Posted: Sat Feb 04, 2006 1:52 pm Post subject: Voltage Regulator Failure |
Tim, I had similar problems with my rectifierlast year, completely cured by
replacing it, but you may find the message below of help. Afraid I was too
keen to get back flying to follow the diagnostic advice! Regards, David
Joyce, G-XSDJ
Virus scanned by Lumison.
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
ward.t(at)xtra.co.nz Guest
Posted: Thu Feb 09, 2006 2:58 pm Post subject: Voltage Regulator Failure |
Hi Europaeans,
Fixed the Regulator/Rectifier problem.
Had the unit checked out by a Rotax agent here and all was OK. So back to
tracking it down with the voltmeter. Before re-installing the DIN plug to
the Regulator/Rectifier I cleaned the terminals and checked the crimping. I
then made sure the connections were good and plug FULLY installed. I noticed
then the plug had gone in a lot further from when I took it out. Ah Ha. So
started up the engine and hey presto!! it was charging the battery.
Conclusion; Vibrations, I think, must have caused the plug to slip down,
despite the plastic holding brackets and caused a stator terminal to not
connect sufficiently well.The plastic brackets certainly do not hold it
securely in place.
So many thanks for your help.
Cheers,
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8005
New Zealand.
Ph +64 3 3515166
Mobile 021 0640221
rholder(at)avnet.co.uk Guest
Posted: Thu Feb 09, 2006 3:46 pm Post subject: Voltage Regulator Failure |
| Quote: | Hi Europaeans, Fixed the Regulator/Rectifier problem.
was OK. So back to tracking it down with the voltmeter.
Before re-installing the DIN plug to the
the crimping. I then made sure the connections were
good and plug FULLY installed. I noticed then the plug
Ha. So started up the engine and hey presto!! it was
charging the battery. Conclusion; Vibrations, I think,
must have caused the plug to slip down, despite the
to not connect sufficiently well.The plastic brackets
certainly do not hold it securely in place.
I wish I could be so optimistic. Mine went on and off
several times, Normally at the flare stage of the flight,
and then worked perfectly the next time I tried it.
I tried various cabling fixes and each time it was OK and
then it wasn't OK.
I changed the regulator and that one was faulty in another
way (since returned).
I opened up my original regulator and re-soldered three
possible dry joints. Worked so far but no real test as the
wx has been bad (and I am fiddling with the oil thermostat).
As I said to someone, if the external wiring is OK and the
regulator is at fault then it can either be a dry joint
(which will normally mean it fails intermittently) or a
component failure, which means it fails and stays failed.
The black plug goes in so that the retaining clips just
pass their notches. It is possible that the faston connectors
weren't all the way into the black connector. They have
small tangs on them to keep them in place - if you used
the ones that came with the regulator - fine; if you used
others then the chances are that they didn't have tangs
and the connector could have been pushed out (or rather
not pushed in enough)
This is why I asked whether your regulator failure was
intermittent or permanent.
Anyway I hope that your problem is fixed. The engine will
run for a long time with no charge !
Maybe we should all carry a spare at all times
Best wishes
Richard
G-OWWW High Cross
