gmvouga(at)hotmail.com Guest
Posted: Mon May 14, 2007 6:29 pm Post subject: Avionics Master |
All,
I'm working on my panel and I'm trying to decide if I should put an Avionics
Master switch. In my experience with rental planes this was nice to have
since there was one switch to turn everything on or off during engine start
or shutdown.
Is there any reason not to add this feature? I'm planning an E-Bus and Main
Bus configuration similar to the Z-13/8 design.
Make every IM count. Download Messenger and join the i’m Initiative now.
It’s free. http://im.live.com/messenger/im/home/?source=TAGHM_MAY07
nuckollsr(at)cox.net Guest
Posted: Mon May 14, 2007 7:57 pm Post subject: Avionics Master |
At 07:28 PM 5/14/2007 -0700, you wrote:
All,
Avionics Master switch. In my experience with rental planes this was nice
to have since there was one switch to turn everything on or off during
engine start or shutdown.
Main Bus configuration similar to the Z-13/8 design.
Why "similar to"? What feature do you find missing
or performance goal that has gone lacking. Goto
http://aeroelectric.com
. . . and put 'avionics master' in the search box.
After reviewing the discussions, help us out by
citing where you perceive a return on investment for
having the feature.
( "Physics is like sex: sure, it may )
( give some practical results, but )
( that's not why we do it." )
( Richard P. Feynman )
fvalarm(at)rapidnet.net Guest
Posted: Mon May 14, 2007 8:19 pm Post subject: Avionics Master |
Greg,
It's been discussed several times and as I recall, the reason to not do it
is a) theoretical single point of failure, and b) no real good reason to do
it.
Bevan
RV7A
Wiring and misc panel work
mwcreek(at)frontiernet.ne Guest
Posted: Mon May 14, 2007 9:45 pm Post subject: Avionics Master |
This is an excerpt from the GRT install manual referring to the use of an
avionics master (at least that is what I read into it). Perhaps Bob can
clear this up as it is somewhat ambiguous.
Power Connections
The display units each include 2 isolated power input connections. This
allows redundant power sources, such as a main and secondary bus. The
display units consume approximately 1 amp, making even a small 3 Amp-Hour
gel cell a suitable emergency source.
The configuration of the power supplied to the display unit(s) is left to
the installer. Considerations such as the number of power buses, the desire
or not to supply one pieceof equipment with power from redundant buses
(which in theory allows the possibility of one device affecting both buses),
the configuration of the electrical system with respect to backup equipment,
and so on, may dictate the best configuration for a particular airplane.
No provision is included within the display units for a power switch. If a
power switch is desired for the EFIS, the +12V power should be controlled
with the switch (not ground). The display units include internal
thermally-activated fuses. This protects the equipment from internal
electrical faults. Power supplied to the EFIS must pass through a fuse or 4
circuit breaker or fuse. It should be sized to allow at least 1.5 amps per
display unit, with a maximum rating of 5 amps.
The AHRS and display units monitor all of their power inputs, and alarms are
available to annunciate the loss of any power source that was provided and
is expected to be working according to the "General Setup" menu.
The majority of the current flow into the display unit will occur on the bus
with thehighest voltage.
It is desirable to have the display units and AHRS off during the engine
start if all of the buses which power them are used for supplying power to
the engine starter. This maximizes the current available for the starter,
and may extend the life of the CCFL backlight in the display unit.
Posted: Tue May 15, 2007 5:31 am Post subject: Avionics Master |
I wanted to use the LR-3 controller and the SD-8, but I didn't find a design
that incorporated both. So, my electrical system is kind of a combination
of Z-12 and Z-13/8. I started with the Z-12 and then removed the circuit
with the SB-1/20A alternator. Then I added the SD-8/regulator circuit from
Z-13/8.
You are right about the search engine. I actually hit send on my email and
then instantly remembered that I should have checked the archives first. Of
course, I found that this subject has been discussed several times before.
My initial reasoning was to protect my "sensitive" avionics during power
fluxuations during startup and shutdown. It seams that modern avionics
should not have this problem according to your comments in the past.
However, I am using some experimental electronics that may or may not have
gone through extensive testing for power fluxuations. I agree that the
manufacturers should have made their products robust enough, but did they?
I'm not sure we can know for sure unless someone tests the units thoroughly
either in the lab or just through normal use.
Greg
| Quote: | From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Reply-To: aeroelectric-list(at)matronics.com
Subject: Re: Avionics Master
Date: Mon, 14 May 2007 22:56:09 -0600
><gmvouga(at)hotmail.com>
>All,
having the feature.
Catch suspicious messages before you open them—with Windows Live Hotmail.
redeloach(at)fedex.com Guest
Posted: Tue May 15, 2007 5:49 am Post subject: Avionics Master |
Why can one not just use the "off/on" switch on each device ?
mlas(at)cox.net Guest
Posted: Tue May 15, 2007 6:27 am Post subject: Avionics Master |
Check the $price$ of that on/off switch in the radio and how much it
cost to have it changed. Then you will know why you don't want to use
them all the time. The on/off switches on the radio seems to fail more
often then a standard toggle switch, especially on the Narco and king
radios.
Mike Larkin
mprather(at)spro.net Guest
Posted: Tue May 15, 2007 7:00 am Post subject: Avionics Master |
Do they fail from operations or age?
Matt-
radios.
Mike Larkin
rjquillin
Posted: Tue May 15, 2007 7:12 am Post subject: Avionics Master |
At 06:48 5/15/2007, you wrote:
| Quote: | Why can one not just use the "off/on" switch on each device ?
There some are IM's that specify the piece of equipment is not to be
energized during engine start, and is to be powered from the
"avionics" bus and turned on post start.
Lack of a power switch is also common with remotely installed boxes,
some with similar power source restrictions.
One panel mounted instrument that immediately comes to mind is the
JPI EDM series engine monitors.
There is no "off/on" switch on this device.
Ron Q.
john(at)ballofshame.com Guest
Posted: Tue May 15, 2007 7:34 am Post subject: Avionics Master |
I'm guessing they mostly fail from lack of use. I often wonder if ANY
switch installed in the real world has ever made it to the rated # of
cycles achieved in the manufacturer'ss accelerated life testing.
-John
www.ballofshame.com
<mprather(at)spro.net>
Matt-
> radios.
> Mike Larkin
Posted: Tue May 15, 2007 8:24 am Post subject: Avionics Master |
Thanks to all who responded!
red :} (My initials but in this case, Rookie in Early Development)
Posted: Tue May 15, 2007 10:14 am Post subject: Avionics Master |
At 08:32 AM 5/15/2007 -0700, you wrote:
cycles achieved in the manufacturer's accelerated life testing.
Probably not. Lab tests never duplicate the combination of
stresses that over time (not operating cycles) will bring the
switch to it's knees.
Switches regularly used are happier/healthier and longer
lived than switches that sit for long periods of time unused.
I've replaced more switches that succumbed to under-use
than from wear-out.
Posted: Tue May 15, 2007 10:26 am Post subject: Avionics Master |
At 06:30 AM 5/15/2007 -0700, you wrote:
design that incorporated both. So, my electrical system is kind of a
combination of Z-12 and Z-13/8. I started with the Z-12 and then removed
the circuit with the SB-1/20A alternator. Then I added the SD-8/regulator
circuit from Z-13/8.
| Quote: | You are right about the search engine. I actually hit send on my email
and then instantly remembered that I should have checked the archives
first. Of course, I found that this subject has been discussed several
times before.
Call them up and ask them. The aura that surrounds the
avionics master switch and the mythology that birthed the
thing will never go away unless responsibly skeptic
consumers drive it away.
The "spikes" from starter motors don't exist. Spikes from
starter contactors do exist but they eat up starter push buttons
and do not propagate out onto the system.
| Quote: | I'm not sure we can know for sure unless someone tests the units
thoroughly either in the lab or just through normal use.
The guy who designed the thing should KNOW what stresses
his product will stand. Further, if there are stresses that
his product will not stand, he should know how big they are
and exactly where they come from. There's no excuse for
levying a requirement on the installation of a product without
being able to support that requirement with the "numbers" and
simple ideas that support them.
Call them up. Point them to articles on the website and ask
them where they're wrong. If you don't get good (understandable)
answers, get the folks names and phone numbers and let me call
them.
Posted: Tue May 15, 2007 10:28 am Post subject: Avionics Master |
Keep in mind that the z-figures are for ARCHITECTURE and
do not necessarily drive combinations of hardware. For example,
A figure Z-13 could use an internally regulated main alternator,
an externally regulated with any regulator.
Posted: Tue May 15, 2007 10:34 am Post subject: Avionics Master |
At 10:43 PM 5/14/2007 -0700, you wrote:
<mwcreek(at)frontiernet.net>
Power Connections
I'm skeptical of the "extended life" claim. However, any of the
z-figures offers dual feed busses. The e-bus is a dual feed bus
and addresses the reliability idea that might have driven any
form of "dual power input" scheme built into the equipment. If
the need to have the stuff powered off during cranking is real,
then one could install a normal feed switch in series with the
normal feedpath isolation diode.
Call them up and ask them which DO-160 power input protocols
are beyond their ability to tolerate. As with other cases,
if you don't get understandable answers, find out who I need
to talk to and I'll go find out what's really going on.
