jhasbrouck(at)woh.rr.com Guest
Posted: Tue May 08, 2007 9:58 am Post subject: Pitch Servo |
Everyone,
Thanks for all of the replys! Talked to Tru-Trak this morning and this is what I found out. First, the pdf on the website for the -10 pitch servo is WRONG. It is the older version. How about that for keeping things up to date? According to Zach at TT the hole for the elevator bellcrank is to be 2.5" up from the center bearing AND .25" aft as was mentioned in an earlier post. Hole size is for an AN-3 bolt which should be a #12 drill. ( Zach said of the hole size, " we try to keep it around .200", about a #8" ) Well Zach's way off on that one. Tim posted earlier that the later versions of the torque multiplier worked OK with the original hole location. Zach said it should work at that location as long as there is full control movement. So here's my dilema. I drilled the hole assuming that the drawing on the web site was correct. I only drilled a guide hole (#30) though. According to Tim this location works fine and if there is plenty of movement in the servo to allow full control movement I'll leave it where it is. Does .25" make that much difference? If it's going to be a problem later I'll just make a new bellcrank. BTW: The servo bracket for the pitch servo is included in the fuselage kit from Vans....John
Randy(at)abros.com Guest
Posted: Tue May 08, 2007 10:06 am Post subject: Pitch Servo |
John, I as well as Tim installed the update kit later after the hole was drilled. It works fine. I would move forward. Randy
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hasbrouck
Sent: Tuesday, May 08, 2007 10:57 AM
To: RV LIST
Subject: Pitch Servo
Everyone,
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
rene(at)felker.com Guest
Posted: Tue May 08, 2007 10:09 am Post subject: Pitch Servo |
One note, if I remember right the servo bracket that Vans provided did not work for me. I had received another one with my servo that did work. I got mine with my servo from Stein…..
Rene' Felker
N423CF
40322
801-721-6080
Sent: Tuesday, May 08, 2007 11:57 AM
To: RV LIST
Everyone,
mritter509(at)msn.com Guest
Posted: Tue May 08, 2007 10:17 am Post subject: Pitch Servo |
I also used the original hole and it works great.
| Quote: | From: "John Hasbrouck" <jhasbrouck(at)woh.rr.com>
To: "RV LIST" <rv10-list(at)matronics.com>
Subject: Pitch Servo Date: Tue, 8 May 2007 13:57:00 -0400
Everyone,
Like the way Microsoft Office Outlook works? You’ll love Windows Live
Hotmail.
LloydDR(at)wernerco.com Guest
Posted: Tue May 08, 2007 10:29 am Post subject: Pitch Servo |
The bracket in the kit is not the same one as is need for the new Torque multiplier, they sent me a new bracket when I got my servo's from Stein and I used the original bracket to make a parking brake mount. I can take pictures of the mount and servo if you want, or I think Deem's has some excellent photo's on his site.
Dan
N289DT RV10E
Sent: Tuesday, May 08, 2007 1:57 PM
To: RV LIST
Everyone,
Deems Davis
Posted: Tue May 08, 2007 12:14 pm Post subject: Pitch Servo |
Here's the link to several pic's in this album.
http://deemsrv10.com/album/Wiring/slides/DSC03208.html
Deems Davis # 406
Finishing - ( A Misnomer ! )
Lloyd, Daniel R. wrote:
| Quote: | The bracket in the kit is not the same one as is need for the new
Dan
N289DT RV10E
Tim Olson
Posted: Tue May 08, 2007 12:52 pm Post subject: Pitch Servo |
Yes, there is a revised bracket that you can get from TruTrak that
is different than at least the earlier kits got with the tail kit.
It just slightly moves the servo location.
Regarding John's question about the torque enhancer and the hole
location....it's hard for me to guarantee it'll work for you
no matter which hole you end up choosing, because there are now
3 variations of the pitch servo link that I know of...the one I'm
using now is the 3rd, and it's a wheel with a track kind of
arrangement. I've always used the original hole and it has worked
perfectly for me. But, I don't doubt that the other location could
probably work too, and it may even be more idea without me knowing
it. In the end, you can probably make either spot work, and you
could even split the difference and put the hole in the middle. I
really doubt the hole location is that precise...but this isn't
a recommendation to stray from plans...just pointing out that it
probably isn't that critical.
I guess if it were me, I'd wait to final drill until you get ALL
of the parts and are ready to hook it up permanently, AFTER you
have your elevator on and everything else. Then you can get to
the part where you hook up the link, work the thing into full
pitch travel both directions while holding the torque enhancer close,
and just see if both extremes would work. If so, just drill away.
Don't sweat it too much...worst case, you just make a new bellcrank
and that part can't be too much money.
Rene Felker wrote:
| Quote: | One note, if I remember right the servo bracket that Vans provided did
Rene' Felker
Posted: Tue May 08, 2007 3:33 pm Post subject: Pitch Servo |
Thanks all for the advice. From what I've seen on Deems' and Tim's sites
this thing should fly ( pun intended ) as is. And Tim's right, a new
bellcrank is short money and very little time to make up. Maybe I could
exchange the old bracket for new bellcrank parts. Hmmmmmmmm. Did I mention
I'm cheap? Another example of the wealth of info this board
provides....john
John Hasbrouck
#40264
