tail spring
kr2(at)earthlink.net
PostPosted: Wed May 02, 2007 5:14 pm    Post subject: tail spring Reply with quote
Hi ALL, I have a small question and would love to hear your advice....on my Kitfox 4 I also have the 2 leaf spring,and am considering change to the newer 3 spring,I have had no prblems yet with a tt of 82hrs,but after listening to yall I might down the road.......Do I need to do another weight&balance when I change out from a 2 leaf to a 3 leaf tail spring?
I know this might be a stupid question,but when I added my landing lights my IA made me do another W&B,
Thanks Mark....N61AC
Mark Thompson
kr2(at)earthlink.net (kr2(at)earthlink.net)
EarthLink Revolves Around You.
Lynn Matteson
PostPosted: Wed May 02, 2007 5:33 pm    Post subject: tail spring Reply with quote
I wouldn't think you'd have to do another W&B, just calculate where
the additional weight is going (the arm) and figure it in. Same for
the landing lights, I would think...but I've been wrong before.
Lynn Matteson
Grass Lake, Michigan
flying w/250+ hrs
Mark Thompson
www.matronics.com/Navigator?Kitfox-List _-
Lynn
Kitfox IV-Jabiru 2200
N369LM
roncarolnikko(at)hotmail.
PostPosted: Wed May 02, 2007 7:51 pm    Post subject: tail spring Reply with quote
Simple math Mark, but yes I would make another sheet. If many changes are
made or you are unsure of the cog then I would reweigh. Ron NB Ore
N541KF VW Kitfox IV flying, N117AF 582 Avid flying, N67779 C152 in annual
sitting.
Subject: tail spring
Date: Wed, 2 May 2007 21:13:26 -0400
Mark Thompson
Watch free concerts with Pink, Rod Stewart, Oasis and more. Visit MSN In
Concert today. http://music.msn.com/presents?icid=ncmsnpresentstagline
Float Flyr
PostPosted: Thu May 03, 2007 4:31 am    Post subject: tail spring Reply with quote
This far North we have to do another W&B if the weight of the aircraft has changed by more than 10% since the last W&B. Smaller changes can be documented with an amendment to the W&B. you would still have the paper work but don't have to go get scales and level wings etc. etc.. Check with your AI. I'm pretty sure there is a similar procedure south of the lakes.
[img]cid:140142512(at)03052007-0BC9[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
 Filesize:  19.77 KB
 Viewed:  204 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
kitfoxmike
PostPosted: Thu May 03, 2007 5:56 am    Post subject: Re: tail spring Reply with quote
Wow, a new w&b on landing lights, where did you put them on the plane.
