rexinator(at)gmail.com Guest
Posted: Tue Apr 24, 2007 5:52 am Post subject: tire valve stem extentions for wheel pants? |
Seems I remember someone mentioning they needed to find a tube with the
longer extended valve stem for use with wheel pants. I just happened to
see these nifty items and thought I would pass the link along for
general interest.
http://www.dual-star.com/index2/Equipment/valve_stem_extensions41.htm
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs
Lynn Matteson
Posted: Tue Apr 24, 2007 12:46 pm Post subject: tire valve stem extentions for wheel pants? |
I was at least one that mentioned them, Rex, and thanks for posting.
I'll check them out.
Lynn
On Apr 24, 2007, at 9:52 AM, Rexinator wrote:
the longer extended valve stem for use with wheel pants. I just
happened to see these nifty items and thought I would pass the link
along for general interest.
Rex Hefferan
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Thu Apr 26, 2007 2:02 pm Post subject: tire valve stem extentions for wheel pants? |
I went to that site, saw what they had and decided that maybe what I
wanted was not a bent extension, but a bent valve *stem.* I went to
my local off-road dealer and found Yamaha tubeless valve stems that
are rubber and brass, bent, and very short. This will allow the stem
to miss the wheel bolts/nuts too. (I recall someone saying that they
had a set of wheels where the stem contacted the bolt/nut) If anybody
is looking for something like this, the part # is 93900-00802...$4.99
each. Honda has a similar part but plated, and cost about $6 more each.
Lynn Matteson
Lower Michigan
flying w/250+ hrs
Rex Hefferan
N369LM |
