cleone(at)rr1.net Guest
Posted: Thu Feb 09, 2006 8:00 am Post subject: Rivnuts or Anchor Nuts or Am I Nuts? |
Scott, About 15 yrs ago while building my first plane I bought a kit and
supply of rivnuts and didn't like them so haven't used one for
years. Problem was the few that turned and the trouble in repairing the
problem. Perhaps I didn't learn the proper way to do this if there is
one. Best of luck, Cleone
At 01:00 PM 1/17/2006, you wrote:
ggower_99(at)yahoo.com Guest
Posted: Thu Feb 09, 2006 10:21 am Post subject: Rivnuts or Anchor Nuts or Am I Nuts? |
I have used them in some panels.
What I use when installing them is a little amount of epoxy putty, the one that comes in two sticks and they blend with the fingers.
Well, given my poor explanation, I aply a little amount betwen the rivnut and the skin before pressing it, then wipe the excess, is like welding the rivnut in place.
The bolts I install them with a drop of linseed (sp?) oil, to prevent corrosion.
I used them in my 701 to install the LRI and Pitot plates, which I plan to remove every year to clean and inspect.
Once I installed some in my old ultralight have 5 years there, without removing and last saturday I removed tested the bolts and they worked out ok.
I think one important thing is the amount of potential corrosion in your area (sea breeze) to get the bolts freezed, removing them for mantainance at least once a year, may not get enough corrosion to "weld" to the rivnut. Corrosion of the bolt is the problem.
The anchor nuts are better used for more structural and permanent attachments where holding the nut with a wrench is not possible, Yes is perfectly OK to use them. more work, more weight and more expensive...
Saludos
Gary Gower.
tutuzulu(at)gmail.com Guest
Posted: Thu Feb 09, 2006 10:35 am Post subject: Rivnuts or Anchor Nuts or Am I Nuts? |
I'm thinking of putting flat lock-washers on the backside of the
rivnuts before rivetting them. Anybody have any experience with this?
Bob Miller
601HD N722Z
Charlottesville, Virginia
cgalley(at)qcbc.org Guest
Posted: Thu Feb 09, 2006 11:55 am Post subject: Rivnuts or Anchor Nuts or Am I Nuts? |
Don't think it is a good idea from a dissimilar metals standpoint. They
already stand proud as it is. The washer would only make it worse.
Cy Galley - Chair,
Air Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
planejim(at)bellsouth.net Guest
Posted: Thu Feb 09, 2006 3:12 pm Post subject: Rivnuts or Anchor Nuts or Am I Nuts? |
I agree with Cy, the washers under the rivnuts is not a good idea. In fact
as I've said here before, after about 50 years of messing around this stuff
I only used rivnuts for interior panels and things like that . In fact I
don't use them at all anymore. Go to the effort of installing "Nutplates"
(there are many different kinds for different applications) especially in
locations where you will be removing the screws or bolts on a regular basis.
Since the introduction of 3/32" pull or blind rivets used for attachment, it
is fairly easy to install nutplates. No need to use a rivet gun and bucking
bar . Go for nutplates every time and leave those antique rivnuts in the
bin!
Jim Hoak
Posted: Sun Feb 12, 2006 7:28 pm Post subject: Rivnuts or Anchor Nuts or Am I Nuts? |
Thanks Jim.
I just found out that ACSpruce sells "keyed rivnuts", apparently to
keep them from spinning out. What would you think of these for a
place that needs rare accessing, mainly for inspections? Nut plates
won't work in the forward top skin I'm working on. I'm sure I'll need
to get to the fuel tank someday.
Say, what days do you think I'll be able to help you at Sun 'n Fun?
On 2/9/06, Jim Hoak <planejim(at)bellsouth.net> wrote:
bin!
Jim Hoak
Posted: Sun Feb 12, 2006 8:16 pm Post subject: Rivnuts or Anchor Nuts or Am I Nuts? |
Riv-nuts are aluminum, Soft Aluminum. Put a steel screw or a SS screw and
dis-similar metal reaction creates corrosion. Even the keyed Riv-nuts are a
pain. Install nut plates is possible and be done with it.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
EAA Sport Pilot
Posted: Mon Feb 13, 2006 6:50 am Post subject: Rivnuts or Anchor Nuts or Am I Nuts? |
The rivnuts have always been "keyed" but most people don't have the tool
that cuts the little notch in the edge of the hole thaar the key fits into.
As Cy says the rivnuts are soft aluninum and screws are steel. Thats a
problem, especially if water gets in there. If you install them at the skin
over the fuel tank you just are taking your chances.
As for days at SnF, I always work with my volunteers to make sure they get
to attend the forums, events etc. that they want and work around their
schedule. As for preference, my main needs are Wed thru Sun. I'll have Monda
send you a "FORM" as soon as I hear from her! She's late geting going this
year. I'll keep in touch.
Jim H.
Larry McFarland
Joined: 10 Jan 2006 Posts: 36 Location: East Moline, Illinois
Posted: Mon Feb 13, 2006 7:05 am Post subject: Rivnuts or Anchor Nuts or Am I Nuts? |
The forward top skin can be removed with J-nuts if you configure the
sheet metal somewhat like what I've done at the front sides. These
J-nuts are for
6-32 screws and cost about $10.00 for 50. I've had the front top skin
off a dozen times
for electrical work, transponder certification etc and believe these are
the way to go.
Nut plates are expensive and relatively difficult to replace if they go
bad. I can remove
or replace the forward top skin in about 20-minutes. The canopy only
needs to be up
when doing this. If you would like more information and part numbers for
these, just ask.
see links
http://www.macsmachine.com/images/canopy/full/uclips.gif
http://www.macsmachine.com/images/canopy/full/canopyframefrt.gif
Larry McFarland - 601HDS at www.macsmachine.com
Bob Miller wrote:
Thanks Jim.
>Bob,
>bin!
>Jim Hoak
>do not archive
_________________ Larry McFarland - 601HDS - Stratus |
