Albert Gardner
Posted: Wed May 02, 2007 2:43 pm Post subject: Electrical: Dynon and Lightspeed Ignition |
My Dynon 180 has a input called ‘keep alive’ which will keep the internal battery charged on the unit so that it doesn’t run down and require reloading the program. It needs to go directly to the battery bypassing the master contactor. Unfortunately, I did not run a wire for that under the floor. Fortunately, the Lightspeed ignition needs to run a shielded conductor back to the battery also. Unfortunately, I didn’t run that wire either. Fortunately, that shielded wire will go to a circuit breaker so I can tie the Dynon keep alive circuit to that point, and I did leave some wireways under the floor and on the sides with string in them so it will not require disassembling the fuse in order to add the wire. A heads-up for Lightspeed and Dynon users.
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
Posted: Wed May 02, 2007 6:31 pm Post subject: Electrical: Dynon and Lightspeed Ignition |
If you have the internal battery, don't use keep alive at all. I can explain why later if you want.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
352-427-0285
