wdaniell(at)etb.net.co Guest
Posted: Mon Apr 23, 2007 7:18 am Post subject: Oil pressure |
I know that I have asked this before but I wonder if everyone could rack their brains.
My motor starts fine the pressure goes up to 5.5 bar for about 2-4 minutes.
It then falls with not loss of rpm to 1.5 bar for about 2-5 minutes.
It then goes back up to 5.5 and stays there without a problem.
The oil pressure sender is working fine and is the gauge – I have tested them both. The engine runs smooth and produces sufficient power. I run avgas because the premium mogas here is 95 or lower octane.
On a hot day the pressure drop is minimal on start up. So I am thinking that maybe this has something to do with viscosity. Perhaps even what Ira mentioned - lead accumulation in the oil tank.
Any ideas as to the cause?
How much damage will this do? Clearly this is not ideal but it could be one of those problems where the “solution” ends up being always out of reach.
Will
Colombia
Posted: Mon Apr 23, 2007 7:56 am Post subject: Oil pressure |
William Daniell a écrit :
| Quote: | My motor starts fine the pressure goes up to 5.5 bar for about 2-4
minutes.
of reach.
William,
If your engine is a Rotax 91X, then you might wish to review the SB on
oil starvation on startup.
Yes it may have something to do with viscosity when cold, and oil pump
starvation due to length/diameter/routing/obstruction of oil line.
Especially as you seem to say that the problem is less obvious on a hot day.
FWIW,
Gilles
http://contrails.free.fr
rehn(at)rockisland.com Guest
Posted: Mon Apr 23, 2007 8:29 am Post subject: Oil pressure |
You could test the oil system per SI-912-005. This would help determine problems of suctions and pressures. Also you might try purging the system per SI-04-1997. This is relatively easy to do and would insure there isn’t air in your system. Third check the oil relief ball and spring for wear and contamination another easy check.
Jerry
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of William Daniell
Sent: Monday, April 23, 2007 8:18 AM
Subject: Oil pressure
Will
Colombia
| Quote: | | http://www.matronics.com/Navigator?Europa-List | 01234
Posted: Mon Apr 23, 2007 8:53 am Post subject: Oil pressure |
Sorry, I forgot to add that we have purged the system as per the latest rotax bulletin and also checked the regulator.
Correct me if I am wrong but I have seen “burping” the system. I have always assumed that this was rotating the prop in the correct direction with the cap of the oil tank off until you get the burping sound. Is this correct?
The only thing that I can think of is that it is some kind of restriction in the “circuit” which ceases to be a restriction once the oil is less viscous (warmed up).
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Jerry Rehn
Sent: Monday, April 23, 2007 11:27
Subject: RE: Oil pressure
Jerry
Will
Colombia
[/b]http://www.matronics.com/Navigator?Europa-Listhttp://forums.matronics.com[/b]01234567890
Posted: Mon Apr 23, 2007 8:55 am Post subject: Oil pressure |
Gilles
Thank you. Mmmmm, this sounds like an interesting route.
I think a change of oil line(s) would be an interesting step and non
invasive. Any ideas about which line to start with?
Will
terrys(at)cisco.com Guest
Posted: Mon Apr 23, 2007 11:33 am Post subject: Oil pressure |
Hi Will,
When we first got our engine running we checked the oil pump 'suction' as was called out in the Europa build manual in the engine provisioning(?) section. We found the suction to be too great, I'm at work now and don't remember the exact numbers. We observed that the Europa supplied oil line from the oil cooler to oil pump inlet had a molded 90 deg bend in it, a few inches before the pump inlet, and suspected that the oil line was partially collapsing at this bend. We replaced the molded elbow with a short section of 90 deg aluminum tubing. A subsequent oil pump suction test showed a drop in suction, bringing if fairly close to the specified maximum value. The suction values were, as expected, greatest when the oil was cold, and dropped off as the oil warmed up. I would expect that the elbow in the oil line feeding the pump inlet would be most likely to collapse when the oil is cold and the suction is at its greatest.
At the time (about six years ago) we sent emails to the Europa group asking what values others were getting in their suction tests, but received no responses from anyone who had performed the test. If there is anyone who has performed the suction test, I would be interested in hearing their numbers.
regards,
Terry Seaver
A135/N125TD
Monowheel XS with 912S, Whirlwind prop
Sent: Monday, April 23, 2007 9:53 AM
Will
Jerry
Will
Colombia
[/b][b]
Posted: Mon Apr 23, 2007 12:53 pm Post subject: Oil pressure |
Excellent – thanks.
I will look at this and report back
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Terry Seaver (terrys)
Sent: Monday, April 23, 2007 14:29
Hi Will,
regards,
Terry Seaver
A135/N125TD
Will
Jerry
Will
Colombia
[/b][quote][b] http://www.matronics.com/Navigator?Europa-List0[quote]1[quote]2[quote]3[quote]4
ami(at)mcfadyean.freeserv Guest
Posted: Mon Apr 23, 2007 1:35 pm Post subject: Oil pressure |
<<If there is anyone who has performed the suction test, I would be interested in hearing their numbers>>
-0.1 bar (max allowable is -0.3 bar) measured on a 912S. Hose is the 'standard' Rotax-supplied Conti (routed across the top of the engine) and oil tank fittings
The barbed push-on inlet fitting on the oil pump had been replaced with a nipple and 180 degree preformed fitting on the engine (the delivery hose 'approaches' under the gearbox from the S'bd side of the engine and therefore has to turn back on itself).
It surprises me that this test is not more popular.
Duncan McF.
danny shepherd
Joined: 27 Jan 2006 Posts: 117 Location: north Wales, United Kingdom
Posted: Mon Apr 30, 2007 6:45 am Post subject: oil pressure |
Hi All,
Can some one tell me if its normal for the oil pressure to
drop when revving up the engine. After start up the pressure immediately
reaches 4.5 bar, but when I throttle up it drops to 2.5. Is this strange
/ normal ? With all the talk about Rotax not liking oil starvation its
a bit concerning .
Cheers Danny
Posted: Mon Apr 30, 2007 9:28 am Post subject: oil pressure |
Hi Danny,
As I recall, we noticed a similar thing with our 912S, early on. We
noticed that our oil pump inlet 'suction' was too high and suspected
that the 90 deg bend in the molded inlet oil line was collapsing (this
is the line from the oil cooler to the oil pump inlet). We replaced the
bend in the oil line with a short aluminum elbow, which reduced our
suction at the oil pump inlet. As I recall, this also reduced the drop
in oil pressure at higher rpms. The bend I am talking about is the one
just a few inches (maybe 4 inches?) from the oil pump inlet.
Terry Seaver
A135 / N135TD
XS monowheel with 912S, Airmaster prop
william(at)wrmills.plus.c Guest
Posted: Mon Apr 30, 2007 9:02 pm Post subject: oil pressure |
I had the same symptoms, Danny, when my 912S was new. The Rotax oil
pressure gauge also twitched violently, before settling down at about 2.5
bar. However, 350 hours later, it no longer twitches and it runs at about
3.75 bar when hot in the cruise. I can only imagine the pressure relief
valve ball has eventually bedded into its seat. BTW, my previous engine was
a 912 (80 HP) which ran at 4 bar constantly all its life (800 hrs) and the
oil pipes and cooler were exactly the same from one engine to the other, so
I don't believe any of the pipes were collapsing due to suction.
I hope that helps,
William
danny shepherd
Posted: Tue May 01, 2007 12:37 am Post subject: oil pressure |
Thanks Pete / Terry / William, I'll get back in the hangar (big shed)
latter this afternoon and check the pipes.
Cheers Danny G-c.e.r.i
willie.harrison(at)tinyon Guest
Posted: Tue May 01, 2007 1:10 am Post subject: oil pressure |
Me too. I've observed the same and I'd been assuming - probably
wrongly - that it was due to a pressure regulating vale spilling
excess pressure at higher rpm.
On 1 May 2007, at 09:28, danny(at)mcwalterscafe.co.uk wrote:
<danny(at)mcwalterscafe.co.uk>
shed) latter this afternoon and check the pipes.
