Posted: Mon Apr 30, 2007 10:40 am Post subject: RV10 Center cabin top brace. |
I have been trimming the windows and working on the cabin top. By the way,
an electric high speed grinder with #100 grit works well for finalizing the
shape on the windows. It heats up the plexiglass and takes it away all at
the same time. Leave the plastic covering on. Outside air temps, as always
need to be warm.
In section 43 the manual asks you to make aluminum spacers that will house
the four screws that through bolt the center brace to the cabin top. I am
not one that will normally question the plans, but the aluminum
tubes(dowels) I imagine will be bonded into the cabin top and and keep the
center brace from pulling out. Being that there are four, it should be
fairly strong.
What I question however if that there is only so many layers of fiberglass
on the outside of the cabin top and so many on the inside. Between there is
the usual foam sandwich. These aluminum dowels will get there retension my
bonding to both the inside and outside layer of glass, not the foam. The
screw head is really not any large in diameter that the O.D. of the aluminum
dowel, so it will not provide any retension.
Basically, it seems like the cabin top fabricator should have place a
hardpoint(Hardwood) in this area instead of the foam or we should be placing
a steel plate on the outside to keep these dowels from pulling through.
Maybe because there are four it is not a problem, but seeing that they are
all in a one inch square spot, my mind thinks it should be made better.
John G.
Rick S.
Posted: Mon Apr 30, 2007 11:03 am Post subject: RV10 Center cabin top brace. |
John,
When I drilled mine there appears to be some sort of filler material at the attach point. The shavings from the drill bit looked like wood...not sure if it's really wood but it is for sure filled with something solid, at least on mine. Make sure you drill the holes undersized enough to hold the bushings or you will have fun countersinking the on top. I had to set mine with epoxy to allow the countersink to cut instead of rotate the bushing...the measurment called out in the plans cracks me up...I think it's to the 64th of an inch and I had to trim at least 3/32 maybe a little more off to make them flush with the cabin inside and out. FWIW, I used my mic to measure and verify the correct length and these were the most exact bushings for the kit I made to date, and the first ones I ever had to trim material from
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
dlm46007(at)cox.net Guest
Posted: Mon Apr 30, 2007 11:54 am Post subject: RV10 Center cabin top brace. |
You can also just clean out the foam and inject a mixture (resin, cabosil
and chopped fibers). Be sure and tape the bottoms of the holes and you will
get a nice solid hard point without aluminum spacers.
Posted: Mon Apr 30, 2007 12:16 pm Post subject: RV10 Center cabin top brace. |
Again, the idea is to have as much of the lamination(s) covering over the
hardpoint. It needs to really be inside the lamination, not cut into it.
Your suggestion would be 50% correct if you didn't drill throught the
outside lamination.
I don't know a way to remove a large enough block of foam through four holes
without the use of solvents which will effect the integrity of the
surrounding foam.
When I drilled my four holes the drill absolutely popped into foam, not
wood, unless it was balsa.
Did others really find wood???? I might have something missing. Maybe a call
to Van's is in order.
[quote]From: "David McNeill" <dlm46007(at)cox.net>
Subject: RE: RV10 Center cabin top brace.
Date: Mon, 30 Apr 2007 12:49:37 -0700
glastar(at)gmx.net Guest
Posted: Tue May 01, 2007 12:54 am Post subject: RV10 Center cabin top brace. |
Hello John,
on the GlaStar which has a fibreglass shell over a steel cage we did
have plenty of hard points (64) to make. How was it done, first we had
to drill a #10 hole with the tabs as guide trough both layers of the
laminate. Next we did bent a wire (0.050) in an L-shape by 3/8" with
that L shape wire it was possible to ream all the foam out of the space
between inner and outer laminate, a shop vacuum should get all the
particles out. A mixture of Q-cell and epoxy then was pushed into that
void (covered on one side with a tape) do that slowly to fill it in
order to get all air out or drill another 1/16" vent hole in about half
way of the hole. that leaves you at the end with a 3/4 inch hard point.
Hope it helps, I could otherwise scan you the GlaStar Manual pages.
br Werner
the hardpoint. It needs to really be inside the lamination, not cut
into it.
outside lamination.
holes without the use of solvents which will effect the integrity of
the surrounding foam.
not wood, unless it was balsa.
a call to Van's is in order.
> To: <rv10-list(at)matronics.com>
> cabosil
> you will
Posted: Tue May 01, 2007 1:11 am Post subject: RV10 Center cabin top brace. |
Forgot, use a syringe to fill the void
Werner Schneider wrote:
Hello John,
space between inner and outer laminate, a shop vacuum should get all
the particles out. A mixture of Q-cell and epoxy then was pushed into
that void (covered on one side with a tape) do that slowly to fill it
in order to get all air out or drill another 1/16" vent hole in about
half way of the hole. that leaves you at the end with a 3/4 inch hard
point.
br Werner
> <indigoonlatigo(at)msn.com>
> into it.
> outside lamination.
> four holes without the use of solvents which will effect the
> integrity of the surrounding foam.
> John
>> cabosil
>> you will
Posted: Tue May 01, 2007 6:50 am Post subject: RV10 Center cabin top brace. |
Now, why did I not think about that L-shaped wire and a drill. That is
pretty clever.
Thanks for the information.
JOhn
[quote]From: Werner Schneider <glastar(at)gmx.net>
Subject: Re: RV10 Center cabin top brace.
Date: Tue, 01 May 2007 10:53:38 +0200
Hello John,
on the GlaStar which has a fibreglass shell over a steel cage we did have
plenty of hard points (64) to make. How was it done, first we had to drill
a #10 hole with the tabs as guide trough both layers of the laminate. Next
we did bent a wire (0.050) in an L-shape by 3/8" with that L shape wire it
was possible to ream all the foam out of the space between inner and outer
laminate, a shop vacuum should get all the particles out. A mixture of
Q-cell and epoxy then was pushed into that void (covered on one side with a
tape) do that slowly to fill it in order to get all air out or drill
another 1/16" vent hole in about half way of the hole. that leaves you at
br Werner
>outside lamination.
>holes without the use of solvents which will effect the integrity of the
>surrounding foam.
>John
>>will
Posted: Tue May 01, 2007 6:55 am Post subject: RV10 Center cabin top brace. |
A Monojet syringe, you can buy a box of them through a dental supply house
for a lot cheeper than Aircraft Spruce sells them. Fill from the bottom so
the airspace is pushed out by the raising level of epoxy cotton flox mix.
Date: Tue, 01 May 2007 11:10:54 +0200
>Hello John,
>Next we did bent a wire (0.050) in an L-shape by 3/8" with that L shape
>wire it was possible to ream all the foam out of the space between inner
>and outer laminate, a shop vacuum should get all the particles out. A
>mixture of Q-cell and epoxy then was pushed into that void (covered on one
>side with a tape) do that slowly to fill it in order to get all air out or
>drill another 1/16" vent hole in about half way of the hole. that leaves
>br Werner
>>outside lamination.
>>surrounding foam.
>>John
>>>cabosil
>>>will
greenley(at)starband.net Guest
Posted: Tue May 01, 2007 8:28 am Post subject: RV10 Center cabin top brace. |
When one says the incorrect name to the assistent and then the asistent does
not correct the doctor, this is the end result. Thanks for the
clarification.
These work very well, one needs to cut the end to the appropriate size
opening depending on the material that is mixed with the resin. Flox
requires the largest opening.
[quote]From: "William Greenley" <greenley(at)starband.net>
Date: Tue, 1 May 2007 11:50:36 -0400
Not to be picky but if you are searching for these the spelling is
Monoject.
Bill Greenley
Soon to be RV-10 builder
