801 Spinners
squiggles
PostPosted: Thu May 03, 2007 5:00 pm    Post subject: 801 Spinners Reply with quote
Hello All...
I am finally reaching the point of needing to purchase a spinner for my 801 in preparation of making the cowl this summer. I tried contacting UHS Spinners, but have been unable to get them to reply to my queries.
For a 3 blade IVO magnum on an SAE 1 hub, what are the possible options for purchase? Ideally, I'd like to purchase one which is already cut out...
Any recommendations?
Thx...
-Scott
agustafson(at)chartermi.n
PostPosted: Thu May 03, 2007 5:14 pm    Post subject: 801 Spinners Reply with quote
My guess is you won't find one already cut for an IVO. There're not that bad
to cut though. I've done 2 now, one for an IVO Medium 3 blade and now one
for a McCauley. Got mine through ACS.
Aaron do not archive
rroberts
PostPosted: Thu May 03, 2007 5:50 pm    Post subject: Re: 801 Spinners Reply with quote
I got a UHS for my IVO through Aircraft Spruce...pre cut also...
 Filesize:  137.53 KB
 Viewed:  540 Time(s)
Low & Slow
Rick
www.n701rr.com
www.ricksplace.info
lrm(at)skyhawg.com
PostPosted: Thu May 03, 2007 6:14 pm    Post subject: 801 Spinners Reply with quote
UHS thru AirCraft Spruce has a 6+ week wait time. But they will cut them
for you. I found Valley Engineering to have the best prices for an aluminum
spinner, but you gotta cut'm. I think it was around $85 including the
bulkhead. It's not that hard to cut it out, make a cardboard cutout first.
I had a machine shop cut out my SAE1 holes or you can get a squash plate to
use for a pattern. You will have to have the plate anyway. Larry, N1345L,
www.skyhawg.com
vgstol(at)bigpond.net.au
PostPosted: Fri May 04, 2007 12:49 pm    Post subject: 801 Spinners Reply with quote
Have a look at www.cumminsspinners.com .
