VE3LVO(at)rac.ca Guest
Posted: Thu May 17, 2007 4:29 am Post subject: Woodcomp propeller controls |
Sent: Wednesday, 16 May 2007 10 35
To: EUROPALIST
Subject: Woodcomp propeller controls
Cheers,
I am in the process of installing the subject item, an SR3000/3 Constant Speed unit. There are several control modules involved in the installation and I am trying to rationalise the siting of these on a standard mono instrument panel – somewhat cramped and needing careful planning.
While I have read the manual several times, I find it hard to calculate how often (and therefore where) each item should be used.
If you are familiar with the use of a 3000 or similar device, would you consider advising me where you would put each module to permit ease and frequency of use? This comprises CS RPM control selector, CS/manual switch, pitch indicator and a guarded Reverse pitch switch – yes, reverse. I know, I know.
Happy landings
Ferg
Classic mono 914
Dave Miller
Posted: Thu May 17, 2007 5:03 am Post subject: Woodcomp propeller controls |
Ferg,
For what it is worth, mine stays in the constant speed mode, so I would position the manual/auto switch where ever there is room, you probably will not normally need to use it.
I don't have a pitch indicator, but would not think this needs to be in a prominent position.
The RPM control selector needs to be in sight and easily accessible.
The reverse switch is probably best located in the baggage compartment !
Dave
"Fergus Kyle" <VE3LVO(at)rac.ca>
Sent by: owner-europa-list-server(at)matronics.com
05/17/2007 08:26 AM
Please respond to europa-list
To: "EUROPALIST" <europa-list(at)matronics.com>
cc:
Subject: FW: Woodcomp propeller controls
To: EUROPALIST
Cheers,
Happy landings
Ferg
Classic mono 914
kheindl(at)msn.com Guest
Posted: Thu May 17, 2007 5:26 am Post subject: Woodcomp propeller controls |
Ferg,
I had all that installed last year (except reverse sw). I had space left on
the right side of my panel for the two round instruments, which require
non-standard size cutouts, and mounted circuit breaker and on/off toggle
switch into the same adapter plate (my cutouts are all 3 1/8") of one of the
instruments. The control box I mounted against the inside of the firewall.
Feathering was supposed to be automatic. Since everything came completely
prewired the installation was fairly easy except for having to reduce my
cutouts to their sizes. You also need a place for the mp gauge.
The manual mode checked out okay on the ground, but nothing worked correctly
in the air. I had a very frustrating summer trying to get it to work.
Acomplete replacement (incl. brush box) simply presented a different set of
problems. The automatic feathering never worked, but this could have been
wired to a manual switch. Factory support was pretty hopeless and I finally
gave up and sent it all back for a full refund. They then offered me their
new SINGLE instrument, The CS1, which takes the rpm directly from the
engine, instead of the propeller, but I had had enough of their lack of
support. I am just now installing the single instrument CSC1-G from Smart
Avionics, as others have done. The Smart box also has the manifold pressure
integrated and displayed on their instrument, so now there is only one small
instrument instead of 3.
I hope that my experience was unique and that your boxes will function
perfectly. I just also felt that the whole design was a cloodge, and had
evolved from the manual mode. Their new instrument would be worth looking
at, but let someone else be the guinea pig.
Their propeller and hub are absolutely first class. They even supplied me
with a standard XS 10 inch size spinner , and the whole propeller was
supplied fully assembled and ready to bolt on.
Karl
| Quote: | From: "Fergus Kyle" <VE3LVO(at)rac.ca>
Reply-To: europa-list(at)matronics.com
Date: Thu, 17 May 2007 08:26:39 -0400
_____
To: EUROPALIST
Cheers,
SR3000/3
standard mono instrument panel - somewhat cramped and needing careful
planning.
CS/manual
switch, pitch indicator and a guarded Reverse pitch switch - yes, reverse.
I know, I know.
Happy landings
Ferg
Classic mono 914
Txt a lot? Get Messenger FREE on your mobile.
https://livemessenger.mobile.uk.msn.com/
pete(at)lawless.info Guest
Posted: Thu May 17, 2007 6:44 am Post subject: Woodcomp propeller controls |
Hi Karl
Your experience was unfortunately not unique. My friend has just had a very
similar 12 month experience and has also given up and is installing the
Smart Avionics controller.
Pete
josok-e(at)ukolo.fi Guest
Posted: Thu May 17, 2007 7:38 am Post subject: Woodcomp propeller controls |
Hi Ferg,
Also a SR3000 with reverse.
But i went for the CSC1-G, and while still on the ground, test running the
engine, everything seems to
work great. Have not reversed with a running engine though. I used the
Woodcomp label and security lock for the switch, replaced the switch with
a 3 pole on-off on, which cuts a relay, taking the cs controller off line
and power to reverse and unreverse. If you are interested a (bad) hand
drawn circuit diagram, i can send it to you. On the defensive side i would
like to add: I will be landing on ice, reverse might come in handy.
Jos Okhuijsen
workshopcam http://www.okhuijsen.org/plane
http://www.europaowners.org/kit600
ghiggins(at)nsw.chariot.n Guest
Posted: Fri May 18, 2007 2:13 pm Post subject: Woodcomp propeller controls |
Does anyone have any info or experience in using the reverse thrust in
anger? My experience of being unable to stop on rollout,( aborted takeoff)
and hitting that cane drain, has been relived many times. It is not a
pleasant experience( broken back, broken aircraft). I have often wondered if
reverse thrust prop would have been more effective than the single mono
wheel brake on dew laden grass, lightly loaded aircraft.
I would imagine the aerodynamics involved would be rather complex.
Graham Higgins in Oz, still rebuilding.
william(at)wrmills.plus.c Guest
Posted: Fri May 18, 2007 10:23 pm Post subject: Woodcomp propeller controls |
Hi Graham,
Very sorry to hear of your mishap, particularly your back injury and I hope
you have now recovered and will soon be back in the air.
I have a mono with a Woodcomp SR 3000/3 with reverse and I use it every time
I land at my strip instead of using the brake (obstacles on both
approaches). It is extremely effective for stopping, but whether I could
activate it quickly enough for an abortive take-off (in a panic), is an
unknown. For safety reasons there are a sequence of actions before reverse
can be activated; U/C down, mode switch changed, throttle closed, guard
lifted and reverse switch activated. All but the last two can be done in
preparation for landing.
Of course the U/C will already be down and no doubt you will close the
throttle instinctively when you decide to abort, so if you can do the
others, the prop will go into reverse in under two seconds. If you are
thinking clearly and have quick reactions, I imagine it is do-able.
The mono is extra wobbly on tarmac (because of reduced rudder authority),
but most hard runways are long enough anyway. On grass it is fine, once the
roll-out has been established. It is also very effective for losing height
in the air (VSI off the clock), but Woodcomp forbid this (no doubt because
of litigation) and the PFA exclude it on the "Limitations" placard. I have
never had the courage to try a landing, in case there is insufficient energy
for the round-out, but it might be OK if 80 knots is maintained all the way
down the glide path. Apparently, C 130s can land in reverse for extremely
short landings; perhaps Nigel can comment on this.
William
Posted: Fri May 18, 2007 11:26 pm Post subject: Woodcomp propeller controls |
Hi William,
While building after your example drawing:
For reason of simplicity, exactly in a high stress situation (most of my landings will be )managed to do away with the change-mode switch. The 3-pole reverse-unreverse switch now operates a relay, that changes the mode. This latched and warning labeled switch is IMHO security enough against accidental operation.
Do you have to wait for full reverse before opening the throttle? Should i think about an indicator light that indicates the reverse end stop reached?
Jos Okhuijsen
Visit - www.EuropaOwners.org
Posted: Sat May 19, 2007 2:09 am Post subject: Woodcomp propeller controls |
Hi Jos,
Yes, you do have to wait and no, I don't think you need an indicator light,
because the change to reverse is continuous and so quick, but it is
important not to be able to select reverse, or "unreverse" with the throttle
open, because when it goes through zero pitch, it will over-speed the
engine. A micro switch on the throttle box to break the circuit will do the
job.
Best wishes,
William
Posted: Sun May 20, 2007 6:12 am Post subject: Woodcomp propeller controls |
William/Jos:
I have discovered (not for the first time - but again...) that being
familiar with operating these types of device is far from installing them!
I appreciate the chat regarding their relative positions - something which
will get more thought after your messages.
Where would you put the 'reverse/unreverse'? - near the throttle or up the
instrument board? - I was hoping to provide the light indicating full
reverse at the top of the panel near the line of sight ahead so as to react
more quickly to reverse being ready. I thought to join 'reverse ready', 'oil
pressure drop', 'angle-of-attack' led and 'over/under-volt' and 'fuel
pressure drop'lamps up high for more conspicuous notice and reaction.
Thoughts?
Cheers, Ferg
Posted: Sun May 20, 2007 11:45 am Post subject: Woodcomp propeller controls |
Hi Ferg,
The rev/unrev with blocking flap sits next to the cs controller. Thats in the lower part of the avionics panel. There are some pictures at http://www.europaowners.org/kit600 : instrument panel. I do not have have rev indicator light.
Jos Okhuijsen
Posted: Mon May 21, 2007 2:29 am Post subject: Woodcomp propeller controls |
Ferg,
I have the reverse switch near the throttle on the tunnel top and I have a
bright LED at the top of the panel to warn when the reverse "master switch"
is selected, which arms the guarded reverse switch.
William
Bill & Sue
Joined: 10 Jan 2006 Posts: 48 Location: Malvern, Worcs. UK (Defford, Croft Farm)
Posted: Wed Jun 06, 2007 2:50 pm Post subject: Re: Woodcomp propeller controls |
The recent discussion on propellers has been really illuminating –but inevitably I now realise how little I know about propellers in general.
I had in mind the Woodcomp for our trigear -but inevitably there now seem to be lots of other props each offering various advantages but no clear winner.
In general terms, could anyone explain the benefits of a three-blade prop over a two blade, and whether these outweigh the weight penalty?
And, while I’m seeking enlightenment, how do the benefits of electric CS props compare with the hydraulic variety?
Bill
Trigear 465
P.S.
I ordered something from Europa by phone one lunchtime last week and was opening the package over breakfast the following morning. Credit due for excellent service methinks!
Posted: Wed Jun 06, 2007 3:54 pm Post subject: Woodcomp propeller controls |
Bill
A three blade prop will balance both mass and yaw forces. A two blade
won't. There will always be a yawing vibration with a 2 blade whenever
there is significant angle of attack. (Downgoing blade sees a different
AoA to Upgoing one)
End result is that in general 3 bladers are smoother than 2 blades.
imho electric is cheaoer than hydraulic but not as fast so electric is
no good for aerobatics.
Graham
Bill & Sue wrote:
| Quote: | In general terms, could anyone explain the benefits of a three-blade prop over a two blade, and whether these outweigh the weight penalty?
Bill
Posted: Wed Jun 06, 2007 5:03 pm Post subject: Woodcomp propeller controls |
Bill,
I have the SR3000/2W 2-blade with narrow ends and wide root with a lot of
twist. It is now running very smoothly, although I had a lot of problems
initially with vibration, which was due to carbs not well balanced. A
3-blade seems to cancel out a lot of uneven combustion. The instrumentation
was hopeless and I am now installing the Mark Burton controller.
Advantages are: less weight, cheaper, better visibility when feathered for
gliding, less drag, and it comes to you fully assembled ready to bolt on.
There are supposed to be other advantages like high altitude performance,
but have not done any serious testing yet.
Apparently Kim Prout has the best performing prop ? With a weight of 13 1/2
pounds that is half the weight of most cs props.
If you are building a mono, then my prop would be too long for you,
Karl
| Quote: | From: Graham Singleton <grahamsingleton(at)btinternet.com>
Subject: Re: Re: Woodcomp propeller controls
Date: Thu, 07 Jun 2007 00:56:32 +0100
Bill
there is significant angle of attack. (Downgoing blade sees a different AoA
to Upgoing one)
imho electric is cheaoer than hydraulic but not as fast so electric is no
Graham
Bill & Sue wrote:
><Billandsue(at)billbell.co.uk>
>Bill
The next generation of Hotmail is here! http://www.newhotmail.co.uk
carl(at)flyers.freeserve. Guest
Posted: Thu Jun 07, 2007 1:16 am Post subject: Woodcomp propeller controls |
As you may know I have been researching VP/ CS propellers but it is always
difficult to come to a definitive conclusion without speaking to those who
have actually used the various propellers.
William Mills was kind enough to share his experience with me before his
tragic departure from this life.
"William, though I never had the pleasure of meeting you in person, your
departure leaves a hole in my life and reminds me of the bond that we who
take to the skies share. You are and will be sadly missed."
William had used both an Arplast and a Woodcomp propeller so was able to
give a useful comparison. This is what he said
Carl,
I had an Arplast PV50 as my first VP prop. I am afraid to say the blades
are the only good aspect of the prop. The hub mechanism is very poor which
resulted in different pitch angles between the blades at different settings,
which cause vibration. The electronic control was very unreliable and
failed in fully coarse, the motor is 6 volts operated by 12 volts to get
enough power, so they fail often and the after sales service is very poor.
That is my experience.
I now have a Woodcomp SR 3000/3 controlled by a Smart Avionics Constant
Speed Controller, which I find is an excellent combination. It is slightly
cheaper than the Arplast and half the price of the Airmaster. It also comes
fully assembled complete with a spinner, fully balanced and ready to bolt
on. May I suggest you take a good look at that before you make up your
mind.
Best wishes,
William
AND
I had a 912 with Warp Drive, then replaced it with an Arplast PV50, then
threw away their control and fitted a Smart Avionics CSC. The PV50 improved
my take-off performance a great deal. When I had done about 800 hours, I
fitted a 912s and a Woodcomp 2000/3 with a Smart Avionics CSC. I have now
changed the 2000 for their latest SR 3000/3 with reverse thrust and I find
this an excellent combination.
Best wishes,
William
I was very interested in the Whirlwind propeller but unfortunately it seems
that (at least in the UK) that converting an existing engine to accept the
hydraulic governor isnt possible (as Skydrive wont supply the necessary
parts). It is possible to purchase a new engine with the governor shaft
fitted but this adds thousands of pounds to the cost (not including the cost
of the governor itself). Additionally the PFA would be unlikely to agree to
the increased propeller diameter (of the Whirlwind) at least for the
monowheel. The Trigear may be a different proposition.
My personal view at present is as follows:
The Airmaster is the best engineered solution (and the CS controller is a
brilliant bit of kit) however there is a question mark over the efficiency/
design of the Warp drive blades.
The Arplast has in the past been somewhat unreliable and in the early days
the VP electric motor was underpowered resulting in the need to reduce
engine power to change the propeller pitch. This issue may have been
resolved but Williams comments above are worrying. Can anyone comment on how
reliable/ suitable the Arplast propeller is in 2007?
The Woodcomp at present seems to be the best of the bunch coupled to the
Smart Avionics CS controller.
Carl Pattinson
G-LABS
Mark Burton
Posted: Thu Jun 07, 2007 1:57 am Post subject: Re: Woodcomp propeller controls |
Even though I manufacturer the Smart Avionics CS controller, I hope my opinion is not completely biased and is of some use to this discussion.
I now have experience of both the Arplast PV50 and the Woodcomp SR3000/3 (feathering version with scimitar blades). A long time ago I also used a Warp Drive fixed pitch prop of which I remember little except it was much harsher than the Arplast EcoProp which replaced it for a short while before I fitted the PV50.
I basically agree with William's comments that the Arplast has super blades from the aerodynamic point of view but the hub+motor are not so good. Even after years of problems, I believe the factory is still supplying the 6V motor as it's the only way they can achieve sufficient torque to coarsen the prop under heavy load. Incidently, I believe you can reduce the likelyhood of the motor frying by connecting a 2ohm power resistor into the wire that supplies the power to the pitch motor. The Arplast supplied control box used to be crap but it could be better now (if you use a CSC-1/P you don't need their box anyway).
The only issue I had with the blades is that they have zero leading edge protection and so getting chewed to bits if your airfield is stony. Even with leading edge tape fitted, a large stone would take out big chunks of gelcoat and cause de-lamination.
Once balanced, the Arplast is a very nice smooth prop.
The quality of the Woodcomp SR3000 is mostly very good. My blades have the carbon finish and look fantastic. The leading edge protect is extremely good. The hub looks adequate and the motor substantial. I don't have that many hours with it yet to say how reliable it is. The wiring between the slip rings, limit switches, motor, etc. looks a bit untidy but not really a problem. Again, the factory electronics does not have a good record for reliability so a lot of people are now ditching the Woodcomp stuff and fitting my controller instead.
Performance wise, it is similar to the PV50 except that the static thrust appears somewhat greater and so provides excellent acceleration - I would think a good prop for short strips. Again, once balanced, the prop is nice and smooth.
My aircraft is slow because it is a tri-gear with no spats and a small engine so I can't really say how either prop performs speed wise.
To summarise, the PV50 and the SR3000 are both very good value and provide good performance. In terms of overall quality of engineering, the Woodcomp wins.
Best of all, both of these props can be controlled by the Smart Avionics CSC controller! This controller can also handle the feathering on the SR3000.
I have flown in aircraft fitted with the Airmaster prop and it works OK but I still think the Warp Drive blades are terribly harsh and the Airmaster controller is poor value for money and lacking in capability.
Mark
Mark Burton
Posted: Thu Jun 07, 2007 2:40 am Post subject: Re: Woodcomp propeller controls |
A few other thoughts:
The Airmaster probably has the best engineered hub of the propellers discussed.
The Airmaster for some time has had a problem with introducing noise into the radio/intercom when the pitch changes and I believe the factory were aware of that and had a fix - perhaps people with Airmasters can confirm/deny this.
Smart Avionics has now sold more than 120 constant speed controllers and I am only aware of 1 unit failing in service due to a component failure.
If you want a smooth prop - balance it!
Mark
Posted: Thu Jun 07, 2007 5:31 am Post subject: Woodcomp propeller controls |
Hi! Carl
Someone the other day somewhere mentioned that Airmaster will be
offering an option with Sensenitch blades at Oshkosh ? That would be
good, however after 600 hours with the MT and facing almost the cost of
new for their 72 month overhaul and since my mind was made up by my
prang last May I have gone for the Woodcomp Scimitar SR 3000 with Mark
Burtons Smart Controller. May as well keep it cheap and be in a better
position at TBO time. BTW Checko is nearer than NZ ! I've been round
their factory on the first 6 Nations trip with William and David Joyce
...great product, great folks, great facility, state of the art
controller from Mark.
Bob H
tonyk(at)kaon.co.nz Guest
Posted: Thu Jun 07, 2007 1:06 pm Post subject: Woodcomp propeller controls |
| Quote: | >> The Airmaster for some time has had a problem with introducing noise
confirm/deny this.
Yes, that was fixed with a change to the controller design.
BTW.. A certain Europa that lives in my hangar looks really great with
its white Sensenich blades ... and for more information you're going to
have to go to Oshkosh!
Tony
