)
it should be able to pull 3,192,000# / 374,000# = 8.5 G's. That would be
something to see, however, that is simply not the case; it just doesn't
work that
way.
You can justify all you want. I still don't recommend it.
-Jim
In a message dated 5/17/2007 12:27:12 P.M. Eastern Daylight Time,
LloydDR(at)wernerco.com writes:
We are not talking safety margins, we are talking an aircraft rated in the
standard category and as such will sustain 3.8G's without structural
failure.
Nuff said. If the location of the additional 200 LBS keeps the plane in CG
than there will not be an issue in standard flight conditions, what is
unknown
is how the plane will react when the plane is stressed past the max load
breaking point of 3.8G's x 2700lbs or 10,260LBS total. Then once you get
past
this point there is the safety margin that is built in, but unless you go
past
the 10,260 LBS limit then there is nothing new being discovered.
Dan
____________________________________
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com
Sent: Thursday, May 17, 2007 12:00 PM
Subject: Re: Establishing gross weight
The design safety margins are established to account for variations in
construction, fatigue, turbulence, variations in piloting, engineering
mistakes
etc. etc., all of which are fairly difficult to predict when they will
happen
or what the effect will be. Furthermore, an aircraft experiences many
different stresses during the course of a flight (besides just holding the
airplane
up in level flight). You need a thorough engineering analysis to understand
the effects a deviation from the design conditions will have on the
airframe in
various flight conditions.
I recommend sticking to Van's established limits (weight limits and all
others) unless one is willing and capable of performing such an analysis.
-Jim McGrew
40134
Jim "Scooter" McGrew
_http://www.mit.edu/~jsmcgrew_ (http://www.mit.edu/~jsmcgrew)
In a message dated 5/17/2007 11:35:42 A.M. Eastern Daylight Time,
Let me clarify my position, Like you have stated the plane has already
had a static test of its 2700 lbs, which means the wing will need to
support 3.8 times that to be in the standard category, which means
theoretically both wings together will withstand 10,260 lbs and not
fail. With this being said, it would not be a long stretch stating that
an additional 200 pounds in the right location will not cause an issue
during normal flight and clear non-turbulent conditions. I did not state
that it was a smart thing to do and go fly in turbulence, what I did
state was set it high, flight test it and adjust as necessary.
Dan N289DT RV10E
************************************** See what's free at
http://www.aol.com.
LloydDR(at)wernerco.com Guest
Posted: Fri May 18, 2007 5:43 am Post subject: Establishing gross weight |
Jim
I agree with you, but if you read my post I stated that testing of the new weight was a requirement. Since you bring in the military, lets point this out, the DC3 was designed for 26k lbs, and when it was put into military service as a C-47, the max weight was increased to 28K, this increased weight was determined acceptable by testing, and all I am saying is that it is okay to increase the max gross weight and test to make sure it is ok. Another option in this scenario is that a max takeoff weight, and a max landing weight be established and a fuel jettison system be installed, it is routine practice to overload an aircraft, knowing that fuel burn in flight will allow the aircraft to return within limits, so if Wayne wanted to he could designate a max takeoff weight that matches his adjusted gross and then put in the op limitations that when landing it is not to exceed Vans recommended weight, and this could be accomplished by fuel burn/ jettison.
The venerable Cessna 172 has had its max weight increased several times during its life, equaling several hundred pounds and without structural modification. This was accomplished by continued testing and analyzing the results. This is all I am recommending him to do.
We are experimental builders after all and the purpose is to experiment, if you are not willing to do that then buy a certified plane and be assured that the plane was tested by someone else. But if you are wanting to further yourself and your skills, and learn what testing is about then buy an experimental and experiment, that is our right as builders and test pilots.
Dan
N289DT RV10E (Experimenting with an alternative power plant and loving every minute of not doing what is accepted by Van's, I am such a rebel!)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com
Sent: Thursday, May 17, 2007 4:40 PM
Subject: Re: RV10-List: Establishing gross weight
Dan,
I'm only responding because I think builders should think long and hard before making the decision to increase Van's recommended limits. I don't want to see any statistics in our group. The RV-10 was designed to handle 3.8G's with a ~1.5 safety margin (~5.7G ultimate). Anything you do beyond the design conditions cuts into said safety margin.
By your argument the C-5 Galaxy with a maximum gross weight of 840,000 lbs x 3.8G's can handle 3,192,000# of load. So when at low fuel weight (374,000#) it should be able to pull 3,192,000# / 374,000# = 8.5 G's. That would be something to see, however, that is simply not the case; it just doesn't work that way.
-Jim
In a message dated 5/17/2007 12:27:12 P.M. Eastern Daylight Time, LloydDR(at)wernerco.com writes:
| Quote: | We are not talking safety margins, we are talking an aircraft rated in the standard category and as such will sustain 3.8G's without structural failure. Nuff said. If the location of the additional 200 LBS keeps the plane in CG than there will not be an issue in standard flight conditions, what is unknown is how the plane will react when the plane is stressed past the max load breaking point of 3.8G's x 2700lbs or 10,260LBS total. Then once you get past this point there is the safety margin that is built in, but unless you go past the 10,260 LBS limit then there is nothing new being discovered.
Dan
The design safety margins are established to account for variations in construction, fatigue, turbulence, variations in piloting, engineering mistakes etc. etc., all of which are fairly difficult to predict when they will happen or what the effect will be. Furthermore, an aircraft experiences many different stresses during the course of a flight (besides just holding the airplane up in level flight). You need a thorough engineering analysis to understand the effects a deviation from the design conditions will have on the airframe in various flight conditions.
I recommend sticking to Van's established limits (weight limits and all others) unless one is willing and capable of performing such an analysis.
-Jim McGrew
40134
In a message dated 5/17/2007 11:35:42 A.M. Eastern Daylight Time, LloydDR(at)wernerco.com writes:
| Quote: | --> RV10-List message posted by: "Lloyd, Daniel R." <LloydDR(at)wernerco.com>
Dan N289DT RV10E
See what's free at AOL.com.
Posted: Fri May 18, 2007 6:01 am Post subject: Establishing gross weight |
I agree whole heartedly with this, how do we set it up and coordinate the effort?
Dan
N289DT
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Friday, May 18, 2007 6:39 AM
Subject: RE: Establishing gross weight
Great idea!
I’m in…………
At my point of build, I’m an information sponge on anything RV-10.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox
Sent: Thursday, May 17, 2007 11:01 PM
Anybody want to talk about an RV-10 Operator’s Seminar at OSH like Lancair does? So we can hammer out these issues.
John Cox
Do not Archive
rvbuilder(at)sausen.net Guest
Posted: Fri May 18, 2007 6:33 am Post subject: Establishing gross weight |
I can see something that starts off very informal until it hit’s a critical mass that we could approach EAA for forum space. In the mean time I would suggest that someone (JC) starts developing some talking points that seem to be of interest to the list. We could then convert one of the daily meeting times at Van’s tent to a one hour lunch and learn session someplace that isn’t in use with picnic tables or chairs. Very much a round table type session unless someone of expertise would have a presentation that they feel would be useful.
Thoughts?
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lloyd, Daniel R.
Sent: Friday, May 18, 2007 9:01 AM
Dan
N289DT
Great idea!
I’m in…………
John Cox
Do not Archive
[quote] href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com ; - The RV10-List Email Forum -http://www.matronics.bsp; - NEW MATRONICS WEB FO; http://forums.matronics.com</================== [b]
ScooterF15
Posted: Fri May 18, 2007 6:39 am Post subject: Establishing gross weight |
Dan,
Sure. I'm not against modifications, just modifications without proper testing and analysis. I don't want builders in general to justify modifications arbitrarily. I certainly don't have anything against you, please don't take my previous post personally. I've had a lot of experience in military flying and engineering and things don't always go optimally. For example I was flying in a T-38 on an instrument check ride one day in clear VFR and got hit by turbulence plus minus about 3 G's. I've never been thumped so hard out of the blue. I hit my head on the canopy and got a splitting headache (that didn't help the check pilot's attitude either). Think about negative G limits for the RV-10 as well, they are a lot less. You never know when you might experience some rough turbulence. I've personally chose to keep the weight limits at 2700. I ended up with a 1570# empty weight and that works out great for useful load.
I spoke to Ken at Van's about the design process they used. It's really hard to test and analyze all different possible stresses on an airframe. So, my understanding is that they did point testing and analysis to ensure certain conditions were met (like load testing the wing for ultimate loading). Then designed so that the infinite number of in-between conditions would be met. It's just hard to be certain you're OK without the know how and resources available to Van's engineering team, the military, or Cessna etc.
Just food for thought. Good luck and keep building. I hope to see you at a fly-in in the near future.
-Jim
In a message dated 5/18/2007 9:45:14 A.M. Eastern Daylight Time, LloydDR(at)wernerco.com writes:
| Quote: | Jim
Dan
Posted: Fri May 18, 2007 6:51 am Post subject: Establishing gross weight |
Now that’s what this list is for. What a great exchange of opinions, facts, and ideas on all sides.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
[quote] [b]
John Ackerman
Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
Posted: Fri May 18, 2007 7:36 am Post subject: Establishing gross weight |
So, among other things, we need to know... What is a "long stretch"? How do we know what a "long stretch" is?
CG aside, what is a "right location" and what is not? How do we know?
| Quote: | ...and clear non-turbulent conditions. I did not state that it was a smart thing to do and go fly in turbulence, what I didstate was set it high, flight test it and adjust as necessary.
| Quote: | | Really and truly, I think the gross weight should be established during the fly-off period. |
What are we going to find out from a "flight test", assuming, of course that the airplane does not flutter, bend detectably, or come apart?
How do we conduct such a test? How (quantitatively) do you adjust GW based on test results? How do you know the test has not overstressed the airplane already, and thus lowered the allowable weight? I suspect that _at least_ education equivalent to that of a B.S. with an emphasis on structures would be required to take on these issues.
Has anyone tried exiting the 10 while wearing a parachute, even stopped on the ground?
One could make a pretty good argument for _decreasing_ the gross weight that we actually fly to. The reason is that -as far as I know- we have no way to know that our wings are capable of withstanding the same loads as Van's test article - regardless of whether they are slow build or fast build. Likewise, we have no way of knowing by how much they might deviate. My personal approach is to decrease the airspeed rather than the gross weight, though.
No, most assuredly _not_ enough said.
We have some really wide latitude with experimental amateur-built aircraft, and rights that are probably the envy of pilots and builders worldwide. With rights come corresponding responsibilities. I submit that the rights accrue to us as individuals, but the responsibilities are to our passengers, families, ourselves, and the families of anyone who might fly or ride in the aircraft down the line, possibly long after we are gone. Oh, yeah - and to our fellow builders who would share in the effects of any negative result of our actions.
Thanks to Rick for the excellent insurance discussion, and to James Hovis for the continuing rational, understated engineering perspective.
Tim Olson
Posted: Fri May 18, 2007 7:45 am Post subject: Establishing gross weight |
I've just followed the comments on this so far, but I guess I
may as well speak too.
I think:
General builder questions would be well addressed in things
like workshops that already exist at EAA events, and by online
discussions, and by things like the recent workshop held
by David Saylor. So when it comes to building things, we
can all sit around the campfire and shoot the sh1t all night
long. That would work well.
For general flying skills, I think at present we not only
don't have the critical mass nor the commonality among
airplanes and panels to really go in depth and have an
event that would fit everyone or even draw a huge attendance.
We certainly don't have a critical mass to do anything that
would qualify us for reduced insurance rates as a motivator.
Then, for RV-10 flying skills, nothing really beats a couple
hours with someone like Mike S. or Alex D. to get transition
training. It's a great place to start.
The gap, as I see it today, is that there are a lot of unique
discussion topics that really could benefit from an hour
(or perhaps much more), where people who are currently flying,
operating, or maintaining the RV-10 could give some great
input as to the many things that you don't get out of the
above. There are things about how the RV-10 flies, and
things about how you can operate it, about some
maintenance gotchas, and about some things like the the
final stages of pre-first-flight preparation, that really
would be great for just a forum type event. Perhaps a
bullet-point list could be put together by a few people, or
questions could be provided for a Q&A list, and at OSH
we could set aside some time where 4-10 current RV-10
operators could speak as pseudo-panelists and give their
opinions...even if they don't all agree. I would be willing
to participate in something of that nature. I also am
quick to point out that while I may have what some would
view as good input to give, I also would not consider myself
an expert, as there are truly very few people who fit that
description. So just as anything, you'd have to take it
only as my opinion. There are far too many who speak
as experts without the qualifications, and I don't want
anyone to mistake me as one of those.
Also, some of the types of questions that could be
answered well by a panel of people are what types of
impressions they have for the need for certain equipment,
such as: Rudder Trim, Yaw Dampners, Autopilot features,
Elevator trim, lighting options, and the many things that
people question whether or not they want to add them to
their plane. Those are things that it would be nice
to hear from multiple flying -10 owners and get more
of a flowing conversation idea of what they all think.
So depending on what y'all say you want, I'd probably be
happy to participate. Ideally, everyone would take a demo
flight with me or someone else, (which PLEASE, this won't
be happening at OSH), because I usually speak at length
about some of these things during the demo flights I give.
It's the best way to really get things pointed out for you
and then let you see first-hand, in-flight, and form
your own opinion.
If we do this at OSH, I think we should just do it at
a place like RV-10 HQ, where we probably will already
have some chairs, and do it on some mid-morning or mid-afternoon
timeframe, perhaps on a day like Tuesday/Wed/or Thurs.
It could even be done twice, with the same agenda, so that
as many builders as possible could participate.
Let's see if there's continuing interest. If you like
the theory above, then shortly we should start
off-line gathering a list of topics and questions, and
we can start getting a list of people to speak. I'm sure
we could talk Vic, who's also a DAR, into speaking too,
as long as his schedule allows.
RV Builder (Michael Sausen) wrote:
| Quote: | I can see something that starts off very informal until it hit’s a
Thoughts?
Michael
Posted: Fri May 18, 2007 8:20 am Post subject: Establishing gross weight |
The beauty of the experimental category is that each of us gets to determine what is right and wrong in the way of testing. With that being said the correct amount of testing is what makes you as the builder satisfied as to the safety of the aircraft and what you determine the max allowable weight to be. Once again it is up to the builder to set these parameters, whether they actually test the aircraft themselves or pay to have the aircraft tested, it is the builder that is ultimately responsible for this, regardless of what the builder community feels they can not stop an individual from doing what they want as long as it meets the regulation requirements set by the FAA. As for a responsibility to others who ride in the plane, there is a placard that is required that says it does not meet the standards and as such they need to make the decision before they get in to determine whether they trust the builder or not, and whether they are willing to put their life on the line based on that trust.
It is all about personal responsibility, not what others place on you, and you as the builder need to determine if it is safe or not.
IMHO (my opinion) many people are willing to fly their certified aircraft over gross, and as such they would be willing to fly their experimental over gross, regardless of what the listed gross was. So,once again IMHO the placard is there and it is listed but the pilot will in the long run do what they want to regardless. Remember how this conversation got started, it was Wayne that asked to change his weight not me, so lets keep that in perspective, because as the builder I would not solicit the opinion of all the arm chair quarterbacks that are on this list, rather I would solicit it from the people I know who have experience in this field and the ramifications would become readily apparent from that discussion, rather than the pure conjecture that is taking place.
Dan
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Ackerman
Sent: Friday, May 18, 2007 11:36 AM
| Quote: | ...and clear non-turbulent conditions. I did not state that it was a smart thing to do and go fly in turbulence, what I did state was set it high, flight test it and adjust as necessary.
Posted: Fri May 18, 2007 8:41 am Post subject: Establishing gross weight |
Thanks. Part of my job is to explain engineering rationale to less
educated, but highly skilled production workers. Sometimes I do a
better job of it than at other times. I've never said "that's the way
it is, don't question it!".
Kevin H.
On 5/18/07, John Ackerman <johnag5b(at)cableone.net> wrote:
apart?
actions.
GRANSCOTT(at)aol.com Guest
Posted: Fri May 18, 2007 9:59 am Post subject: Establishing gross weight |
In a message dated 5/18/2007 12:23:23 PM Eastern Daylight Time, LloydDR(at)wernerco.com writes:
| Quote: | | IMHO (my opinion) many people are willing to fly their certified aircraft over gross, and as such they would be willing to fly their experimental over gross, regardless of what the listed gross was. |
Dan,
Every pilot makes the final decision on their safety of flight...but having said this, if you over load your plane and you have an incident/accident there is the likelyhood that your insurance company will not honor your insurance policy since you knowingly violated the standards which you created. But results may vary...or the widow and children left on the ground.
Patrick
rleffler
Posted: Fri May 18, 2007 12:09 pm Post subject: Establishing gross weight |
I've swapped some email with Susan Sedlacheck at EAA. We may be able to get
one of the forum buildings, but they are only available in the evening. She
also talked about the porch at the Homebuilder's HQ, but I think we could
easily overwhelm that area.
Just some more options if interested.......
_________________ Bob Leffler
N410BL - Phase I
apilot2(at)gmail.com Guest
Posted: Fri May 18, 2007 4:37 pm Post subject: Establishing gross weight |
The C172 increases came with gear changes and later engine change. It
went from 2200 to 2300, and eventually I think 2400...not a major
increase. Also, the airframe was designed as a taildragger, so gear
and gearbox had to be designed stronger. Those weren't paper changes
but fully tested, and there were structural changes. Different gear
legs, different struts, etc.
On 5/18/07, Lloyd, Daniel R. <LloydDR(at)wernerco.com> wrote:
| Quote: | The venerable Cessna 172 has had its max weight increased several times
results.
Posted: Fri May 18, 2007 8:11 pm Post subject: Establishing gross weight |
Not true for all of the weight changes in the history of the 172, but
like you said 200 lbs is not a major increase?
Posted: Sat May 19, 2007 3:42 am Post subject: Establishing gross weight |
I'd like to get back to OSH (haven't been since '96) and at least meet
y'all at the camp. Unfortunantly, my vacation time will be ate up by
other hobby and family time. Maybe next year....
Kevin H.
Posted: Sat May 19, 2007 4:07 am Post subject: Establishing gross weight |
Just come in for the first weekend or the second. Depending on how far
it is, I might be willing to come get you in my overweight 10!!!
Remember all of this is in jest and we are just educating each other!
Dan
N289DT RV10E (She is on her own gear and rolling with a mounted Subbie)
PS Michael, I did try to post the photos last night at midnight but
Matronics kicked'em back because they were too big. I will resize and
send again
Posted: Sat May 19, 2007 4:29 am Post subject: Establishing gross weight |
Not considering it took more than fifteen years to get there, totally
different landing gear, different engine, different fuselage. Remember
it started as the C170 in 1948, so there are a lot more changes than
you realize. Almost nothing from 1969 on is original.
Posted: Sat May 19, 2007 4:50 am Post subject: Establishing gross weight |
I'd love a ride if you don't mind an overweight passenger too.
Actually, doing an equivalent strength analysis isn't that difficult
for someone familiar with the process. There are several things about
the structure affected that needs to be known (sizes, material types,
fasteners, etc.) to see exactly how much a gross weight increase will
affect the structure. I'm just very skeptical of anyone just pencil
whipping a higher gross weight on any airplane without checking with a
professional. While the RV-10 may be able to tolerate a 10% weight
increase without structural modification (only as an example, I want
to do or see an analysis before fully agreeing to that statement),
other airplanes can't. See this from Avweb about what severe
turbulence can do to you for someone who wasn't careful in their
flight planning:
http://www.avweb.com/news/probablecause/probable_cause_32_incomplete_briefing_195146-1.html
I'm going to keep watch on the Subbie installation to see how it pans
out. Good alternatinves are always welcome to me.
Kevin H.
(putting in some Sat. OT)
Dan
send again
Posted: Sat May 19, 2007 5:02 am Post subject: Establishing gross weight |
Kelly,
One thing to remember is in the "old" days, engineering analysis
tended to be extremely conservative which resulted in structures that
were actually more robust than needed. As better analysis tools came
on line (for example NASTRAN), it was easier for Cessna and others to
re-look at old designs and show "upgrades" (i.e. weight and HP
increases) without altering the basic airframes too much. Aircraft
design still tends to be conservative. Why do you think radical design
departures take SO long to get FAA approval if a TC is sought (see
Beech Starship for composite construction)? Fortunantly for Cirrus,
Diamond, and Columbia, Beech spent the money. But the point is, weight
increases on TC aircraft aren't just pencil-whipped, there are
rational professional analyses behind them.
Kevin H.
Posted: Sat May 19, 2007 6:51 pm Post subject: Establishing gross weight |
What I am talking about is the changes in the gross weight without
changing/ modifying the airframe. Research the history of the aircraft
and you will see many gross weight changes without any modification to
the airframe, rather extensive testing was accomplished and the gross
weight was modified. This is what I am referring to in this situation,
if the builder is going to change the gross weight than a test period is
required to verify it is safe, and as the builder they are the ones that
need to determine how much and what testing is necessary to be okay with
the change.
Dan
