k5wiv(at)amsat.org Guest
Posted: Mon Apr 23, 2007 3:01 am Post subject: Metallic wingtip paint & VOR signal strength? |
YES!
But I won't attempt to guess how much. It will depend on the exact
composition of the paint, the thickness of the application, how well bonded
to the airplane structure, etc. It could range from a barely detectable
effect to no signal received.
Jack Sargeant
1127 Patricia St.
Wichita, KS 67208-2642
316/683-5268
carl.froehlich(at)cox.net Guest
Posted: Mon Apr 23, 2007 3:22 am Post subject: Metallic wingtip paint & VOR signal strength? |
Not sure how much metal is in metallic paint. When I painted my plane, the
"metallic" additive to the paint mix was not metal.
Try it and see. I would guess you would not be able to measure the
difference in performance. I have a homemade wingtip comm. antenna and it
works fine. It is not as good as the belly bent whip comm antenna, but good
enough for a backup comm and fine for as a primary VOR antenna.
Carl Froehlich
RV-8A (325 hrs)
Posted: Mon Apr 23, 2007 5:43 am Post subject: Metallic wingtip paint & VOR signal strength? |
I don't know the difference between a metallic paint and a pearled paint,
but we have noticed no lack of signal strength in the planes that have been
painted with a pearled paint on the wingtips. We haven't actually compared
the distance that a signal is received from, but it is certainly not a
noticeable difference.
Do not archive.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
AV8ORJWC
Posted: Mon Apr 23, 2007 7:17 am Post subject: Metallic wingtip paint & VOR signal strength? |
YES.
John Cox
rvbuilder(at)sausen.net Guest
AV8ORJWC
Posted: Mon Apr 23, 2007 4:59 pm Post subject: Metallic wingtip paint & VOR signal strength? |
I am suffering from "Echo Bruises". Ever heard a never-ending echo
until the Doppler effect reminds you it is the same chatter just
rehashed and will eventually subside with time.
Oh, how I long for effective archives.
Over? I mean Aye?
Okay... What are "Echo Bruises"? They are the phenomena that good
instructors and great pilot examiner experiences when after a few years,
a new applicant for instructor sends a student who then becomes a second
generation student (pursuing instructor) who then sends you a third
generation applicant some time later. The individual from the third
generation uses the exact same answer to same or similar question from
three generations or more prior. Very little learning took place,
everything was rote learning. Bad habits are reinforced and worse with
each generation of new applicant you think you are losing it (Your
mind). The examiner has to go back to work with new questions or learn
to adapt the review during licensing to a higher level of learning. You
conclude it was poor examination technique from the Examiner (yourself)
with both the first and second generation check ride which led to the
ROTE student applicants.
If each student would regularly question (that's healthy), find their
answer from two separate qualified sources and then understand the
underlying principles - their learning would become invaluable for their
entire lifetime. Hence, safer pilots, safer planes and lower rates for
"Builder Interruptus types". Each generation would move farther down
the path towards true wisdom. This is no reflection on builders in the
#500 or #600 series. I was just feeling familiar bruises from
conversations Long Ago as a pilot examiner. Attorneys advise... Just
give a YES or a NO and don't expound.
Few here want extemporaneous discussion. Now on to my typical rant.
Metallic additive in lacquer, enamel and poly paint is aluminum flake,
it comes in various sizes. Aluminum is a metallic material. Metallic
materials do not improve RF signal propagation except in the ground
plane. In pearl, it is another beast altogether. Carbon fiber in either
canopy construction, wingtips or fairings impedes RF signal propagation.
Metallic paint or a poor ground plane do the same things - negatively
influence the signal.
Now Mr. Sausen are you all happy? I am dreaming of OSH and those cold
beers I owe to last year's group.
Mr. Wellenzohn, your question is excellent and should not discourage the
use of metallics, something that was done to a close friend down in
Phoenix. Just properly tackle RF signal propagation techniques.
Kitplanes (the mag) has done some good work on the subject and it is
available in their archives. Most builders couldn't even explain how
their ELT antennae will work in a typical crash. Now is that learning?
John #600
Posted: Mon Apr 23, 2007 5:58 pm Post subject: Metallic wingtip paint & VOR signal strength? |
As expected you have met and exceeded my expectations! Only a couple months to go, see you then.
Michael
Posted: Mon Apr 23, 2007 5:59 pm Post subject: Metallic wingtip paint & VOR signal strength? |
Aaaaah, he's back.... Welcome back, John. The list has been so (read easy to understand/follow) without you.
Jesse Saint
352-427-0285
Mike Whisky
Posted: Tue Apr 24, 2007 2:52 am Post subject: Re: Metallic wingtip paint & VOR signal strength? |
Wow, thanks for all your replys. Lets see if I can get the KITPLANE magazine here in CH.
Best Regards from Switzerland
Michael (who has quit his job to go full time building)
http://www.wellenzohn.net
_________________ RV-10 builder (flying)
#511 |
Posted: Tue Apr 24, 2007 5:18 am Post subject: Metallic wingtip paint & VOR signal strength? |
Darn it John, use small words and keep it monosyllabic for Jesse would ya. HA!
AV8ORJWC
Posted: Tue Apr 24, 2007 6:51 am Post subject: Metallic wingtip paint & VOR signal strength? |
They have an excellent website. The subscription is probably better
than an electronic version but you will have to ask others.
Occasionally the topics are a little off the mark but most of the
articles will hit a "Wow that was a great article this edition".
John
