Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Thu Apr 26, 2007 5:25 am Post subject: Painting...Painting... |
Hi Rog,
I’m not a painter so this is subject to review by those with actual experience. I did the grunt work.
- Cleaned skins with Lacquer Thinner to remove sharpie marks, tape, etc.
- Washed wings, etc. with Liquid Dove dishwash soap
- Let wings dry (standing on edge so water drains).
- Washed wings with Alumiprep and rinsed well (3 parts water, 1 part Alumiprep).
- Washed wings with Alodine and rinsed well. (3 parts water, 1 part Alumiprep).
- Stood all surfaces on edge so they would drain well over several days. Taped off areas that would not be painted.
- Took wings to paint shop. Painter looked at wings and had me scuff them up with Scotchbright pads (green).
- I previously ordered 2 gallons arctic white Acrylic Enamel 2 gallons Gray Synthetic Primer along with reducer and hardener from Paint For Cars (http://www.paintforcars.com)
- The painter sprayed primer while I held the parts to keep them from swinging. (That was the biggest mistake, hanging the parts from the ceiling. The lighter items had to be held to keep them at the right distance from the gun).
- Within one hour we started spraying the tack coat of Acrylic Enamel. Followed that with a second coat. Then the painter mixed ˝ enamel, ˝ reducer and sprayed a light coat. That light coat sort of smoothed everything out.
- The painter said he could have done a better job with a base/clear coat paint like Imron, but I’m happy and the paint was much, much cheaper (let’s hope it’s durability is good).
Hope this helps,
Tommy Walker in Alabama
| Quote: | | Tommy Looks Good! I am nearly ready to paint my 701 and interested in knowing more. Can you give details on what you used to prep and prime? Appreciate it Roger |
_________________ Tommy Walker
N25A - Anniston, AL |
roger(at)nwtradingpost.co Guest
Posted: Thu Apr 26, 2007 8:39 am Post subject: Painting...Painting... |
Tommy
Appreciate the detail. Think I am going to follow your lead
Roger
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Tommy Walker
Sent: Thursday, April 26, 2007 6:23 AM
Subject: Re: Painting...Painting...
Hi Rog,
Hope this helps,
0http://www.matron - NEW MATRONICS WEB FORUMS --> http://forums.matronics.com===================[/b] [/quote]1
steveadams
Posted: Fri Apr 27, 2007 4:13 am Post subject: Re: Painting...Painting... |
I'm not a painter either, but here are a couple of tips that may save a bit of work.
1. You can probably skip the Lacquer thinner cleaning on aluminum surfaces. I did the same initially, but then discovered that the sharpie marks are removed completely by the alumiprep/scotchbrite. One less step and less chemicals to deal with.
2. Use the scotchbrite pads when cleaning with dishwashing soap and alumiprep. It will clean up faster and scuff up the surface nicely. You won't need the additional step of going back and scuffing up the surface. I won't get into what color of scotchbrite to use.
3. An engine hoist makes a great mobile, adjustable hanger for the parts for cleaning, drying, and painting. Parts will still swing around a bit, but you can keep the lines short to minimize movement and adjust the height of the boom to put the part where you want it.
That's the extent of my knowledge for what it is worth.
Steve Adams
CH640
Tommy Walker
Posted: Sat Apr 28, 2007 6:02 am Post subject: Painting...Painting... |
Steve,
Those are good tips. I wish I had tried the alumaprep against the sharpie, tape residue first. And using a scotchbrite pad with the alumaprep would have been smart. My thinking was that the alumaprep etch would be enough etching of the skins. The painter knew better though.
"... 1. You can probably skip the Lacquer thinner cleaning on aluminum surfaces. I did
with.
Steve Adams"
