by0ung(at)brigham.net Guest
Posted: Wed Apr 25, 2007 7:39 am Post subject: 582 w/oil injection |
Hi all, I`m about to fire up a newly overhualed 582 w/oil injection. With
everything set up PER rotax sevice manual, when I crank the engine with the
electric starter, but with no gas available, shouldn`t I get some oil
movement in the lines between the oil injector & the engine crankcase where
the oil line attaches to engine? I`m hesitant to put gas in & run the
engine with no visible oil movement while cranking at different throttle
settings. Everything else ablout the installation looks great & "by the
book". Thanks, Jim Kmet
MK-3C
| Quote: | >>>>>>>>>>>>>>
If in doubt mix some oil in the gas... at the proper ratio... then after
20 to 30 min look at the level in the oil res,,,, if it has not moved go
back to the drawing board,,, if it has gone down drain the premix, check
the plugs and filer up. The oil feeds slow enough you may not see it move
with only the electric starter. Somewhere I remember that doubling the oil
for the first tank is good for the break in period...
Boyd
Richard Pike
Posted: Wed Apr 25, 2007 12:19 pm Post subject: 582 w/oil injection |
If you run it at part throttle with premix AND also pull the oil pump cable
to max, you can see the air bubbles pulsing through the oil line as the pump
sucks them out.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
jlsk1(at)frontiernet.net Guest
Posted: Wed Apr 25, 2007 6:29 pm Post subject: 582 w/oil injection |
Thanks, I ran it for a few min today with the premix, didn`t have time to
run it very long, just enough to bring up temps, & the oil has started to
fill the lines, evrything looks like it will be OK, thanks to everyone for
the help. Also, Richard, how far away from TRI are you & your plane? I`m
in there about Once a month lately, thought I might give you a call. I`m at
SRB
Jim
Richard Pike
Posted: Wed Apr 25, 2007 7:04 pm Post subject: 582 w/oil injection |
3TN0, about 4.5 miles north of TRI, about a ten minute drive.
http://www.airnav.com/airport/3TN0
Call me next time your at TRI.
Richard Pike
Kingsport, TN 3TN0
