rehn(at)rockisland.com Guest
Posted: Fri May 04, 2007 12:53 pm Post subject: Tire change |
I am going to change my tire and tube and was looking to recommendation for lifting aircraft to remove tire. I have a hoist-crane that I could lift at the engine or engine mount. Would that cause any issues or too much stress at attach points? Thanks for help
Jerry
914 Mono
terrys(at)cisco.com Guest
Posted: Fri May 04, 2007 2:11 pm Post subject: Tire change |
Hi Jerry,
Another option for removing the monowheel wheel is a simple wood jacking block, as seen in the following Europa mods link;
http://terryseaver.home.comcast.net/N135TD_mods.htm
Look at the section titled; Mono-wheel jacking block
regards,
Terry Seaver
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Jerry Rehn
Sent: Friday, May 04, 2007 1:49 PM
Subject: Tire change
Jerry
914 Mono
[quote] [b]
willie.harrison(at)tinyon Guest
Posted: Sat May 05, 2007 9:21 am Post subject: Tire change |
Likewise I have to change tyres on my trigear, so any advice on jacking a trike would be welcome.
Willie Harrison, G-BZNY
On 4 May 2007, at 21:49, Jerry Rehn wrote:
Jerry
914 Mono
kheindl(at)msn.com Guest
Posted: Sat May 05, 2007 1:01 pm Post subject: Tire change |
Whenever I need to work on the wheels, I push a suitable steel rod (not sure
about the diameter)
into the hub, and then put a jack underneath at the far end. To remove the
wheel you move it outboard next to the jack, then put a support on the
inboard side, and lower the jack. Sounds complicated but is dead simple.
Karl
| Quote: | From: William Harrison <willie.harrison(at)tinyonline.co.uk>
Reply-To: europa-list(at)matronics.com
Subject: Re: Tire change
Date: Sat, 5 May 2007 18:20:34 +0100
>for lifting aircraft to remove tire. I have a hoist- crane that I could
>Jerry
>914 Mono
>http://www.matronics.com/Navigator?Europa-List_-
>============================================================ _-
>forums.matronics.com_-
Reserve your place in history - Email Britain!
http://www.emailbritain.co.uk/
topglock(at)cox.net Guest
Posted: Sat May 05, 2007 2:41 pm Post subject: Tire change |
Willie,
Using a short 6x6, on top of a hydraulic floor jack it place the 6x6 just inboard of the leg and jack up one side at a time. Never had any problems with lifting this way...
Jeff - Baby Blue
William Harrison wrote: [quote]Likewise I have to change tyres on my trigear, so any advice on jacking a trike would be welcome.
Jerry
914 Mono
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Sun May 06, 2007 7:52 am Post subject: Tire change |
Hi all.
For what its worth I always travel with my jacking block. I have had one incident where my tube blew out on landing at an airport away from my home base. It would have been very difficult to deal with the situation had I not had a jacking block with me.
To give you an idea I had 5 hefty guys to help be move my aircraft and it was a major effort to move it the 3 ~ 4 meters required to clear the airstrip.
Paul
[quote] --
Posted: Sun May 06, 2007 8:23 am Post subject: Tire change |
How does anyone rate tyre inflation/sealing aerosols for emergency get-you-home application?
On 5 May 2007, at 14:48, Paul McAllister wrote:
[quote]Hi all.
Paul
[quote]--
rampil
Posted: Sun May 06, 2007 8:44 am Post subject: Re: Tire change |
I am with Karl in tire changing technique.
I have a nicely primed and painted 1" steel bar about 18" long to slide
inside the axle. Several steps but not hard. An actual trigear jack point
would have been a nice design feature.
Its time, after about 70 flight hours to replace my main tires again.
I've been using new Goodyear Flight Special II tires and these prime
tires last fewer than 400 landings on concrete, both sides losing outboard tread at a prodigious rate.
I wish there were a practical fix to this design "feature" as it is a bit pricey.
carl(at)flyers.freeserve. Guest
Posted: Sun May 06, 2007 1:28 pm Post subject: Tire change |
The jacking block is a great idea but if you are without one there is another easy solution.
Most jacks kits (aka Halfords) and calso ars come with foldable metal wheel chocks.
Open out the chock as you would with a car and hold the face of the chock (which would normally face the wheel) against the underside of the swinging arm such that the top edge of the chock sits against the two boltheads which protrude from the underside of the arm. They are only about 3mm in depth but it is sufficient to support the weight of the aircraft.
The jack is then placed underneath the chock and as long as pressure is applied it will hold the chock in place and enable the wheel to be jacked off the deck and removed for repair.
Because the chock is made of thin guage mild steel it will seat itself against the bolt heads and there is little chance of being displaced. None the less it would be sensible to support the swinging arm with a block of wood while the wheel is away being fixed.
Its not as good as the proper block (discussed in this forum) but as I said it is a readily available solution which will get you out of a fix.
I have used it a couple of times as I have had problems with the hydraulic brake cylinder siezing and locking up the brake.
Carl Pattinson
G-LABS
graham(at)pocock56.fsnet. Guest
Posted: Mon May 07, 2007 2:23 am Post subject: Tire change |
lgds(at)post6.tele.dk Guest
Posted: Mon May 07, 2007 3:16 am Post subject: Tire change |
- I carry one in my AC.... could help me get home to tea one day./Gert
OY-GDS/mono/914
Den 07/05/2007 kl. 12.22 skrev Graham:
[quote]---
raimo.toivio(at)rwm.fi Guest
Posted: Mon May 07, 2007 5:27 am Post subject: Tire change |
I had a situation during our maiden flight:
the tire was inflated couple of years ago
and checked just before take off but after
this happy flight we noticed it was almost empty!
So, we completed our maiden flight with broken tire!
We repaired /inflated it by using aerosol and filled
until tire´s pressure was 1,5 bar. So far it has been OK.
After this experience I am going to carry tire
inflation aerosol always with me. I am not sure
but think it mades a permanet fixation - not only
temporary to get home. So I rates it high!
And cheap!
And fast!
And easy!
And clean!
Wishes, Raimo
Posted: Mon May 07, 2007 6:14 am Post subject: Tire change |
I have a new spare can and weighted it:
just 261 grams (=0,575 lbs).
Raimo
mikenjulie.parkin(at)btop Guest
Posted: Mon May 07, 2007 10:36 am Post subject: Tire change |
While they work admirably, the tyre inflating aerosols have one major drawback - if the experience with my Peugeot 206 is anything to go by.
The 206 does not come with a spare tyre, so I used the supplied aerosol to get me home. It worked brilliantly, but when I took the offending item to the tyre place to have it repaired, I was told that after using the aerosol it was impossible to repair. I had to buy a new tyre.
Expensive puncture.
regards,
Mike
Posted: Mon May 07, 2007 11:39 am Post subject: Tire change |
For what it's worth, I remember hearing on a Monowheel you can remove
starboard wing, starboard stabilator, put seat cushions under the fuse and
roll plane on side and lift wheel off ground to fix flat.
Never tried yet, but may worthy remembering in a "Pinch".
Ron Parigoris
ami(at)mcfadyean.freeserv Guest
Posted: Mon May 07, 2007 12:02 pm Post subject: Tire change |
Some tyre fitters charge extra for a (tubeless) tyre change if sealant has been used; they claim it's a mucky job!
Duncan McF
Posted: Tue May 08, 2007 2:28 am Post subject: Tire change |
I have thought it is not only to get home
- repair should be permanent until a next
puncture happens. In my case my tyre has
been OK after aerosol, so far. And if not,
inner tyres are not expensive.
Att least I have in my mono an inner tyre...
Regards, Raimo
Posted: Tue May 08, 2007 4:06 am Post subject: Tire change |
It is brilliant stuff, BUT, can I sound a note of caution from personal experience?
A tin of it once got me almost home after a blow out on a motorbike. 100 miles later (1 mile from home...) it went again and refused to respond to a second dose. When examined later, a 3 inch split was found in the inner tube (caused by incorrect fitting - it had been put in with a crease which had caused the rubber either side to abrade). The magic aerosol held it together - amazingly - and I might have trusted it as a permanent repair if it hadn't gone again. That's the problem: the stuff is so good that it may, under some circumstances, be able to mask a seriously faulty tyre.
I always carry some when touring in the car/bike/plane, (have never needed it since though), but would always want to have a proper repair ASAP after getting home.
Incidentally, BMW used to supply a tyre plugging kit in motorcycle tool kits for the user to repair a puncture at the roadside without needing to remove the tyre. They have stopped now due to fears of product liability, I believe, although you can still get the kits. They rely on a crochet hook type tool to instal the plug and have a cylinder of compressed gas to reinflate the tyre.
Willie Harrison - G-BZNY
On 8 May 2007, at 11:30, Raimo Toivio wrote:
[quote]I have thought it is not only to get home
Regards, Raimo
[quote]---
Posted: Tue May 08, 2007 12:07 pm Post subject: Tire change |
I can confirm that those kits are still available, although of course they are only for tubeless tyres.
I thought that plugging was illegal for UK road-use!
Duncan Mcf.
Posted: Tue May 08, 2007 11:05 pm Post subject: Tire change |
I have used "slime" (green stuff) in the wheeles of my car for the last couple of years and it has saved repairs on about 3 or 4 punctures. When the wheels were last replaced I think about three had been dosed with the stuff and the tyre mechanics didnt say a thing.
The manufacturer says you shouldnt exceed 60mph with the stuff but I think they are simply covering their backsides. I have only had one puncture unseal itself and it reverted to a slow puncture which was in no way dangerous. It resealed itself (see below)
Its brilliant stuff and usually plugs a hole straight away. One tyre didnt seal straight away and I simply left the car parked with the hole pointing at the ground and the next day it was fixed - probably drove another 5000 miles on that tyre.
If you overdo the application it can throw the wheel out of balance though this wouldnt be an issue with an Europa.
Have a couple of cans of the stuff in the gagage and was meaning to use some on the Europa but havent got round to it. You can buy it in tubed or tubeless variety. The tubeless has loads of ground up rubber bits in it.
