nuckollsr(at)cox.net Guest
Posted: Thu May 10, 2007 7:37 pm Post subject: Dual Voltage Operation of Ford-style Alternator |
At 03:15 PM 5/9/2007 -0700, you wrote:
<paulmillner(at)COMPUSERVE.COM>
Hi Bob,
I'm considering a slightly unusual configuration on a Lycoming IO360A
installation... 12 volt alternator on a vacuum pad on the back of the
engine... powers the "essential" bus (there's a word you prefer to
essential, but it's late and I can't recall... well, I'm in Holland, too,
standing up in an internet cafe, and the wind is howling... enough excuses)
The "standard" Ford-style alternator on the front will attach to the
airconditioning (HVAC) bus... in the back of the plane, a variable voltage
air conditioining unit (Kelly Aerospace Thermawing or similar) will be
powered by the HVAC bus.
Under normal, non-cooling operation, the HVAC bus will be connected to
the main bus. The regulator will recognize this fact and regulate for
nominal 14 VDC. Both alternators will power the 14 volt systems.
When cooling is wanted (and of course loads allow for the rear mounted
alternator to carry the requirements), the breaker or contactor will be
opened between the HVAC bus and the main bus. This will also enable the
regulabor to assume 28 VDC mode.
The air conditioning unit will put out some cool air at 14 volts, but
twice as much cool air at 28 volts. The unit draws 50 amps over a voltage
range of 12 volts to 48 volts, and cooling output varies proportionately.
Any fatal flaw to this plan?
Assuming I use a 28 volt alternator (assume for the moment the
Cessna-style Ford Aeromotive once), should it regulate "happily" at 14
volts? I can think of schemes to "fool" the regulator with a voltage
divider connected to the A lead... switched as required to make a 14 volt
regulator think that 28 volts meets its needs, I'm sure you have the picture.
Thoughts? I've already tried to talk the better half out of retiring to a
hot place... and am now preparing contingency plans to deal with the
eventuality!
Paul, Berkeley CA (soon to be Palm Springs CA)
Is this the same Paul Millner with whom I shared many an
intriguing conversation back in the Compuserve AVSIG days?
What you propose has merit. I think I'd go for a more
controlled approach. Wire per Z-14 but with the main bus
split into a 14v ops and 28V HVAC busses. When in 14V ops
mode, both busses are tied together and the alternator
is controlled by a 14V regulator. When the higher performance
HVAC ops are desired, split the busses and control the
alternator with a B&C SR-1 regulator which is specifically
designed to operate a 14V alternator in 28V system. Under
this mode, goodies on the 14v portion of the main bus would
be allowed to go dark but could be brought up quickly by
closing the crossfeed contactor to the opposite side which
is always up and running at 14v.
Maybe we need an new Z-figure . . . perhaps a Z-14PM?
paulmillner
Joined: 09 May 2007 Posts: 21 Location: Berkeley, California
Posted: Thu May 10, 2007 10:41 pm Post subject: Re: Dual Voltage Operation of Ford-style Alternator |
Hi Bob!
Indeed, it's the same me. I wasn't aware of that functionality of the SR-1 regulator... do folks operate 14 V alternators in 28 volt systems simply because 14 V alternators are less expensive?
Any other ampacity limits to a 14 volt alternator in that service?
I was curious how far one could push a 14 volt alternator before reliability becomes an issue... making 48 volts at 50 amps seems like a stretch for a 14 volt / 60 amp device... I'm thinking of brush current/arcing, and I squared R heating of both the rotor and the stator.
The good news is that *usually* the HVAC usage should be transient... but there are times, especially with an inversion and ATC weirdness, when one would bump along in warm conditions quite some time... though the output could likely be reduced, say, to 28 volts.
How do 14 volt alternators hold up in 28 volt systems at, say, 80% rated load?
Paul, remote from Amsterdam
_________________ Paul Millner, Berkeley CA [OAK] |
